Definition Precision Machining - Definition
bobdoering
Stop X-bar/R Madness!!
Precision Machining - a process where material is removed by a cutting surface, such as grinding, honing, turning, milling, etc. The process must be controlled in a manner that all variation (vibration, bearings, measurement error, etc.) is statistically insignificant except for tool wear.
Wes Bucey
Well, OK, as far as it goes. I would have included lasers and electric arc discharge machines, too. Maybe even water jet cutting as well.
Frankly, I think the definition of precision machining is not so much about the devices used to remove material from stock (essentially, either the material moves against the cutting device or the cutting device moves against the material) as it is about the precision of the tolerances which are held in the process. Sometimes, of course, the Control Plan for precision machining factors in the tool wear and the tool undergoes regular adjustment throughout the production cycle to maintain the tight tolerances (which may seem blasphemous to folks who live by SPC, Cpk, and the other alphabet soups of reporting whether a process is under control.)
What do you say, Bob?
Big Jim
There are those that would argue that "precision" machining only applies when the tolerances are less than 10 thousands of an inch. If the tolerance is measured in thousands of an inch it is just machining.
I'm not claiming that this is my definition though.
bobdoering
Well, looks like we can have a lively conversation about this!
First - precision: If we define precision by the tightness of the tolerance, in 1930 precision may have been a tolerance of .1", while today it could be .0005" - or whatever target it may be. Therefore, it would be a moving target that would be hard to define, depending on the processes of the day. Which is my point, I am focusing on that the process that is precision, not the result.
Second - machining: I think wire EDM, laser and waterjet are dumped into the "machining" bucket because the result of the process is similar to the mechanical cutting devices - but they do not exhibit tool wear. They may be better suited for another category. Electrodischarge grinding may behave like precision machining. I did not have a chance to work with it long enough to determine if the wheel does decay like plunge EDM electrodes, in which case its behavior would be consistent witht he definition.
I think that some of the essence of this discussion is in the fact that the short term capability (less tool wear) of a precision machining process is extremely high relative to what ever the tolerance may be. The short term variation of the process (less tool wear may in fact be normally distributed. However, for perfectly valid, economical reasons, a decision is made to allow variation from tool wear to enter the picture over a longer term.
This decision should be based on whether a part anywhere within the tolerance is equally acceptable to another part elsewhere in the tolerance. Assuming these are all economically and practically valid reasons, the end result is a short term, normal (or skewed, or etc.) distribution that is deliberately allowed to drift with tool wear to predetermined limits whereupon it is adjusted to the other decision limit.
The long term effect of this is a pseudo-uniform distribution. I use the term pseudo-uniform because unlike a true uniform distribution that has vertical tails, this distribution will have tails that reflect the underlying short term distribution. These tails may not be large from a practical view, but they do exist.
In short, precision machining has extremely high short term capability that is allowed to drift according to tool wear then adjusted resulting in a sawtooth pattern.
bobdoering
I am not sure how one can eliminate tool wear from the machining process consideration. It is the process. As far as precision machining capability, it really has no difference between the short term and long term capability, the capability is always (USL-LSL)/(UCL-LCL) based on the uniform distribution. Theoretically, there are no 'tails', but in practice, thanks to total variation, sum of the lesser variations, such as the inability to hit the control limits exactly , measurement error, etc. - some of the lesser variations are normal and will contribute 'tails', the overall composite distribution will have some tails. That is why the recommended control limits are 75% of the tolerance to allow for that.
Wes Bucey
Yep. In 1999, my shop had machines that could routinely hold 0.000050 (50 millionths of an inch.) When I told this to my then 90-year old great uncle, who had been a machinist during WWII, his first comment was, "How do you even measure 50 millionths of an inch?"
He hadn't been inside a machine shop for 30 years - when I brought him a little titanium doodad (cup-shaped, looking somewhat like a bullet casing he made in the 40s) our shop made for a satellite which we shaped on a Swiss turning center, heat-treated, had a small bridge cut out of the bottom with an electric arc discharge machine, then electropolished to a mirror finish, he was absolutely flabbergasted. He simply couldn't grasp the change in machinery from the Browne & Sharpe lathes, Model B Davenports, etc. of his day in terms of accuracy, stability, precision.
