Definition Precision Machining - Definition
Big Jim
#11
Well, looks like we can have a lively conversation about this!
First - precision: If we define precision by the tightness of the tolerance, in 1930 precision may have been a tolerance of .1", while today it could be .0005" - or whatever target it may be. Therefore, it would be a moving target that would be hard to define, depending on the processes of the day. Which is my point, I am focusing on that the process that is precision, not the result.
Second - machining: I think wire EDM, laser and waterjet are dumped into the "machining" bucket because the result of the process is similar to the mechanical cutting devices - but they do not exhibit tool wear. They may be better suited for another category. Electrodischarge grinding may behave like precision machining. I did not have a chance to work with it long enough to determine if the wheel does decay like plunge EDM electrodes, in which case its behavior would be consistent witht he definition.
Perhaps "chemical milling" should be added to the list too, particularly in the making of micro-miniture parts through photo etching. No parts to wear, but resulting parts are very precise (and tiny).
bobdoering
Stop X-bar/R Madness!!
#12
I agree, this too is a precision process, but should it be "machining" if there is no tool and no tool wear involved - or is it another category altogether (along with laser, et. al.)?
#13
It's an interesting question. I think the language hasn't caught up with technology, or there's no need for more specificity. In general, we think of "machining," in its simplest form, as strictly an erosive or abrasive material removal process, as opposed to something like stamping which (in addition to removing material in some cases) forms the metal into a specified shape. For your purposes of accentuating the proper SPC methods, perhaps it would be best to say, "machining (the adjective "precision" is redundant, I think) with perishable tooling." That's quite a mouthful, but at least the distinction is preserved.
bobdoering
#14
I do not think that precision is redundant, in that you can have sloppy machining processes, where there is sufficient variation to mask the tool wear (bad bearings, sloppy ways, etc.). It may not matter, if your specifications are wide open. So, the precision portion of the definition infers the portion of the definition " all variation is statistically insignificant except for tool wear."
Yes, it sure doesn't roll of the tongue, but it has good specificity. :agree1:
#15
It sounds like tautology to me:
Q: How do you know it's precision machining?
A: You have to use the uniform distribution, because the normal distribution is misleading.
Q: How do you know when to use the uniform distribution?
A: You use it when you're doing precision machining.
If you don't want "precision" to be redundant in the phrase "precision machining," you need a definition that doesn't go in circles.
bobdoering
#16
I think you missed some steps - it is more like this:
Q: What is precision machining?
A: A machining process the only statistically significant variation is tool wear.
Q: How do you control a process where the only statistically significant variation is tool wear?
A: You start at one control limit, and allow the dimension to vary to the opposite control limit, then reset. For outer dimensions, start at the lower control limit, for inner dimensions, start at the upper control limit.
Q: What is the resulting curve for the process?
A: The sawtooth curve.
Q:What is the distribution for the sawtooth curve?
A: The continuous uniform distribution.
Does not seem that circular to me.
Conversely,
Q: What is not precision machining?
A: A machining process where the most significant variation is not tool wear, such as vibration, worn bearing, manual operation, etc.
Q: How do you 'control' a process where the statistically significant variation is not tool wear?
A: You can only adjust to the target value when the value exceeds a control limit as the process randomly varies about it.
A: Random variation about the target.
Q:What is the distribution?
A: The normal distribution.
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
Proud Liberal Turnover Rates in Precision Machining Benchmarking 5
M Precision Machining Supplier Audit Format/Template wanted Manufacturing and Related Processes 9
B Precision Machining and Compressed Control Limits Capability, Accuracy and Stability - Processes, Machines, etc. 13
bobdoering SPC for Precision Machining Presentation March 25, 2010 ASQ Central Kentucky Section ASQ - American Society for Quality 1
U Introduction of SPC - Embarking on my first implementation for precision machining Statistical Analysis Tools, Techniques and SPC 11
bobdoering Statistical process control for precision machining - Sample Data Imported Legacy Blogs 3
bobdoering Statistical Process Control for Precision Machining Video Training Course Imported Legacy Blogs 0
bobdoering Statistical process control for precision machining - Part 3 - Sampling Error Imported Legacy Blogs 0
bobdoering SPC for Precision Machining - ASQ Presentation Imported Legacy Blogs 0
B Legacy products in an AS9100 QMS precision machining job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H Bob's Statistical process control for precision machining Statistical Analysis Tools, Techniques and SPC 1
bobdoering Statistical Process Control for Precision Machining - Part 2 Imported Legacy Blogs 0
bobdoering Statistical Process Control for Precision Machining - Part 1 Imported Legacy Blogs 25
S Work Instructions Required? Precision metal stamping, cnc machining and wire edm Document Control Systems, Procedures, Forms and Templates 7
H Hoeyster QM - Goal: Eliminate "Final Inspection" - Aerospace precision machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Inter/Intra assay precision study per CLSI guidelines Statistical Analysis Tools, Techniques and SPC 1
V Selecting System Precision Criteria - System Suitability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
H How Calibration Precision checks are implemented in medical device companies General Measurement Device and Calibration Topics 2
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
M How to provide Stability Study for micron-precision tool Misc. Quality Assurance and Business Systems Related Topics 2
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
L Requirements for employees personal precision measuring tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Precision Testing for RA (Rheumatoid Arthritis) Kits US Food and Drug Administration (FDA) 1
H Accuracy and Precision of Test Equipment required? General Measurement Device and Calibration Topics 2
G Issues with Time needed for Measurement of High Precision Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
V Validation of Washing and Degreasing (Solvent Washer) for Precision Machine Parts Design and Development of Products and Processes 9
W What standard should I be using? Precision milled & turned metal products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Precision of REPRORUBBER - What is the 'smallest' that reprorubber can discriminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Precision Balance Verification and Calibration Process General Measurement Device and Calibration Topics 3
B Minitab v15 Precision to Tolerance does not compute? Using Minitab Software 1
E Precision Instruments Calibration Instructions General Measurement Device and Calibration Topics 4
L Small Precision Parts for Aerospace and Medical Devices - Inspection Procedures Document Control Systems, Procedures, Forms and Templates 4
E Is ISO 13485 compulsory - Fabrication of precision metal parts for medical industry? ISO 13485:2016 - Medical Device Quality Management Systems 17
V Definition Precision and Accuracy - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
S Should we consider Precision of Machine Reading when setting Inspection Specs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Measurement Uncertainty (MU), Accuracy, Precision - Relationship? Measurement Uncertainty (MU) 6
L Precision tool storage such as micrometers and calipers? General Measurement Device and Calibration Topics 5
S P/T (Precision/Tolerance) ratio for off-center processes? Process capability ratio? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Statistical Steven Accuracy vs. Precision - What is more important for Process Capability Statistical Analysis Tools, Techniques and SPC 55
L Expressing fractions as decimals - Indicators on older or lower precision instruments General Measurement Device and Calibration Topics 7
J CFR Title 21 820.72.b Calibration Procedure Accuracy and Precision Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Precision/Tolerance Ratio for 1-sided Specification - How to Compute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course General Measurement Device and Calibration Topics 1
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course Professional Certifications and Degrees 10
