PPAP - No Critical Characteristics on Print
Q
qualitytrec
What level PPAP are you required to submit? And is your customer asking for Capability?
Mark
Bill Ryan - 2007
1) You can beg your customer to define a couple (but WHY??)
2) You define "Critical Characteristics" internally (example - if a feature is maintained you are sure that some/most other features are also "acceptable"
3) You submit without any "Critical Characteristics" defined
The majority of our part drawings have no "CCs" called out.
Q
QualityJedi
Ask your customer to submit a preliminary Part Submission Warrant. If there is no critical charastics defined then you don't have to worry. It may just be a level 1 PPAP. Always get a warrant first.
Bill Ryan - 2007
You lost me there.
Where on the Warrant do critical characteristics get mentioned :confused: .
What is a "preliminary" Part Submission Warrant from my customer :confused: (by any chance do you mean a PPAP checklist?)
Jim Howe
1killercls said:
What the heck do ya do??? :bonk:
At my location we define, in our engineering standards and procedures, what are CTQ's, such as Line Bores and Boss Spacings. If the CTQ is not defined in our standards, then the engineer must identify it on the drawing. If I were faced with your situation I would look for attributes that would affect function and use them as the CTQ's.
:2cents:
Q
qualitytrec
Except when I worked at Intier Automotive I have always been the one to submit the warrant (as part of the PPAP). This is the way our customers want it and they get what they want.
As for the original question. Ask your customer what level PPAP is required if you did not do this in contract review (where it should have been done). This will put you on the right trail. Then open your PPAP reference manual and away you go. If there are no CCs then you likely do not have to produce capability on any. If you ask your customer about the CCs they will do one of a few things
:bonk: der, what do you mean
:eek: Golly I forgot, thanks
:naughty: Assign some random feature for no apparent reason
or
:D say do not worry about it we do not need them.
They could ask for capability on process parameters or something else also.
Ask your customer what they need.
Mark
Howard Atkins
Forum Administrator
I would like to make some order in this question, forgive me if I misinterpet.
The original question was: "what to do if there are no critical characteristics"
In general the answer is nothing, it is not a problem to anyone.
If there are CC then you have to perform capability studies, whether you submit them is dependent on the level, not whether you do them.
If there are no CC's then you don't have to perform capability studies.
You might want to do them for yourself of to validate a process etc. but the PPAP handbook does not require them.
If the customer requires capability studies that are not for CC's then this is a question to be discussed.
In any case do not invent any thing.
I think that the most constant advice in regards to PPAP is to ask the customer.
If you and the recipient of the PPAP are in tune every thing goes easier.
I hope this has helped.
s-bell
I agree completely with this approach :agree1: , the customer may not have put CC's on a drawing because the part does not have any critical features. One important issue to consider though is that if the drawing however has the inverted Delta (Signifying Safety Critical) or equivalent on it, but no CC's defined, I would talk immediately to my customer as a safety critical or similar product usually has key features that require control. If these are omitted I would be a little concerned that I may be hit with a late requirement from the customer that was initially missed but has an effect on PPAP dates.
If this is not the case, as Howard correctly states if you wish to perform internal capability studies then you are at liberty to do so for your own gratification and confidence in your processes. Remember if you perform these yourselves it is not compulsary to be part of the PPAP package but obviously you may review with your customer if you feel the need.
Jim Howe
I agree with what you are stating :agree1: But I am a bit confused? :confused: What is a critical characteristic? Is it not a characteristic that affects form, fit or function? If it is not defined on the drawing should it have been? Does anyone have a good definition?
L Gage R&R studies and control plan for PPAP - Critical or Significant characteristics? APQP and PPAP 16
J What level PPAP for 5 critical parts? APQP and PPAP 8
V Out of Tolerance on Non Critical Dimension (PPAP) APQP and PPAP 8
J Supplier not responding to PPAP request APQP and PPAP 5
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
B Toyota PPAP Process - Three Questions APQP and PPAP 3
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
P PPAP samples retention time IATF 16949 - Automotive Quality Systems Standard 5
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K OEM specific requirements - PPAP was rejected by STA Customer and Company Specific Requirements 5
T PPAP for distributors? APQP and PPAP 1
A PPAP for Fire extinguisher APQP and PPAP 2
S PPAP Progress - Visual Status Board APQP and PPAP 0
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
B What is the role of Quality Engineer in APQP and PPAP APQP and PPAP 3
F How to submit PPAP without IMDS APQP and PPAP 10
GreatNate Excel PPAP Tracking templates or tool wanted APQP and PPAP 1
M Where can I find examples of PPAP? APQP and PPAP 6
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
I PPAP Assembly and Components Manufacturing and Related Processes 3
F PPAP Documentation Control APQP and PPAP 8
K PPAP Phases Vs PPAP Levels APQP and PPAP 2
R Plan to Volvo Cars for capacity verification in Phase 3 of PPAP Customer and Company Specific Requirements 3
G Job interview - So I have to do a presentation on PPAP APQP and PPAP 16
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
M Level 3 PPAP submission of intentional defective parts APQP and PPAP 4
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
A New Supplier implementation - PPAP vs APQP APQP and PPAP 9
E Nissan (Renault) PPAP Acronyms (DNote , KFD, IR) APQP and PPAP 2
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
N PPAP material certificate date IATF 16949 - Automotive Quality Systems Standard 4
P Paint shop vs PPAP requirements IATF 16949 - Automotive Quality Systems Standard 5
N How to resolve discrepancies in Level 3 PPAP supplier dimensional reports? APQP and PPAP 11
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D PPAP a Rebranded Purchased Product (we don't manufacture) IATF 16949 - Automotive Quality Systems Standard 6
E Solder thermal profiles for PPAP - Automotive IATF 16949 - Automotive Quality Systems Standard 1
P Automotive Customer asking PPAP for catalogue parts IATF 16949 - Automotive Quality Systems Standard 16
V PPAP documentation - Submission required in English APQP and PPAP 3
H Informational What is PPAP (Production Part Approval Process)? APQP and PPAP 26
S PPAP Levels compared to Interim Class APQP and PPAP 1
E PPAP Workbook 4th APQP and PPAP 3
N Can you use parts from Run at Rate to use in your PPAP? APQP and PPAP 4
N Who shall manage PPAP process? APQP and PPAP 4