Wes Bucey
<SNIP>
As the professor in "My Fair Lady" says,
"By Jove, I think he's got it!"
Good job, Miner!:applause:
How do you hold .00005 when you're electropolishing?
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
Proud Liberal Turnover Rates in Precision Machining Benchmarking 5
M Precision Machining Supplier Audit Format/Template wanted Manufacturing and Related Processes 9
B Precision Machining and Compressed Control Limits Capability, Accuracy and Stability - Processes, Machines, etc. 13
bobdoering SPC for Precision Machining Presentation March 25, 2010 ASQ Central Kentucky Section ASQ - American Society for Quality 1
U Introduction of SPC - Embarking on my first implementation for precision machining Statistical Analysis Tools, Techniques and SPC 11
bobdoering Statistical process control for precision machining - Sample Data Imported Legacy Blogs 3
bobdoering Statistical Process Control for Precision Machining Video Training Course Imported Legacy Blogs 0
bobdoering Statistical process control for precision machining - Part 3 - Sampling Error Imported Legacy Blogs 0
bobdoering SPC for Precision Machining - ASQ Presentation Imported Legacy Blogs 0
B Legacy products in an AS9100 QMS precision machining job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H Bob's Statistical process control for precision machining Statistical Analysis Tools, Techniques and SPC 1
bobdoering Statistical Process Control for Precision Machining - Part 2 Imported Legacy Blogs 0
bobdoering Statistical Process Control for Precision Machining - Part 1 Imported Legacy Blogs 25
S Work Instructions Required? Precision metal stamping, cnc machining and wire edm Document Control Systems, Procedures, Forms and Templates 7
H Hoeyster QM - Goal: Eliminate "Final Inspection" - Aerospace precision machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Inter/Intra assay precision study per CLSI guidelines Statistical Analysis Tools, Techniques and SPC 1
V Selecting System Precision Criteria - System Suitability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
H How Calibration Precision checks are implemented in medical device companies General Measurement Device and Calibration Topics 2
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
M How to provide Stability Study for micron-precision tool Misc. Quality Assurance and Business Systems Related Topics 2
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
L Requirements for employees personal precision measuring tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Precision Testing for RA (Rheumatoid Arthritis) Kits US Food and Drug Administration (FDA) 1
H Accuracy and Precision of Test Equipment required? General Measurement Device and Calibration Topics 2
G Issues with Time needed for Measurement of High Precision Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
V Validation of Washing and Degreasing (Solvent Washer) for Precision Machine Parts Design and Development of Products and Processes 9
W What standard should I be using? Precision milled & turned metal products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Precision of REPRORUBBER - What is the 'smallest' that reprorubber can discriminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Precision Balance Verification and Calibration Process General Measurement Device and Calibration Topics 3
B Minitab v15 Precision to Tolerance does not compute? Using Minitab Software 1
E Precision Instruments Calibration Instructions General Measurement Device and Calibration Topics 4
L Small Precision Parts for Aerospace and Medical Devices - Inspection Procedures Document Control Systems, Procedures, Forms and Templates 4
E Is ISO 13485 compulsory - Fabrication of precision metal parts for medical industry? ISO 13485:2016 - Medical Device Quality Management Systems 17
V Definition Precision and Accuracy - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
S Should we consider Precision of Machine Reading when setting Inspection Specs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Measurement Uncertainty (MU), Accuracy, Precision - Relationship? Measurement Uncertainty (MU) 6
L Precision tool storage such as micrometers and calipers? General Measurement Device and Calibration Topics 5
S P/T (Precision/Tolerance) ratio for off-center processes? Process capability ratio? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Statistical Steven Accuracy vs. Precision - What is more important for Process Capability Statistical Analysis Tools, Techniques and SPC 55
L Expressing fractions as decimals - Indicators on older or lower precision instruments General Measurement Device and Calibration Topics 7
J CFR Title 21 820.72.b Calibration Procedure Accuracy and Precision Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Precision/Tolerance Ratio for 1-sided Specification - How to Compute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course General Measurement Device and Calibration Topics 1
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course Professional Certifications and Degrees 10
