Pre-clinical Animal Studies for long term implantable medical devices
Aliasanonymous
Hi covers,
I have been told that animal testings are only required for long term implantable medical devices. Is that true? How could it be that a clinical investigation (clinical trial) is required but not a pre-clinical animal study? I am looking at a class III device.
Is there a guideline for decisions on whether or not a pre-clinical animal study is required?
Thank you in advance!
Ronen E
Problem Solver
Moderator
Re: Pre-clinical Animal Studies
Hi covers,
Animal studies are typically required wherever the initial risk in human-subject trial is considered too high.
Cheers,
Ronen.
PS It could help if you specified what regulatory system you are referring to (FDA, EC etc.), and what sort of device is at stake. Thanks.
Sam Lazzara
The attached 2010 US FDA guideline does not exactly answer your question but it should be useful just the same. It is called General Considerations for Animal Studies for Cardiovascular Devices.
Some of FDA's guidelines for premarket submissions provide specific animal study guidance for particular devices.
Overview - 2010 Guidance mentioned above
FDA recommends that you consider the following general principles when developing animal study strategies for cardiovascular devices:
  • You should follow Good Laboratory Practices (GLP) for all animal studies involving cardiovascular devices that are to be submitted to the Agency.
  • The animal model selected for a cardiovascular study should be generally accepted for the study of the device type. That is, there should be a reasonable amount of scientific evidence that the animal model has utility for the study of the product class.
  • FDA’s primary purpose in asking for an animal study for a particular device is to demonstrate sufficient safety including performance and handling. A secondary objective is to study the efficacy of the device, if applicable. Sometimes the performance of a particular device is intricately linked to its safety, such as for products that provide circulatory support.
  • The in vivo setting generally provides FDA with an initial assessment of how the device interacts with biologic systems and also how the biologic system may affect the device, such as via device corrosion and structural deformities.
  • You should observe the best practices of refinement, reduction, replacement, and current standards of humane veterinary care and use. This may also involve consideration of available validated alternatives.
Aliasanonymous
Thank you for the replies.
Ronen,
Does that mean it is all risk based? So if the device is not a new device and does not have novel features, I can go straight to human-clinical tests and skip the animal tests (given that tests have been done on similar existing devices)?
We are looking at both the FDA and EC requirements on class III transient invasive devices.
Sam,
Thank you for the document. It will come in handy when we start structuring the tests. The problem now is whether or not we need to do them. :confused:
Ronen E
Problem Solver
Moderator
Ronen,
I'm sorry, but based on general descriptions I can only give general answers. Saying that the device is a "class III transient invasive device" is a step in the right direction but it's not enough for a definite answer. providing the FDA's ProCode would be very helpful. If you are reluctant to expose more in a public space please send me a PM.
Cheers,
Ronen.
planB
Ronen,
Sam,
have a look at ISO 10993-1, which is harmonized in Europe and a recognised consensus standard in the US. Yes, you have to follow a risk-based approach.
Follow the flow chart in ISO 10993-1 and have a look at the tests-to-consider matrix in the annex of the standard.
In addition have a look at this FDA draft guidance, which highlights the Agency's expectations when interpreting ISO 10993-1:
"Use of International Standard ISO 10993, "Biological Evaluation of Medical Devices Part 1: Evaluation and Testing", April 2013
This draft guidance contains a slightly modified flow chart.
Generally,
1) Only test what you do not know
2) Prefer in-vitro over in-vivo testing if there is an adequate and valid in-vitro test available
3) If you can demonstrate device safety and performance in an appropriate in-vivo study of course you would not skip these animals tests and put humans on risk; at least in Europe you would a hard time with the Ethics Committee justifying a clinical study when the same data could be generated in an animal study or even in an in-vitro test ....
HTH,
Gerhard
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
J Pre-clinical Studies for RUO Product Other Medical Device Regulations World-Wide 1
J Custom-made implants (Class IIb) and pre-commercialization clinical trials in Spain EU Medical Device Regulations 4
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
M Ownership of Pre-Clinical cGMP Stability Testing Other Medical Device and Orthopedic Related Topics 2
L Pre-Clinical Studies for Medical Devices in Thailand Other Medical Device Regulations World-Wide 2
bio_subbu FDA issues draft PMA (Pre-Market Approval) Clinical Study Guidance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
S Pre-Submission for Breakthrough Device Designation - What's the threshold? US Food and Drug Administration (FDA) 8
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
H Queries: RFD & Pre-RFD Program Medical Device and FDA Regulations and Standards News 0
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 0
D Pre-Submission after 510(K) Submission? Other US Medical Device Regulations 4
M Informational Health Canada guidance document – Pre-market Requirements for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
C Shipping Medical Devices to US before pre market clearance US Food and Drug Administration (FDA) 1
A UDI requirements for pre-filled combination devices - Box containing a pre-filled device US Food and Drug Administration (FDA) 2
D Redacted pre-submission bundle that you would be willing to share US Food and Drug Administration (FDA) 3
I Bench Testing & Pre-verification vs. Formal verification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D FDA Pre-Submission Meeting Advice US Food and Drug Administration (FDA) 0
M Medical Device News Health Canada – Consultation: Pre-market Requirements for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
L 510 (K) Pre-Sub meeting - Does it worth? US Food and Drug Administration (FDA) 4
A Examples of Pre-Sub, SRD, PMA Shells and Templates Other US Medical Device Regulations 3
B Manufacturing site relocation of pre amendment Class II medical device Manufacturing and Related Processes 4
A Users won't return devices from pre-CE performance evaluation study EU Medical Device Regulations 3
B GM GP-12 Pre-Launch - They asking for a I chart Statistical Analysis Tools, Techniques and SPC 2
GoSpeedRacer Pre-Work and Study for ISO 13485:2016 Lead Auditor Class ISO 13485:2016 - Medical Device Quality Management Systems 1
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
V Is 'Compliance' a pre-requisite or is it ok before Batch Release to Market? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 47
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
H Pre compliance test for Glucometer Other Medical Device and Orthopedic Related Topics 1
V Pre-dispensed API material received in predetermined quantities & given to production Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
somashekar Pre-Announced FDA 4 Day Inspection, Class 2 Devices, Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
Q FDA Consensus Standard for PMA (Pre-Market Approval) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Does anyone have experience providing a summary of Pre-IDE discussions in the 510k US Food and Drug Administration (FDA) 1
JoCam Format of Health Canada pre-market licence application Canada Medical Device Regulations 3
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V 510(K) Cyber Security Documentation for Pre-market Submission (Templates) Other US Medical Device Regulations 6
A Infusion Pump - Pre-Clearance Inspections Learnings US Food and Drug Administration (FDA) 4
Crimpshrine13 ISO/TS 16949 Pre-Audit Requirement IATF 16949 - Automotive Quality Systems Standard 18
Marc USA to insist on pre-flight mobe power probe Travel - Hotels, Motels, Planes and Trains 3
G 510(k) Pre-market approval Application Requirements - Effectiveness of the product Other US Medical Device Regulations 1
K Harmonisation of Global Medical Device Pre-Market Regulations Other Medical Device Regulations World-Wide 5
