Ppk for Combined Data Sets
sinned
Registered Visitor
I've got a set of data from the process engineer with its Ppk calculated to be 1.80. However, it turns out that the set of data are a combination of four sources, each of which from ID measurement of an individual hole. (As usual, they can't be distinguished anymore)
In this case, what can be said about the stdev and Ppk for those individual holes ? Should the Ppk for each hole be ~1.8 at worst case ?
bobdoering
Stop X-bar/R Madness!!
The point of Ppk is to see if the process is centered and falls within the specifications. That said, how does combining four sources represent a "process"? What question would that answer? A "Grand Ppk" of a part? I suppose if it passes, the lesser levels of capability should be academic. But a process needs to first be analyzed with time-order data plotting (both the highest and lowest of each part's diameters, in the case of a circular feature), then generalized with capability indices – if applicable.
The other point that arises from data being presented in this manner is the training of the process engineer on capability. It sounds like they barely know the basic concept of rubber stamping Ppk, and very little about the underlying concepts. Ultimately, they are not using the tool to make good decisions.
I believe that would be the case, but the other question is whether Ppk is even applicable. What is the process making the hole? How is the process controlled (SPC)…or is it? Is the measurement system accurate to truly detect the variation?
mathematically the individual Ppk values can't be greater than the whole for that data set.
IF you plot the histogram or trend the values and see distinct peaks that might be an indication that there is a difference in the hole IDs but this difference - if it were to exist -would over estimate teh standard deviation giving you a worse overall Ppk...
sinned
Registered Visitor
This is also what I've observed: when individual data set are combined into a mix of different data stream, the Cpk would always get worse than calcuated seperately.
Can i argue that if i am getting a mix data set with Cpk>1.33, the individual data stream will not worse than that figure ?
sinned
Registered Visitor
Yes, bobdoering. Thanks.
I can't say the process engineers understand SPC or Ppk. But when they heard that 100 ID data Ppk has to be done in few days on a part with 4 holes, that was the report turned in to the quality guy right before the deadline.
You don't have to argue it - you can state it with confidence
On the other hand, this statement makes the confidence in your true capability an issue of practicality rather than statistical math. 100 parts in a short time gives almost no practical confidence in your stability or capability over time. And if your sample is composed of 4 holes across 25 sequential parts you have even less.
Of course it sounds like your organization is just 'checking the box' of a short term PPk study for your customer and you really aren't trying to understand your process?
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
R When Pp>2, and Ppk<1.33, can we approve a new process? IATF 16949 - Automotive Quality Systems Standard 3
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Advise on R Chart with Ppk of 17.85 for Ford Capability, Accuracy and Stability - Processes, Machines, etc. 37
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Ppk Issue - Some Products have Unilateral Tolerances Capability, Accuracy and Stability - Processes, Machines, etc. 24
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
M How to Do Ppk on Non-Normal Data Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
A Ppk Reporting - Ideas to make it more meaningful for Management Statistical Analysis Tools, Techniques and SPC 3
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
J Using Ppk to set up Control Plans - Injection molding Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
K Normality of distribution prior to Cpk and PpK Statistical Analysis Tools, Techniques and SPC 4
R Can Ppk value be greater than Cpk and if yes, under what conditions? Statistical Analysis Tools, Techniques and SPC 10
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
