N
Hi greetings!!
I work in the automotive industry, my story for you guys is...
We mold plastic injected parts, which go into an assembly process, our clients requieres or states, in the assembly drawing PQC, which for him I understand are product quality characteristics.
Now, I know that being in the drawing, I must put them in the PFMEA, but given that they are all points in the surface of a plastic components in the form of x= y= z = and given that the assembly line has no way of measuring this points, my thoughts are that maybe a check in a GDT can be used.
My questions are:
If the manufacturing ( assembly line) process does not mess with those pqcs, should they still be considered in the Assembly process PFMEA?? How can I be sure?
Should they be considered, should they be considered only in the molding process requirements of the PFMEA since they are all points in the surface?
Since it is the assembly drawing that is requesting us this PQCS, is it correct if I consider them in the molding process part of the PFMEA??
I hope you can help thank you.
My questions are:
