PPAP to Customer with Deviation Request
V
vardar3
My supplier submitted a deviation request for a fine blank transfer tool. Dimensions are out and they stated they are not going to fix it because we provided no money for refurbishment (we would have to pay for it).
Anyways, I never PPAP'd to a customer with a deviation request, and wanted to ask about how I should proceed with the customer. Should I come out with it and indicate how we are controlling from making non conforming product?
What have been some of your experiences with PPAPing to the customer with supplier deviation request?
Your supplier should have discussed this and gotten it settled before PPAP submission. Submission of nonconforming parts without prior approval is reason for PPAP rejection, no matter where the cause of the problem might lie. As soon as the supplier was aware that the tool was incapable, you should have been notified. In these days of consolidations and plant closings, there are a lot of hard tools being moved around, and I've learned from experience that transferred tools are subject to what I call the Cracker Jack Syndrome--there's a surprise in every box.
You are now in the same position your supplier was in--you need to get this settled before submitting your PPAP. A lot depends on design responsibility and who owns the tool. Whomever that is should be apprised of the situation and given a choice--change the specifications or pay to have the tool refurbished.
Howard Atkins
Forum Administrator
Is it useable out of tolerance?
If it is not there is no question.
If it is then think about cost benefit.
Also think about why the supplier did not communicate with you and do you want a supplier like this
DrM2u
I cannot agree more with Jim and Howard! Here are some of my thoughts to add to this discussion:
I have never submitted or approved a PPAP with a deviation REQUEST attached to it. It means that the planning process is not completed and that any differences from requirements have not been settled. What if the request is not approved? How does that affect the PPAP and all the work done prior to submittal?
Another thought is 'what is a deviation request?'. To me, an approved deviation is a TEMPORARY approval to deviate from the specifications until either the specifications change or the tool/process is corrected. A deviation should have a limit of time and/or quantity of parts large enough to allow for the necessary changes to take place. Continuing the thought, a PPAP with an attached deviation is implicitly a 'temporary' PPAP, an exercise that should be done once more when the tool is changed. In lucky cases, the design is changed and the PPAP stands as submitted; however, how often have one succeeded in getting a design changed? Telling an engineer that his design is flawed is like telling a mother that her child is fuggly and dumb like a door nail.
In conclusion, all the deviations from the print specifications should be settled prior to submittal and/or approval of a PPAP. So, either the tool owned should repair the tool or the design owner should change the design. The two entities should collaborate to identify the best (read 'cost effective') alternative that does not affect the product (fit, form and function) and the customer.
amit_rd
In addition to what other elsmarians have pointed, I want to bring a different dimension:
"we provided no money for refurbishment (we would have to pay for it)" ---- This indicates that this issue was raised by the supplier earlier - If this is true then I see it as a gap from your organization. Moreover knowing this gap only during PPAP also indicates that your organization had insufficient control over this supplier during the APQP process else this problem would have been identified earlier.
I recommend transparency while communicating with your customer because at times all criticalities are known only to the end users.
This reminds me that "Customer Focus" can not be achieved without having "Mutually beneficial supplier relationship"
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
P Automotive Customer asking PPAP for catalogue parts IATF 16949 - Automotive Quality Systems Standard 16
P Customer wants a Part Material Change - New PPAP required? APQP and PPAP 3
G Customer wants PPAP on Old Parts to New Standards APQP and PPAP 8
N Customer wants a PPAP/PSW on some Prototype Parts APQP and PPAP 6
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
Y Customer Specific PPAP Level 3/4 Requirements - Fastener Manufacturer APQP and PPAP 2
T Customer requires Internal Specification to be met on PPAP APQP and PPAP 7
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
V Submitting Supplier Information in Customer PPAP APQP and PPAP 2
Stijloor GM (Supplier) and PPAP Requirement 3.1 Customer Notification APQP and PPAP 5
C AS9100 Customer requiring PPAP APQP and PPAP 3
W PPAP MSA for each new customer IATF 16949 - Automotive Quality Systems Standard 9
S Guidance to prepare and submit a Level 3 PPAP to a Customer APQP and PPAP 6
K Looking for Ideas to Track Customer Requests and PPAP Data Packages APQP and PPAP 4
J Customer PPAP Approvals - Internal PPAP Possible? APQP and PPAP 7
V We put Old plating spec on supplier prints and need to PPAP to Customer. APQP and PPAP 1
V Can't PPAP to Customer because a Supplier was Re-Sourced APQP and PPAP 2
R Customer using their own version of the AIAG PPAP Forms APQP and PPAP 5
E PPAP PSW Approval: Customer Drawing or Supplier Drawing APQP and PPAP 4
I Repair and Service Facility - Customer wants PPAP for Refurbished Equipment APQP and PPAP 3
P ISIR vs. PPAP - Customer is requesting an ISIR Cover Sheet according VDA Quality Manager and Management Related Issues 5
M PPAP including FAI Parts - Customer is requiring 5000 measurements APQP and PPAP 15
S Can PPAP be submitted when not all customer requirements can be met? APQP and PPAP 5
B Cost for PPAP - Customer pays for samples and PPAP documentation from supplier APQP and PPAP 8
D Outsourced Material - Customer who is asking us for a level 3 PPAP APQP and PPAP 8
S PPAP for VW QPN - PPAP documentation for Volkswagon customer APQP and PPAP 4
S Customer PPAP notification and submission for a Change APQP and PPAP 2
P PPAP Approval - Customer approval of PSW (part submission warrant) APQP and PPAP 5
H How to refuse PPAP submission to a customer? APQP and PPAP 7
P PPAP submission for a new customer of an existing product APQP and PPAP 7
M PPAP Review Updated yearly but not send to Customer - Is it Right? APQP and PPAP 12
H Requirements in TS for PPAP - Full PPAP or as per Customer Requirement? IATF 16949 - Automotive Quality Systems Standard 14
M How can I say no to a customer PPAP request APQP and PPAP 14
D Level 3 PPAP for Customer - We are outsourcing the processing FMEA and Control Plans 6
R PPAP customer notification - what do you think? APQP and PPAP 12
5 PPAP Request from our Customer for an Assembly we Purchase APQP and PPAP 9
S Supplier requesting Customer PPAP submission APQP and PPAP 5
kedarg6500 PPAP for Continuous Process like Copper Wire Enameling but SWG differs per customer APQP and PPAP 3
M Customer Notification Rules under PPAP 3.1 APQP and PPAP 2
K PPAP per QS-9000, rev.4 - Customer rejected our normal PPAP APQP and PPAP 3
R Engineering changes for customer notification - PPAP Submission APQP and PPAP 5
S PPAP on Prototype tooling? Producing components for internal customer (assembly) APQP and PPAP 5
C Notice Received from Customer Regarding PPAP's & FAIR's APQP and PPAP 8
T Do They Submit PPAP with a Uniform PSW from Customer? APQP and PPAP 7
R Changing Suppliers - Customer (GM) PPAP required? APQP and PPAP 6
M DaimlerChrysler (DCX) Customer Specific Requirements for PPAP 4th Edition Customer and Company Specific Requirements 8
Sidney Vianna Chrysler Customer Specific Requirements For PPAP 4th Edition IATF 16949 - Automotive Quality Systems Standard 10
