Ppk results shown as asterisk after the transformation of Non-normal data
Hi all,
I used Minitab 17 to calculated the Ppk of my 30 samples non-normal data and it's resulted as an asterisk for Ppk results in 1 set of data (The rest of data are include with both normal and non-normal and it's normally shown the Cpk/Ppk result in both normal and non-normal run). So I would like to ask if there any cause that make this data set failed to shown the Ppk results?
BTW my failed data set is as below:
#12
n = 30
Subgroup = 1
LCL = 5176.5
UCL = 5278.0
5240.6
5241.6
5241.8
5242.4
5242.0
5241.4
5240.4
5242.2
5242.2
5241.4
5242.2
5241.4
5241.6
5242.4
5243.4
5242.2
5239.0
5240.4
5241.4
5240.4
5238.2
5242.8
5237.2
5238.8
5239.2
5239.6
5237.4
5234.4
5237.1
5234.6
*FYI. for my failed run I used Weibull base on its p-value has the most fit distribution.
Thanks.
I'm not a minitab user - maybe Miner can chime in here.
Is your data sequential parts?
the sample size is pretty small for a capability index - is this just short term data collection?
a simple run chart shows you have a substantial decrease in values a the end - that would lead to your non-normal look of the data. this 'instability' makes any transformation inaccurate. perhaps that's why minitab gives you an *?
Bob - not sure how you get a Ppk of 1.96 when the data is so small compared to the tolerance?
This is all that Minitab Help has on the subject. Why are some capability analysis results shown as asterisks in the output?
None of these specific examples appear to apply in this case. However, the asterisk appears when the index cannot be calculated. The non-normal capability that Minitab uses calculates a z-score from the Weibull function then converts that to Pp/Ppk. It may be that Minitab's Weibull function does not provide a z-score that large (i.e., the programmer set limits on the calculation).
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
R When Pp>2, and Ppk<1.33, can we approve a new process? IATF 16949 - Automotive Quality Systems Standard 3
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Advise on R Chart with Ppk of 17.85 for Ford Capability, Accuracy and Stability - Processes, Machines, etc. 37
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Ppk for Combined Data Sets Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Ppk Issue - Some Products have Unilateral Tolerances Capability, Accuracy and Stability - Processes, Machines, etc. 24
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
M How to Do Ppk on Non-Normal Data Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
A Ppk Reporting - Ideas to make it more meaningful for Management Statistical Analysis Tools, Techniques and SPC 3
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
J Using Ppk to set up Control Plans - Injection molding Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
K Normality of distribution prior to Cpk and PpK Statistical Analysis Tools, Techniques and SPC 4
R Can Ppk value be greater than Cpk and if yes, under what conditions? Statistical Analysis Tools, Techniques and SPC 10
