Precision Balance Verification and Calibration Process
Dongzkie
Equipment's specification Max 820g with a readability of 0.01g
Process : BareWire GramWeight, Min:2.947 Max:56.96
Test Weights Available:
50g(1pc),20g(2pcs),5g(1pc),10g(1pc),2g(2pcs),1g(1pc)
2mg(1),20mg(2),10mg(1),50mg(1),100mg(1),200mg(1),500mg(1)
500g(1) and 200g(2) <<<<< Expired External Calibration Certificate
Questions:
1. What is the correct test weights do i use during my verification or calibration with regards to the Process
2. Can I use a test weights with an expired calibration certificate as a dummy load?
Thank you very much :rolleyes:
BradM
Questions:
Hi there!:bigwave:
1. What is the correct test weights do i use during my verification or calibration with regards to the Process?
There are lots of approaches and philosophies on points to check equipment. But generally, one wants to check across the use range. So for this balance, I might be tempted to check at 10, 25, 50, 75, and 90%, minimally. However, it all depends on how you intend on using the balance. If say you weigh a lot of product at 20grams, then you would want to verify the balance at that point.
What would you need a dummy load for? What would be the purpose? Saying anything you put on the balance to ascertain any error in the balance, I would assure it has been calibrated by a competent vendor. You want to assure your mass standards aren't gaining/losing significantly.
:topic:
Do you have a procedure on how to calibrate the balances? If you have not generated one, I would start working on that. If you have not purchased it, Handbook 44 would be a great start. You can base your practices and such on it, but I would write your own. That way, it will be more applicable for your operation, and be much shorter. :D
Be sure to include handling the weights, how to move the balances, estimating uncertainty, remedial action (if one is out of tolerance), etc. :agree1:
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
K Inter/Intra assay precision study per CLSI guidelines Statistical Analysis Tools, Techniques and SPC 1
V Selecting System Precision Criteria - System Suitability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
Proud Liberal Turnover Rates in Precision Machining Benchmarking 5
H How Calibration Precision checks are implemented in medical device companies General Measurement Device and Calibration Topics 2
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
M How to provide Stability Study for micron-precision tool Misc. Quality Assurance and Business Systems Related Topics 2
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
L Requirements for employees personal precision measuring tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Precision Testing for RA (Rheumatoid Arthritis) Kits US Food and Drug Administration (FDA) 1
H Accuracy and Precision of Test Equipment required? General Measurement Device and Calibration Topics 2
G Issues with Time needed for Measurement of High Precision Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Precision Machining Supplier Audit Format/Template wanted Manufacturing and Related Processes 9
B Precision Machining and Compressed Control Limits Capability, Accuracy and Stability - Processes, Machines, etc. 13
V Validation of Washing and Degreasing (Solvent Washer) for Precision Machine Parts Design and Development of Products and Processes 9
W What standard should I be using? Precision milled & turned metal products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Precision of REPRORUBBER - What is the 'smallest' that reprorubber can discriminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
bobdoering SPC for Precision Machining Presentation March 25, 2010 ASQ Central Kentucky Section ASQ - American Society for Quality 1
B Minitab v15 Precision to Tolerance does not compute? Using Minitab Software 1
E Precision Instruments Calibration Instructions General Measurement Device and Calibration Topics 4
U Introduction of SPC - Embarking on my first implementation for precision machining Statistical Analysis Tools, Techniques and SPC 11
bobdoering Statistical process control for precision machining - Sample Data Imported Legacy Blogs 3
bobdoering Statistical Process Control for Precision Machining Video Training Course Imported Legacy Blogs 0
bobdoering Definition Precision Machining - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
bobdoering Statistical process control for precision machining - Part 3 - Sampling Error Imported Legacy Blogs 0
L Small Precision Parts for Aerospace and Medical Devices - Inspection Procedures Document Control Systems, Procedures, Forms and Templates 4
E Is ISO 13485 compulsory - Fabrication of precision metal parts for medical industry? ISO 13485:2016 - Medical Device Quality Management Systems 17
bobdoering SPC for Precision Machining - ASQ Presentation Imported Legacy Blogs 0
B Legacy products in an AS9100 QMS precision machining job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Definition Precision and Accuracy - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
H Bob's Statistical process control for precision machining Statistical Analysis Tools, Techniques and SPC 1
bobdoering Statistical Process Control for Precision Machining - Part 2 Imported Legacy Blogs 0
bobdoering Statistical Process Control for Precision Machining - Part 1 Imported Legacy Blogs 25
S Work Instructions Required? Precision metal stamping, cnc machining and wire edm Document Control Systems, Procedures, Forms and Templates 7
S Should we consider Precision of Machine Reading when setting Inspection Specs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Measurement Uncertainty (MU), Accuracy, Precision - Relationship? Measurement Uncertainty (MU) 6
L Precision tool storage such as micrometers and calipers? General Measurement Device and Calibration Topics 5
S P/T (Precision/Tolerance) ratio for off-center processes? Process capability ratio? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Statistical Steven Accuracy vs. Precision - What is more important for Process Capability Statistical Analysis Tools, Techniques and SPC 55
L Expressing fractions as decimals - Indicators on older or lower precision instruments General Measurement Device and Calibration Topics 7
J CFR Title 21 820.72.b Calibration Procedure Accuracy and Precision Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Precision/Tolerance Ratio for 1-sided Specification - How to Compute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course General Measurement Device and Calibration Topics 1
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course Professional Certifications and Degrees 10
H Hoeyster QM - Goal: Eliminate "Final Inspection" - Aerospace precision machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
