Pre-Production Capability Assesment
Hi all.
I need some help with presenting some data I've retrieved.
I was asked for an SPC analysis and X-bar chart for the capabilities of our 5 axis machines based on pattern block test pieces (see photo attached)
I have constructed a report for the test piece however i don't see anyway of achieving what has been asked with no control measures in place and nothing to measure it against.
After asking the QM i have been instructed just to set an upper and lower limit of 0.1 and construct a line graph with the results however this gives me many graphs as opposed to the one graph they are after.
Could anyone offer any advice on how i can achieve the results they're after as i have hit a brick wall.
Proud Liberal
You can't do capability on one piece. They need to produce a sufficient quantity to have your sigma value be meaningful. A 30 piece sample would be the minimum I would consider.
A single line graph per feature is of value to evaluate stability but a histogram would point to a better understanding of the process (bi-modal, skewness, kurtosis, etc.).
If you have Minitab, a 6-pack capability analysis is the automotive industry standard for capability. If you can share the data, we can point you in the right direction as far as presentation goes.
Thankyou for replying so soon. The report may be a tad tricky to decipher, i'll work on presenting it a bit better shortly.
the end result i am trying to achieve is the average deviation about the 6 degrees of freedom I.e. average x axis, y axis, z axis then rotational about, each axis, to determine whether the machine is capable of producing the parts required and whether there is a trend in declining capability.
These blocks are being produced at a rate of 1 per week. and i have been requested to split the part into 8 quadrants for reporting.
In my mind this isn't sigma its a simple chart showing a risk analysis however after being told i need to produce SPC 3 sigma graphs ive become confused with whats required.
The other problem i've come across is that there could be an error in a positive x direction one side then an error in a negative direction the other side however the average then shows 0 error within that axis as i'm not allowed to present deviation as just a positive value from nominal.
Thankyou for your help
Proud Liberal
It sounds like the confusion rests with those making the request. At the rate of one per week, this is going to be a lengthy process (more than 6 months). I doubt that's what the QM wants. But based on what you've said, I don't think they really know what they want (distilling this information into a single chart is not a reasonable request). Before you go too far down any path, you need clarification on what the goal is.
The data shows that you are clearly NOT capable to the specifications listed when numerous features are measuring out of tolerance. If on the other hand, the goal is to determine what tolerances can be held, a short term study could be used for that purpose.
Also note, that breaking up the analysis of the sphere geometry into quadrants will impact the analysis. Reductions in the percent of feature measured will shift the means and increase the standard deviations of size and location measurements. You can easily demonstrate this by writing a program to repeatedly measure the CMM's reference sphere (calibration ball) using decreasing % of feature.
Another thing to consider is how the data is being collected. Are you taking discreet points or scanning?
After speaking with the QM i have been told just to put it into line graphs with +/- 0.1 limits and go from there. I would agree that they are unsure as to what asked because as soon as i mention standard deviation or Cp/Cpk i get a blank response.
The part is measured using discreet points on the CMM, no scanning.
Could you advise on another short term study i could use that might be of some use for determining machine tolerances? my main concern with the data i've collected is that with no control log to restrict tool length, size etc, the data means nothing.
Thankyou again
toniriazor
Where did these limits came from ? Reading above it seems you into a big mess. +/- 0.1 limits is the control limit or product LSL/USL ? Before you move forward the goal and direction must be clear.
I Reason for pre-production machine/process capability studies / SPC during production Capability, Accuracy and Stability - Processes, Machines, etc. 3
DuncanGibbons Pre FAI production terminology AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
V Pre-dispensed API material received in predetermined quantities & given to production Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
W Process of Pre-Production under Mass Production Conditions IATF 16949 - Automotive Quality Systems Standard 6
N Applying FMEA to all Pre-Production Processes FMEA and Control Plans 5
A Pre Production Parts Sampling for Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q How Many Control Plans Needed? Prototype, Pre-launch and Production? FMEA and Control Plans 3
N Pre-Clinical Performance Testing Design and Development of Products and Processes 3
B How to submit Pre-submission to FDA? US Food and Drug Administration (FDA) 4
leftoverture Pre-Launch vs Safe Launch IATF 16949 - Automotive Quality Systems Standard 15
M Pre-Sub preparation (for de Novo request) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
S Pre-Submission for Breakthrough Device Designation - What's the threshold? US Food and Drug Administration (FDA) 8
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
H Queries: RFD & Pre-RFD Program Medical Device and FDA Regulations and Standards News 0
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
D Pre-Submission after 510(K) Submission? Other US Medical Device Regulations 4
J Pre-clinical Studies for RUO Product Other Medical Device Regulations World-Wide 1
M Informational Health Canada guidance document – Pre-market Requirements for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
J Custom-made implants (Class IIb) and pre-commercialization clinical trials in Spain EU Medical Device Regulations 4
C Shipping Medical Devices to US before pre market clearance US Food and Drug Administration (FDA) 1
A UDI requirements for pre-filled combination devices - Box containing a pre-filled device US Food and Drug Administration (FDA) 2
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
D Redacted pre-submission bundle that you would be willing to share US Food and Drug Administration (FDA) 3
I Bench Testing & Pre-verification vs. Formal verification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D FDA Pre-Submission Meeting Advice US Food and Drug Administration (FDA) 0
M Medical Device News Health Canada – Consultation: Pre-market Requirements for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
L 510 (K) Pre-Sub meeting - Does it worth? US Food and Drug Administration (FDA) 4
A Examples of Pre-Sub, SRD, PMA Shells and Templates Other US Medical Device Regulations 3
B Manufacturing site relocation of pre amendment Class II medical device Manufacturing and Related Processes 4
A Users won't return devices from pre-CE performance evaluation study EU Medical Device Regulations 3
B GM GP-12 Pre-Launch - They asking for a I chart Statistical Analysis Tools, Techniques and SPC 2
GoSpeedRacer Pre-Work and Study for ISO 13485:2016 Lead Auditor Class ISO 13485:2016 - Medical Device Quality Management Systems 1
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
V Is 'Compliance' a pre-requisite or is it ok before Batch Release to Market? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 47
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
H Pre compliance test for Glucometer Other Medical Device and Orthopedic Related Topics 1
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
somashekar Pre-Announced FDA 4 Day Inspection, Class 2 Devices, Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
Q FDA Consensus Standard for PMA (Pre-Market Approval) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Does anyone have experience providing a summary of Pre-IDE discussions in the 510k US Food and Drug Administration (FDA) 1
JoCam Format of Health Canada pre-market licence application Canada Medical Device Regulations 3
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
