Pre-Design Verification - Using Continuous / Variables Data
daamor
Hi all!
I've been so frustrated lately because I feel like I'm struggling with such a simple concept.
I'm used to performing design verification by choosing statistical C/ R intervals based on our risk analyses (95/90 or 95/95 usually) then selecting an attribute sample plan to test (n = 29/ 59 usually).
However, I can't for the life of me figure out how to set up the sample size for variable data collection.
Some of the specs are 2 sided. For example, lets say a pouch seal strength of 15 N +/- some number.
During Pre-DV, we may not necessarily know what our USL and LSL are yet. For most of the k-factor analysis determinations fro sample size, you have to know mean (ok lets make that 15) but standard deviation as well (how can we know this if we haven't gathered the data)?
I feel its a cart before the horse problem but I'm sure I'm missing something really critical.
1) Essentially, how do I go into a pre-DV study to collect data that will give me a statistically significant result that I can use to set specifications?
2) If we have identified specifications through other testing (challenge, etc.), and lets say we DO set the spec at 15 N +/- 1 N, how do you set up a variable sample plan at a C/R interval of 95/90 or 95/95?
Thanks in advance!
it IS a cart before the horse dilemma...however the solution is fairly simple: guess - using good engineering judgment. what do you think it should be? what do you think it probalby will be. then take some data to see how close you are. sounds silly but it?s how it?s done in real life.
First I would not use the process data to set specs. specs should be based on function for the Customer. Using process capability to ?set specs? results in throwing away good material or shipping bad material...
IF you have real specs, then the sample size is based on the confidence level and precision you want in the standard deviation estimate. This will give you the sample size needed to estimate the standard deviation and determine if any values are beyond the specifications. Both numerically and from a distributional standpoint.
I use the following formulas to determine the appropriate sample size to estimate the standard deviation. They are based on calculating the confidence interval. The confidence interval is the precision of the estimate; the greater the precision (smaller confidence interval), the larger the sample size. The greater the confidence (1-alpha), the larger the sample size.
The variation in sample standard deviations tends to follow a ChiSquare distribution for the formulas for the confidence intervals are:
Lower Confidence Interval: sqrt([n-1]s^2/chi_1-alpha/2^2)
Upper Confidence Interval: sqrt([n-1]s^2/chi_alpha/2^2)
The confidence intervals are not symmetrical like they are with means.
IN EXCEL:
Lower Confidence Interval = s/SQRT(CHIINV((alpha/2),(n-1))/(n-1))
Upper Confidence Interval = s/SQRT(CHIINV((1-(alpha/2)),(n-1))/(n-1))
You are better served to use the upper interval than the lower interval.
You must have some estimate for the ?expected? true standard deviation. This is where you guess or take a small sample to estimate it. 30-50 should be sufficient.
I use the attached spreadsheet to iterate the formulas and visualize what choice I make.
The caution here is that many processes are NOT homogenous. They can still be in statistical and practical control but they may have lot to lot or raw material to raw material shifts. SO you should spread your tests out across the components of variation in your process?
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
V FDA 510K - Pre Submission Query US Food and Drug Administration (FDA) 6
L Notified Body submission - Pre-filled syringes EU Medical Device Regulations 2
Watchcat How are pre-subs going these days? Other US Medical Device Regulations 2
N Pre-Clinical Performance Testing Design and Development of Products and Processes 3
B How to submit Pre-submission to FDA? US Food and Drug Administration (FDA) 4
DuncanGibbons Pre FAI production terminology AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
leftoverture Pre-Launch vs Safe Launch IATF 16949 - Automotive Quality Systems Standard 15
M Pre-Sub preparation (for de Novo request) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
S Pre-Submission for Breakthrough Device Designation - What's the threshold? US Food and Drug Administration (FDA) 8
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
H Queries: RFD & Pre-RFD Program Medical Device and FDA Regulations and Standards News 0
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
D Pre-Submission after 510(K) Submission? Other US Medical Device Regulations 4
J Pre-clinical Studies for RUO Product Other Medical Device Regulations World-Wide 1
M Informational Health Canada guidance document – Pre-market Requirements for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
J Custom-made implants (Class IIb) and pre-commercialization clinical trials in Spain EU Medical Device Regulations 4
C Shipping Medical Devices to US before pre market clearance US Food and Drug Administration (FDA) 1
A UDI requirements for pre-filled combination devices - Box containing a pre-filled device US Food and Drug Administration (FDA) 2
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
D Redacted pre-submission bundle that you would be willing to share US Food and Drug Administration (FDA) 3
I Bench Testing & Pre-verification vs. Formal verification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D FDA Pre-Submission Meeting Advice US Food and Drug Administration (FDA) 0
M Medical Device News Health Canada – Consultation: Pre-market Requirements for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
L 510 (K) Pre-Sub meeting - Does it worth? US Food and Drug Administration (FDA) 4
A Examples of Pre-Sub, SRD, PMA Shells and Templates Other US Medical Device Regulations 3
B Manufacturing site relocation of pre amendment Class II medical device Manufacturing and Related Processes 4
A Users won't return devices from pre-CE performance evaluation study EU Medical Device Regulations 3
B GM GP-12 Pre-Launch - They asking for a I chart Statistical Analysis Tools, Techniques and SPC 2
GoSpeedRacer Pre-Work and Study for ISO 13485:2016 Lead Auditor Class ISO 13485:2016 - Medical Device Quality Management Systems 1
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
V Is 'Compliance' a pre-requisite or is it ok before Batch Release to Market? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 62
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
H Pre compliance test for Glucometer Other Medical Device and Orthopedic Related Topics 1
V Pre-dispensed API material received in predetermined quantities & given to production Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
somashekar Pre-Announced FDA 4 Day Inspection, Class 2 Devices, Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
Q FDA Consensus Standard for PMA (Pre-Market Approval) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Does anyone have experience providing a summary of Pre-IDE discussions in the 510k US Food and Drug Administration (FDA) 1
JoCam Format of Health Canada pre-market licence application Canada Medical Device Regulations 3
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V 510(K) Cyber Security Documentation for Pre-market Submission (Templates) Other US Medical Device Regulations 6
