Preparation for ISO 9001:2015 - Required Document Revisions
L
Lougee
Hello again :bigwave:.
I was currently working with a company with existing document system. My question is, since their current revision onprocedure/w.i are for example rev. 5, whenwe prepare for ISO 9001:2015(document registration), do we need to reset the form to rev.0 since it will be the first time the document will be controlled?
TIA:):)
AMIT BALLAL
Hi!
Its a good choice to reset revision dates of forms against a new issue number. But is optional, its up to your organization how you do it. Standard doesn't mandate this.
What do you mean by Document control for first time?
Since you are already having a management system, document control system might be in place.
Thanks,
Amit
L
Lougee
Thanks Amit. But I have additional question. How about during audit, can we present those document(records) which were not yet controlled?
somashekar
TIA:):)
The standard has changed and will change again after some years. Your QMS just improves. There is nothing to reset. Its only revision to next if you want to do.
L
Lougee
I mean, there was no established ISO during our 1st 12mos of manufacturing but we have those documents (forms/checksheet/w.I) it has revision (currently #5) but no document control/not registered to dcc.
I was asking if we are going to established now the ISO QMS:
1. is my current revision#5 for document will be reset to 0 once registered to dcc?
2. if answer to question1, is yes. How about our previous record for the last 12mos, are we going to present it to the iso audit?
AMIT BALLAL
1. If you were not having a proper document control system in place in past, you can reset revision numbers against a new issue number (i.e. Issue no.2 in your case). This will help to start fresh and maintain things properly. You'll have to write the details of revision in your document change history stating "new issue no. was raised and therefore all forms reset to 0 to upgrade to ISO9001:2015".
2. No problem even if you change revision numbers. Your old records will still remain valid. Revision in any form means from that date / as per your company policy, only the new format should be used.
howste
Thaumaturge
The answer to question 1 is no.
At the time of certification to ISO 9001, the auditor(s) will expect to see evidence of conformity to the standard for some period of time. If you show every document at Rev 0 it wouldn't show evidence that the document change process is working. Just because your system wasn't certified doesn't mean that the documents weren't controlled. I would recommend that all of your documents keep the revisions they are at currently.
L
Lougee
So you mean, if ISO QMS updates, ISSUE NUMBER for my document will be set to issue# 3; rev. 00?
That is what I was thinking too; auditors won't see evidence of controlling the document. I know there's no specific way to control document according to the standard and I was just preparing for possible query of the auditor.
Does adding ISSUE # + rev # will be insufficient? Document will be issue#2; rev. 00 from issue#1:rev5.
QUestion:
If I am going to retain REV5 on registration of the document, all previous rev(1 to 4) shall reflect the history right?
Same with if I am going to adopt ISSUE# plus REV #..
Big thanks to you guys
howste
Thaumaturge
I wouldn't bother with an Issue #. Your system is your system. You don't need to change your revision indicator if an ISO standard changes. If you make changes to a document because a requirement in ISO 9001 has changed, just increment your number up one.
It's good practice to maintain a history of the document revisions. Previous versions of ISO 9001 required records of this, but the 2015 version doesn't.
S ISO 9001:2015 & ISO 14001 Re-Certification Audit Preparation ISO 14001:2015 Specific Discussions 8
Q ISO 9001 Survelliance Audit Preparation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q 5 Tips for ISO 9001 Certification Preparation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 Registration Preparation Gantt or Pert Chart or Timeline ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A ISO 9001 3rd Party Audit Preparation - Open Issues Aspects General Auditing Discussions 81
S ISO 9001:2000 Internal Audit Preparation Internal Auditing 14
C Final preparation before ISO 9001:2000 Assessment Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C ISO 9001:2000 Internal Auditor System and Preparation - Schedule, Check Lists, etc. Internal Auditing 57
Q Requirements and suggestions for ISO/TS 16949 Internal Auditor Preparation IATF 16949 - Automotive Quality Systems Standard 1
N Putting SOPs in place in preparation for ISO certification - where to start? Service Industry Specific Topics 5
S ISO 17025 Quality Manual Preparation ISO 17025 related Discussions 7
F Preparation for TUV surveillance audit - ISO 13485 - Medical Devices General Auditing Discussions 5
B Remote IATF 16949 audit preparation General Auditing Discussions 10
Q AS 9120 exam Preparation Tips AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Regulatory Affairs Certification (RAC) Exam - November 2020 preparation Professional Certifications and Degrees 0
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
P ASQ Certified Biomedical Auditor (CBA) Certification Preparation 2019 ASQ - American Society for Quality 3
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
I IATF16949 Audit Preparation, Need "searchable" ANPQP 3.1 or latest IATF 16949 - Automotive Quality Systems Standard 1
andika_untoro ASQ CQE Exam Group for Dec 2019 / Jan 2020 Preparation ASQ - American Society for Quality 18
J ASQ Chicago Training Institute - If any of you are interesting in teaching ASQ Certification preparation ASQ - American Society for Quality 1
A CTD (Common Technical Document) for a Topical Preparation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
E RAC EU preparation aids - Tips on how to prepare for RAC EU exam Professional Certifications and Degrees 2
T Is a new edition of the IEC 60601 in preparation for 2019 (Amendment 2)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Marc Homework and Examination Preparation Help Policy Elsmar Cove Forum ToS and Forum Policies 1
D AS9100 Audit Preparation Costs and Hours AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Cost of DMF Type III preparation and submission Other US Medical Device Regulations 1
D What is a reasonable consulting fee for preparation of a complete traditional 510k? Consultants and Consulting 11
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
B OCP 11g 1Z0-053 Exam Preparation Professional Certifications and Degrees 1
B API Q1 & Monogram Preparation Oil and Gas Industry Standards and Regulations 19
C What are the best preparation materials for ASQ CSSBB? Professional Certifications and Degrees 2
P RAC (Regulatory Affairs Certification) US Spring 2013 Preparation Study Group Professional Certifications and Degrees 3
P Acquire formal USFDA Inspector for USFDA Inspection Preparation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Advice for preparation of ADOA and POA audits - What are the most critical points? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
optomist1 Interview Preparation for Quality Supervisory Position - TS16949 Environment Career and Occupation Discussions 24
R Information on RAC US Test Preparation Material Training - Internal, External, Online and Distance Learning 1
S What is the role of "Reviewer" and "Approver" in the preparation of procedures? Document Control Systems, Procedures, Forms and Templates 9
A FDA Inspection Preparation Hints 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
G Preparation Work for Internal Audit before they Audit a Area Internal Auditing 2
K Guidance on Preparation for EASA Certification wanted EASA and JAA Aviation Standards and Requirements 4
M CQE Preparation - Classes offered by ASQ or QC Group Professional Certifications and Degrees 9
C Preparation for Product Validation Protocol ISO 13485:2016 - Medical Device Quality Management Systems 6
R Inspection types A, B AND C used in FMEA Preparation FMEA and Control Plans 3
M ASQ CQA Exam June 4, 2011 - Best resource for preparation Professional Certifications and Degrees 19
K AS 9100 Rev C - Risk Management Procedure and Template Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Entry Level Quality Engineer Interview Preparation/Advice? Career and Occupation Discussions 23
Q ASQ CQM (Certified Quality Manager)/OE Certification Exam Preparation Materials Professional Certifications and Degrees 3
R Preparation for AS9100B conversion to AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
jkuil Clean Room Class for Aseptic Preparation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
