PPAP question for audit
andrei iuganu
Hello group.
Questions about PPAP.
We have PPAP documentation approved for the production of parts from the automotive industry by plastic injection.
1. If during an audit it is found in the Standard with process parameters a change = eg in PPAP the piece had 10 g after injection, now by changing the parameters in the standard following a revision, I have for example 12 g, this change must be communicated the client?
is it a non-compliance to change the parameters without notifying the client?
in this case for the weight of the part I have no tolerance, and in CSR the client does not specify anything about this.
2. if the revision to the standard with parameters is done then in the evidence of the revisions it must be specified and what has changed?
is non-compliance only the evidence of revisions without specifying the changes?
thank you very much
Not enough information. I don't know what "...changing the parameters in the standard..." means. Did you do an IMDS submission for this part? Has anything in the PPAP submission changed as a result of the change, such as the control plan? Why was the change that resulted in the weight increase done?
andrei iuganu
change in parameters example: in Parameters sheet used for making the trials/ first aproval part we have 250 c temperature in nozzele head. after ppap aproval, when we start real production, we use instead off 250 c in nozzle head 260 C.this is a change off parameters.
Johnnymo62
Haste Makes Waste
Do you have tolerances for your process parameters? Are you still within these tolerances? If so, then no problem. If not you need to re-PPAP.
My experience, a lighter weight injection molded part may not be packed out adequately which may make the part weaker.
andrei iuganu
yes. we have tolerance. this is my concern, when we are out of tolerance. thx for all response.
andrei iuganu
"...changing the parameters in the standard..." means.= manufacturing
yes
No , control plan don’t change, only value of an parmater from parameter sheet
We investigate.
thx in advance.
Sebastian
Could you answer my question?
It looks like process parameters specifications were defined "too easily".
It is not question of making "good" parts and job finished.
It is about determining boundaries. Getting knowledge when NOK part could be made.
S APQP, PPAP and PSW Question from a Rookie APQP and PPAP 4
J Prior Notice of Sub-Supplier or Material Source Change - PPAP Requirements Question APQP and PPAP 13
J PPAP Requirements Question APQP and PPAP 4
E Question about AIAG PPAP Third Edition APQP and PPAP 2
J Plastic Injection Molding Mold Change - PPAP Process Question APQP and PPAP 8
J Microsoft Access Integrated Database Question - PPAP Module Software Quality Assurance 13
R Sister Plant PPAP Question - Can we hold the PPAP paperwork and not send it to them? IATF 16949 - Automotive Quality Systems Standard 13
B Question about "When PPAP is required" - Tier 2 to GM - Fabric Density on Part APQP and PPAP 24
A PPAP Alternate Equipment IATF 16949 - Automotive Quality Systems Standard 10
O PPAP'ed part manufacturer has discontinued production Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 7
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 16
R PPAP Requirements for Tool Repair or Refurbishment APQP and PPAP 5
abrego44 AIAG PPAP manual for service part APQP and PPAP 2
G PPAP for Chemical Products APQP and PPAP 4
T Re-PPAP after updating CMM program? Manufacturing and Related Processes 9
J Supplier not responding to PPAP request APQP and PPAP 5
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
B Toyota PPAP Process - Three Questions APQP and PPAP 5
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
P PPAP samples retention time IATF 16949 - Automotive Quality Systems Standard 5
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K OEM specific requirements - PPAP was rejected by STA Customer and Company Specific Requirements 5
T PPAP for distributors? APQP and PPAP 1
A PPAP for Fire extinguisher APQP and PPAP 2
S PPAP Progress - Visual Status Board APQP and PPAP 0
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
B What is the role of Quality Engineer in APQP and PPAP APQP and PPAP 3
F How to submit PPAP without IMDS APQP and PPAP 10
GreatNate Excel PPAP Tracking templates or tool wanted APQP and PPAP 1
M Where can I find examples of PPAP? APQP and PPAP 6
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
I PPAP Assembly and Components Manufacturing and Related Processes 3
F PPAP Documentation Control APQP and PPAP 8
K PPAP Phases Vs PPAP Levels APQP and PPAP 2
R Plan to Volvo Cars for capacity verification in Phase 3 of PPAP Customer and Company Specific Requirements 3
G Job interview - So I have to do a presentation on PPAP APQP and PPAP 16
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
M Level 3 PPAP submission of intentional defective parts APQP and PPAP 4
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
A New Supplier implementation - PPAP vs APQP APQP and PPAP 9
E Nissan (Renault) PPAP Acronyms (DNote , KFD, IR) APQP and PPAP 2
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
N PPAP material certificate date IATF 16949 - Automotive Quality Systems Standard 4
