Ppk/Cpk value with 1-sided specification - Only given a lower specification
F
froggy66
Knowing that ppk and cpk values are calculated based on the target value, how would a ppk or cpk value be calculated if you are given a lower spec only? For instance, if you are given a spec of .00025 min, how would you calculate the ppk/cpk value? Any help is appreciated.
thanks:confused:
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Can Ppk value be greater than Cpk and if yes, under what conditions? Statistical Analysis Tools, Techniques and SPC 10
B Attribute capability indices - Cpk and/or Ppk value for an attribute type of feature Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
K Normality of distribution prior to Cpk and PpK Statistical Analysis Tools, Techniques and SPC 4
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
S Are Pp and Ppk more useful than Cp and Cpk as a benchmark for further studies? Statistical Analysis Tools, Techniques and SPC 1
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
B Difference between Ppk (Preliminary), Cpk, Performance Capability Statistical Analysis Tools, Techniques and SPC 2
D Real life example of the difference between Cpk and Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 0
N Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 25
V Quality Control Index - We thought that Cpk or Ppk would be good choices Capability, Accuracy and Stability - Processes, Machines, etc. 6
Tim Folkerts Interpreting the common capability indices: Cp, Cpk, Pk, and Ppk. The Reading Room 5
J Machine issue in Cpk/Ppk and Control Plan - PPAP Submissions APQP and PPAP 5
D Use of an outlier in calculating Cpk/Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 8
N Analysis of non-normal stratified data for cpk/ppk? Rupture test Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
Howard Atkins Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Statistical Analysis Tools, Techniques and SPC 4
S What is the meaning of "k" in Cpk and Ppk? And Cpk vs. Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 15
A Capability Indexes for ISO/TS16949 - Cpk & Ppk after PPAP Statistical Analysis Tools, Techniques and SPC 6
