Predictive Maintenance Suggestions
harry
#11
My question is: just because predictive maintenance is mentioned in the TS documents, does it mean that every body must practice it or show evidence that it is being practiced?
While I understand that it is basically a 'good practice' but at times it may not be applicable in a low tech. environment such as manufacturing of wire harness where simple machines for cutting, crimping and testing are employed. (in other words, traditional preventive maintenance is good enough)
Thanks in advance for sharing your views.
#12
Re: Suggestions for Predictive maintenance
What are the other techniques. The three you listed are the only three that we hear about and it is really not cost effective based on the equipment that we have. We do not have rotating equipment, we don't have hydraulic fluids and very little mechanical equipment.
Sorry. I didn't have time earlier to get back with you.
Some additional methods include dynamic current monitoring of motors, continual monitoring of temperature for gradual increases, continual monitoring of pressure or pressure drop (as filters clog), ultrasonic, and performance trending.
Jrich
#13
In answer to you question Harry:
The requirement for Predictive Maintenance is a Shall and therefore you must do it.
Section 7.5.1.4 "The Organization shall utilize predictive maintenance methods to continually improve the effectiveness and the efficiency of production equipment."
Therefore the focus should be on production equipment, and you must show evidence that even low tech items have predictive maintenance performed.
It is a good question and did make me look at the specification to ensure I wasn't missing anything.
Tim Folkerts
#14
Couldn't something as simple as visual inspection be a part of predictive maintenance? Between shifts someone goes around and looks at the equipment for signs of wear and tear. Items that are questionable are watched more closely, or are replaced immediately.
Who has the signature "Low Tech is better than No Tech"?
P
pinpin - 2009
#15
I think the system belongs to the owner who runs the business, as such whether Predictive Maintenance is practical for the owner is at his discretion base on his cost and benefit analysis.
I agree that simple routine preventive maintenance's resulta contribute to the predictive maintenance decision. If the components found to fail soon can be replaced readily without causing disruption to quality and delivery to customer, I think it is less critical to practice predictive maintenance here.
I agree, predictive maintenance is good to practice when components of machines are not changed before it fails as it could cause the owner to incur most cost, but not for those with easy replacement of components and quick repaired machines. If this is already acceptable in TS audit, please enlighten me, thank you very much!
As such, I wonder whether TS Standard would consider revising some of the requirements to be more flexible, of course it will then depend on competence of auditor to judge whether the practice of the owner is complying to the intent of the Standard; and I think auditor is and should play this role, instead of follow the standard without critical assessment of the Standard requirement and its applicability.
Please pardon me and correct me for me to learn more, thank you very much!
S Predictive Maintenance Format / Example Misc. Quality Assurance and Business Systems Related Topics 4
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
M Predictive Maintenance Data Collection IATF 16949 - Automotive Quality Systems Standard 11
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
G Predictive Maintenance Services IATF 16949 - Automotive Quality Systems Standard 7
K Monitoring Tool Wear for Predictive Maintenance - Data evaluation methodogy IATF 16949 - Automotive Quality Systems Standard 5
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
M Predictive Maintenance - Confused about what can be considered predictive maintenance IATF 16949 - Automotive Quality Systems Standard 8
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
H What is Predictive Maintenance - MFTB Collection (downtime interval of equipment) IATF 16949 - Automotive Quality Systems Standard 1
L Predictive Maintenance activities - Please review my proposed form/criteria IATF 16949 - Automotive Quality Systems Standard 6
Marc Predictive Maintenance? GM pitches "smart" cars to cut back on discounts World News 2
R Predictive Maintenance for Plastic Injection Machine IATF 16949 - Automotive Quality Systems Standard 7
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
M Predictive Maintenance vs SPC (Statistical Process Control) Data Misc. Quality Assurance and Business Systems Related Topics 1
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
D How to setup a system for Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 8
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
Q Validation of Predictive Models of Yield Statistical Analysis Tools, Techniques and SPC 19
A Predictive Model Development (Regression?) Statistical Analysis Tools, Techniques and SPC 5
H Statistical Models for Predictive Management of Software Processes Software Quality Assurance 2
kedarg6500 Corrective Action (CA) vs. Preventive (Predictive) Action (CAPA) Preventive Action and Continuous Improvement 18
K Using the Predictive Index for Job Candidates Career and Occupation Discussions 14
K Predictive Quality Indicators - Manufacture of semiconductor optoelectronic products Quality Tools, Improvement and Analysis 2
J CQI-7 - ISO/TS 16949 Implementation Guide and preventive and predictive IATF 16949 - Automotive Quality Systems Standard 3
C How to develop an Equipment / Machinery FMEA - Remember the key word: Predictive FMEA and Control Plans 7
J Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discussion Preventive Action and Continuous Improvement 177
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
