Predictive Maintenance Suggestions
Q
QA-Talport
I need some help with Predictive Maintenance. In our last TS audit we were sited for not having a predictive maintenance program. The auditor told us what were doing was tool changing.
We are a automotive wiring harness provider. We have Komax cutting machines, compressors, presses for terminating, manual cutting machines and all of our boards are stationary.
We are at a lose in what to implement for predictive maintenance. Does anybody have any suggestions. Thanks.
Edit: Just to let you know, our plant is in Mexico and I really don't know what services are available where we are.
Re: Suggestions for Predictive maintenance
Some examples of predictive maintenance are thermal imaging to detect mechanical or electrical components that are running hotter than normal; analysis of fluids (hydraulic) for chemical breakdown, metal fines, contamination; vibration or acoustic analysis (bearings, alignment of rotating equipment, etc.).
There are other techniques.
Q
QA-Talport
What are the other techniques. The three you listed are the only three that we hear about and it is really not cost effective based on the equipment that we have. We do not have rotating equipment, we don't have hydraulic fluids and very little mechanical equipment.
Jen Kirley
Quality and Auditing Expert
QA-Talport, the question to ask is: which functions of these machines affects quality?
Planning for preventive maintenance is planning for realiable and continual good output for the tool's availability as well as ability to produce good product.
Thus, the questions to ask for planning are:
1. Which functions would affect readiness--that is, which would cause down time if the machine breaks and is not available?
2. Which functions would affect ability to produce good product if wear, misalignment, malfunction due to mechanical problems etc. occurs? This requires understanding of what machine aspect impacts what quality aspect.
An FMEA should help you with this planning process.
RoxaneB
If the technological aspects to Predictive Maintenance aren't feasible, what about the people aspects? Have you introduced a Routine Equipment Care program for your operators to follow, so that Maintenance personnel can do maintenance? This initiative helps the operator to understand his/her equipement and its use, plus improves communication between Operations and Maintenance.
If done properly, the number and length of interruptions may be reduced, as well as the number of equipment emergencies.
Have you also established Key Performance Indicators to track equipment performance, utilizations, delays, etc.? Highlighting problem areas (i.e., trends) will assist you in developing a more proactive maintenance program instead of reactive.
Q
QA-Talport
This is great information for preventive maintenance, but I am really looking for some predictive maintenance ideas.
Jen Kirley
Re: Suggestions for Predictive Maintenance
Predictive and preventive are similar in that both are meant to prevent disruptions.
Predictive could be thought of as a guess as to when failure would happen, and do a repair before then. Wear, vibration and other trends would be examined.
Preventive would be more routine, like changing belts, filters and oil, and cleaning.
Read more about predictive maintenance here:
http://www.idcon.com/article-maintenancetwoeight.htm
http://www.plantservices.com/articles/2005/479.html
http://www.allbusiness.com/marketing-advertising/marketing-collateral/217498-1.html
...and also here.
RoxaneB
Links to similiar discussions where you might obtain some ideas can also be found by scrolling down to the bottom of this screen.
Marc
Fully vaccinated are you?
A couple of existing threads to gum up the works:
Distinction between Preventive Maintenance and Predictive Maintenance
Predictive maintenance vs Preventive maintenance
Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4
Jrich
Most items we use are Preventive. With respect to the predictive maintenance I agree with Miner. We use the vibration and thermal imaging of electrical panels and disconnect boxes. Thermal imaging is very good at detecting potential fire hazards and therefore potential downtime and operational disruptions.
You could probably ask your auditor what type of predictive items they have seen as well to get an idea of what else is out there.
The thermal testing works well, we generally find items each year based on this function. Vibration testing has not been as beneficial to us.
Good luck.
Jason.
S Predictive Maintenance Format / Example Misc. Quality Assurance and Business Systems Related Topics 4
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
M Predictive Maintenance Data Collection IATF 16949 - Automotive Quality Systems Standard 11
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
G Predictive Maintenance Services IATF 16949 - Automotive Quality Systems Standard 7
K Monitoring Tool Wear for Predictive Maintenance - Data evaluation methodogy IATF 16949 - Automotive Quality Systems Standard 5
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
M Predictive Maintenance - Confused about what can be considered predictive maintenance IATF 16949 - Automotive Quality Systems Standard 8
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
H What is Predictive Maintenance - MFTB Collection (downtime interval of equipment) IATF 16949 - Automotive Quality Systems Standard 1
L Predictive Maintenance activities - Please review my proposed form/criteria IATF 16949 - Automotive Quality Systems Standard 6
Marc Predictive Maintenance? GM pitches "smart" cars to cut back on discounts World News 2
R Predictive Maintenance for Plastic Injection Machine IATF 16949 - Automotive Quality Systems Standard 7
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
M Predictive Maintenance vs SPC (Statistical Process Control) Data Misc. Quality Assurance and Business Systems Related Topics 3
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
D How to setup a system for Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 8
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
Q Validation of Predictive Models of Yield Statistical Analysis Tools, Techniques and SPC 19
A Predictive Model Development (Regression?) Statistical Analysis Tools, Techniques and SPC 5
H Statistical Models for Predictive Management of Software Processes Software Quality Assurance 2
kedarg6500 Corrective Action (CA) vs. Preventive (Predictive) Action (CAPA) Preventive Action and Continuous Improvement 18
K Using the Predictive Index for Job Candidates Career and Occupation Discussions 14
K Predictive Quality Indicators - Manufacture of semiconductor optoelectronic products Quality Tools, Improvement and Analysis 2
J CQI-7 - ISO/TS 16949 Implementation Guide and preventive and predictive IATF 16949 - Automotive Quality Systems Standard 3
C How to develop an Equipment / Machinery FMEA - Remember the key word: Predictive FMEA and Control Plans 7
J Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discussion Preventive Action and Continuous Improvement 177
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
