Predicting Machined Components Capability based on Historical Data of Similar Parts
E
Edwards_CNC
Recently I?ve been working on an Excel model to predict capability of machined components based on historical data of similar parts. This is in an attempt to move away from fixed targets in our product commercialisation process.
Some background stuff
? Previous New Product Introduction (NPI) projects employed hard targets/goals for machining capability, such as - 1.33 Cpk or 4 Sigma / 95% yield, which in some cases were not achievable in the time-frame or technology available
? The acceptance criteria needs to be agreed using historical analysis and balanced with commercial viability.
? Ensuring capability figures are managed pragmatically and kept flexible presents the following advantages:
? More focus can be given to critical features/tolerances.
? A strengthened relationship is created between NPI and Operations.
? Manufacturing Readiness (MR) deliverables can be agreed to suit business requirements.
? Use of historic data allows us to understand & improve upon past errors.
? Flexible approach provides the ability to predict capability results for any future changes.
To this end, I would like to undertake a peer review of the capability gap analysis model with some (well regarded) external contacts that may find this sort of work interesting and may be able to utilise the framework within their own roles. The model has been created to predict capability and yield % and provide a meaningful metric for future projects but could easily be adapted for processes other than machining. Attached is the model that I have created for one of our most recent product commercialisation projects.
Please start by visiting the ?Read me? tab on the model before reviewing the sheet.
Any comments or feedback will be welcomed. If you have any questions, then please don?t hesitate to contact me. Feel free to use this model and adapt it for you own needs if you so wish, with the normal accreditations.
Please note, that currently this model is only intended to predict adverse scenarios and will not predict improved capability or yield based upon tolerance trade-off?s or other favourable process improvements. This will be a consideration for future versions
bobdoering
Stop X-bar/R Madness!!
Re: Predicting Machined Components Capability based on Historical Data of Similar Par
I took a quick look at the chart, and the some characteristics listed for capability are controversial themselves - unilateral tolerances with physical limits (such as Curve Forms, True Positions and Surface Finishes). On top of that, if any of these characteristics are generated using precision machining, you should not even be looking at Cpk or Ppk, proper statistical control is a constant. So, this will take some time to fully review.
Marc Predicting COVID-19 Aspects - Pandemic Modeling (Easter 2020) Coffee Break and Water Cooler Discussions 11
Z Predicting External PPM Capability from Internal PPM Capability, Accuracy and Stability - Processes, Machines, etc. 1
Marc Predicting the Future through 19th Century French Post Cards Coffee Break and Water Cooler Discussions 1
Hami812 Predicting the outcome using high No Trouble Found Rate Statistical Analysis Tools, Techniques and SPC 4
N Using Regression Analysis in Excel - Predicting a Value Statistical Analysis Tools, Techniques and SPC 30
Q Reliability Prediction - Predicting the Reliability of an Inductor (Semi-conductor) Reliability Analysis - Predictions, Testing and Standards 8
Marc Predicting the Internet in 1995 After Work and Weekend Discussion Topics 0
C Statistical technique sought for predicting replacement of perishable tooling Statistical Analysis Tools, Techniques and SPC 14
T Corrosion in Bores after Zinc Plating machined Iron Castings in VCI Bags Manufacturing and Related Processes 1
Ron Rompen 2D matrix issue - Parts (machined steel) returned from the customer Design and Development of Products and Processes 0
C O-Ring Groove Measurement Method in CNC Machined Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
KyloDen Checking Threads - Discrepancy in threads that are machined In-House vs. Outsourced General Measurement Device and Calibration Topics 11
Ron Rompen Sintered Metal Machined Parts Rust Removal Methods Manufacturing and Related Processes 8
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Is there any specific Standard on visual defects for extrusion and machined parts ? Quality Tools, Improvement and Analysis 6
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
M Masking Machined Parts without using MEK (Methyl Ethyl Ketone) Manufacturing and Related Processes 5
P Surface Finish measurement for machined (finished) component/part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Visual Acceptance test for machined and vapor polished polycarbonate parts Other Medical Device and Orthopedic Related Topics 1
P AS9100 and Final Inspection of Machined Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Measuring a shallow OD of a Machined Ring/Groove Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
W Are Purchased Machined Components an "Outsourced Process"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Is 100% Inspected Lot of Machined Parts requires Cp > 1.67 Misc. Quality Assurance and Business Systems Related Topics 15
E Help with PPAP Level 3 for a small company! Machined parts APQP and PPAP 5
C Machined Parts PFMEA - Example of a CNC produced part PFMEA wanted FMEA and Control Plans 1
U Variables Control Chart options - Tightly toleranced machined components Statistical Analysis Tools, Techniques and SPC 1
R Hand tool to measure angles that has been machined into stock Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q FAI Help - Subcontracting out all manufactured items (PCB & machined parts) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M How clean is clean and how do you know? Small machined aluminum part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A Sampling Method for CNC Machined Products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
ScottK Surface Finish on machined brass (or other metals)- Attribute or Variable inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Calibration required? We buy part of our machined parts - Supplier gage calibration? General Measurement Device and Calibration Topics 6
S Soldering in stainless steel machined part Manufacturing and Related Processes 7
B Sharp Edge Measurement - Method of measuring how sharp the edge of a machined part is Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Example - PFMEA for Machined Parts on CNC Mills & Lathes FMEA and Control Plans 3
S Identification of Machined Products between Processes - Solution Needed. Manufacturing and Related Processes 7
ScottK Detecting non-visible defects in machined brass - Where to start? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
R PPAP from Customer for Customer Supplied Product - Material to be machined APQP and PPAP 2
D Is it acceptable to use a checklist for inspection of machined parts from supplier? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T SPC and GD&T - Machined parts - Is Cpk is the correct index? Capability, Accuracy and Stability - Processes, Machines, etc. 30
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
U Procedure pack components EU Medical Device Regulations 3
T Sterilized components expiration date ISO 13485:2016 - Medical Device Quality Management Systems 1
T Sterilized components shelf life Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
C Warehousing two separate components to a finished device while meeting regulations Other US Medical Device Regulations 7
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 12
