Precision of REPRORUBBER - What is the 'smallest' that reprorubber can discriminate
Jeenan
Hi, the question might sound weird,
But we try to find a method to measure part with hard to reach corner....and of course with tight tolerance....
The actual question is what is the 'smallest' that reprorubber can discrimine
Can it see .005", .001", .0005", .0001"....etc
Of course we will look at the reprorubber on an Optical Comparator
:thanx:
Re: Precision of REPRORUBBER
If you're using the branded reprorubber, there are some dimensional stability and deformation numbers here. Your own results may vary, of course. You also have to remember that the method is limited to approximation by definition, because the rubber compound and the surfaces of the part can't occupy the same plane(s) at the same time, just as you can't get a .050" gage pin into a .050" hole. The reprorubber model will always be slightly smaller than the part geometry. In most cases that difference will be negligible, but if you're concerned about it you would be better off knowing the size of the mating part, because that's what you're actually modeling.
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
K Inter/Intra assay precision study per CLSI guidelines Statistical Analysis Tools, Techniques and SPC 1
V Selecting System Precision Criteria - System Suitability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
Proud Liberal Turnover Rates in Precision Machining Benchmarking 5
H How Calibration Precision checks are implemented in medical device companies General Measurement Device and Calibration Topics 2
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
M How to provide Stability Study for micron-precision tool Misc. Quality Assurance and Business Systems Related Topics 2
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
L Requirements for employees personal precision measuring tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Precision Testing for RA (Rheumatoid Arthritis) Kits US Food and Drug Administration (FDA) 1
H Accuracy and Precision of Test Equipment required? General Measurement Device and Calibration Topics 2
G Issues with Time needed for Measurement of High Precision Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Precision Machining Supplier Audit Format/Template wanted Manufacturing and Related Processes 9
B Precision Machining and Compressed Control Limits Capability, Accuracy and Stability - Processes, Machines, etc. 13
V Validation of Washing and Degreasing (Solvent Washer) for Precision Machine Parts Design and Development of Products and Processes 9
W What standard should I be using? Precision milled & turned metal products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Precision Balance Verification and Calibration Process General Measurement Device and Calibration Topics 3
bobdoering SPC for Precision Machining Presentation March 25, 2010 ASQ Central Kentucky Section ASQ - American Society for Quality 1
B Minitab v15 Precision to Tolerance does not compute? Using Minitab Software 1
E Precision Instruments Calibration Instructions General Measurement Device and Calibration Topics 4
U Introduction of SPC - Embarking on my first implementation for precision machining Statistical Analysis Tools, Techniques and SPC 11
bobdoering Statistical process control for precision machining - Sample Data Imported Legacy Blogs 3
bobdoering Statistical Process Control for Precision Machining Video Training Course Imported Legacy Blogs 0
bobdoering Definition Precision Machining - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
bobdoering Statistical process control for precision machining - Part 3 - Sampling Error Imported Legacy Blogs 0
L Small Precision Parts for Aerospace and Medical Devices - Inspection Procedures Document Control Systems, Procedures, Forms and Templates 4
E Is ISO 13485 compulsory - Fabrication of precision metal parts for medical industry? ISO 13485:2016 - Medical Device Quality Management Systems 17
bobdoering SPC for Precision Machining - ASQ Presentation Imported Legacy Blogs 0
B Legacy products in an AS9100 QMS precision machining job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Definition Precision and Accuracy - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
H Bob's Statistical process control for precision machining Statistical Analysis Tools, Techniques and SPC 1
bobdoering Statistical Process Control for Precision Machining - Part 2 Imported Legacy Blogs 0
bobdoering Statistical Process Control for Precision Machining - Part 1 Imported Legacy Blogs 25
S Work Instructions Required? Precision metal stamping, cnc machining and wire edm Document Control Systems, Procedures, Forms and Templates 7
S Should we consider Precision of Machine Reading when setting Inspection Specs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Measurement Uncertainty (MU), Accuracy, Precision - Relationship? Measurement Uncertainty (MU) 6
L Precision tool storage such as micrometers and calipers? General Measurement Device and Calibration Topics 5
S P/T (Precision/Tolerance) ratio for off-center processes? Process capability ratio? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Statistical Steven Accuracy vs. Precision - What is more important for Process Capability Statistical Analysis Tools, Techniques and SPC 55
L Expressing fractions as decimals - Indicators on older or lower precision instruments General Measurement Device and Calibration Topics 7
J CFR Title 21 820.72.b Calibration Procedure Accuracy and Precision Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Precision/Tolerance Ratio for 1-sided Specification - How to Compute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course General Measurement Device and Calibration Topics 1
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course Professional Certifications and Degrees 10
H Hoeyster QM - Goal: Eliminate "Final Inspection" - Aerospace precision machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
