Predictive Maintenance Data Collection
melissaflora
What specific data do I use to figure out predictive maintenance? The company I work for mainly supplies steel coils to automotive production facilities. The only true production we do is robotic welding and very little of that. Does anyone have a checklist or a data sheet I could use or any suggestions. I am in the middle of trying to get TS certified and this has me stumped.:(
Q
Quality-Geek
What equipment do you have? (I'm guessing coilers...we buy steel coils and make automotive parts). Does any of the equipment have manuals that state what maintenance needs to be done, and the frequency? Are there people who check certain parts of the equipment each shift, day, week, month? What are they looking at?
Who is responsible for the building and facilities? What is done to maintain all that and reduce repair costs...lilke roof leaks, wiring, plumbing, HVAC, etc. These could be part of hte PM program as well. Hope this helps!
Bekki
The Specialist
The first port of call will be your equipment O+M manuals.
You could use an FMECA process for determining planned preventative maintenance.
You can also apply experience from past break-down and repairs.
qusys
ISO TS 16949 requires to perform studies and analysis for predictive maintenance.
In the predictive maintenance you should usually study analysis of vibration of a motors, viscosity of oil, thermography etc. Based upon the data collection and analysis, you can search room for maintenance improvement ( effectiveness and efficiency parameter), trying to "predict" when a failure occurs . Based upon these studies you can think to enlarge the time frame of a maintenance, trying to be more efficient. :bigwave:
X
xpcids
do we need to continuous study/analysis? or just 1 time analysis then we get result and put it into maintenace plan/preventive maintenance plan??
qusys
Hi xpcids,
Clause 7.5.1.4 of ISO TS says that the organization shall utilize methods of predictive maintenace to pursue continuos improvement of the effectiveness and the efficiency of the production equipment.
For example, if you have a static situation of your production equipment as well facilities equipment ones, it is ok a one shot analysis and include it in your maintenance plan.
If there are new situation ( change of the production, for example) or new equipment introduction, you shall consider the analysis of predictive maintenance as a dynamic process.
The suggestion could be the one to formalize the maintenance process with process mapping or a general procedure ( even if this document is not mandatory for ISO TS) to have a clear picture of how to proceed in the entire organization. Consider to have a multidisciplinary approach to do so and set KPI for this key process. Hope this helps
see you:bigwave:
qusys
Clearly process FMEA could be useful too in thsi process. The organization could also implement some predictive maintenances and put them in control plan to contribute to increase detection and avoid a potential risk for the production:bigwave:
JOYLYN ARELLANO
Predictive Maintenance Requirement
Could I ask to somebody who can share with me any predictive maintenance program or activity & procedure sample ?
Our company had passed 1st certification audit of ISO/TS 16949 but we had minor NC for Predictive Maintenance requirement because as per 3rd party Auditor ,we're focused on preventive maintenance.
Our Machine & Equipment type are Press Machine,Generator,Heater and Plastic Molding Injection Machine.
Please help me on this..
Joylyn
K Monitoring Tool Wear for Predictive Maintenance - Data evaluation methodogy IATF 16949 - Automotive Quality Systems Standard 5
M Predictive Maintenance vs SPC (Statistical Process Control) Data Misc. Quality Assurance and Business Systems Related Topics 3
S Predictive Maintenance Format / Example Misc. Quality Assurance and Business Systems Related Topics 4
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
G Predictive Maintenance Services IATF 16949 - Automotive Quality Systems Standard 7
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
Q Predictive Maintenance Suggestions IATF 16949 - Automotive Quality Systems Standard 14
M Predictive Maintenance - Confused about what can be considered predictive maintenance IATF 16949 - Automotive Quality Systems Standard 8
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
H What is Predictive Maintenance - MFTB Collection (downtime interval of equipment) IATF 16949 - Automotive Quality Systems Standard 1
L Predictive Maintenance activities - Please review my proposed form/criteria IATF 16949 - Automotive Quality Systems Standard 6
Marc Predictive Maintenance? GM pitches "smart" cars to cut back on discounts World News 2
R Predictive Maintenance for Plastic Injection Machine IATF 16949 - Automotive Quality Systems Standard 7
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
D How to setup a system for Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 8
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
Q Validation of Predictive Models of Yield Statistical Analysis Tools, Techniques and SPC 19
A Predictive Model Development (Regression?) Statistical Analysis Tools, Techniques and SPC 5
H Statistical Models for Predictive Management of Software Processes Software Quality Assurance 2
kedarg6500 Corrective Action (CA) vs. Preventive (Predictive) Action (CAPA) Preventive Action and Continuous Improvement 18
K Using the Predictive Index for Job Candidates Career and Occupation Discussions 14
K Predictive Quality Indicators - Manufacture of semiconductor optoelectronic products Quality Tools, Improvement and Analysis 2
J CQI-7 - ISO/TS 16949 Implementation Guide and preventive and predictive IATF 16949 - Automotive Quality Systems Standard 3
C How to develop an Equipment / Machinery FMEA - Remember the key word: Predictive FMEA and Control Plans 7
J Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discussion Preventive Action and Continuous Improvement 177
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
