Preservation of Electronic Data / Information Technology
duff999
Hi Folks
I have the task of writing an SOP regarding Preservation of Electronic Data / Information Technology for a small company that uses an electronic QMS. I was gearing this towards the following:
1. How the eQMS is backed up and retention
2. How our Google Drive is managed, backed up.
3. How we backup our local data, and offsite storage.
We are not server based, just as an fyi
I am ot even sure if this is the right approach and was looking for any tips anyone has regarding this SOP.
Ninja
Looking for Reality
Been there, though I had off-site consultants doing the nitty gritty.
I would:
1. write minimum requirements...using the phrase "or equivalent" frequently.
"Backups should be RAID 1 or equivalent (or better)"
"At least two off site backups (or equivalent) must be kept"... that kind of stuff...so you don't have to rewrite the whole thing when tech improves.
2. Write the step by step process as "Example 1"...so if little tweaks happen later you don't immediately become non-compliant.
Google drive changes the manager screen layout, dropdown titles, etc.
FWIW, most folks would consider Google drive to be "a server"...but call it whatever you want.
eQMS not on a server? So you can only access it through a single hard drive and single screen?
When it comes to writing, write the top level stuff vague...what is needed? Google drive is not needed, a cloud or server based data storage is needed.
When you get to the nitty gritty, that's when you mention Google Drive (or equivalent). eQMS database (or equivalent), etc.
Then in Example 1...it's a step by step instruction (with screenshots) so that any competent person can perform the task if you get hit by a bus.
Taking this approach, you have an overview which is a little flexible if OneDrive gives you a great deal next month, or RAID5 becomes cheaper than RAID1 or, or, or ...but you also capture the current state with detailed instructions like a manual.
HTH.
duff999
I would:
HTH.
I would:
HTH.
Good information.
Currently all of QMS is cloud based, so I can describe the process or storage and retrieval, Google Drive also holds some of our records that we dont keep in our eQMS (spreadsheets, inspection records, etc), I can explain how data is stored, backed up, and retrieved if necessary. We do not backup local laptops, anything that would affect product quality, or QMS should not be stored locally.....is this enough to explain, or should we put a policy in place that local laptops connected to the network should be backed up.
Ninja
Looking for Reality
Not sure if that was a question or not...so let me comment this way:
If your company thinks it's important, it should be done.
There is a goal set (Preservation of Electronic Data / Information Technology )
There is an assumed goal also set (folks have to be able to get at it).
The high level is "Why are we doing it? What are the general requirements to achieve that goal?"
The mechanics of how your particular company chooses to do it...that's the "Example", for QMS, for Any other way of storing or preserving data.
QMS is cloud based (that's a server BTW) and is already not local.
Google Drive is cloud based (also a server) and already not local.
Does your company care if laptops are backed up? You need an answer to this before you start writing.
If a laptop was lost or fried...would you care about the potential data loss?
Does your company need/want your own copies of what is on Google Drive or your cloud QMS? or do you trust those folks to backup and preserve?
Flesh out (for yourself, not here) the whole picture of data preservation...
What data?
How is it initially stored/recorded the first time at data generation?
How is it protected prior to compilation?
How is it complied for longevity storage?
How is it then protected?
How long is it to be kept?
How/who/when can you then retrieve it?
Walk mentally through the process of how the data is handled already, from generation to backup retrieval to disposal... correct or question the process as needed... then let that guide your SOP document.
In my experience, laying the whole thing out in a flow chart will make life easier...and I would show said flowchart to top management (they likely don't think about this stuff often) and see if the system you found is at all the system they want ... or if it really makes any sense at all.
Then document the process.
duff999
Great information Ninja, thanks for allowing me to see the whole picture. I appreciate you taking the time explaining this, very helpful.
Ninja
Looking for Reality
Happy to help... been through that task often enough...
My mantra through the whole thing (every time).
Time is expensive. People are expensive. Losing data is expensive.
Storage is cheap.
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
I IATF 8.5.1.5 Requirements c) provision of resources and d) packaging and preservation IATF 16949 - Automotive Quality Systems Standard 1
S Methods used for Preservation of Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 5
D AS9100 section for Warehouse/Preservation of materials? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S How do you determine a Constituent Part - Clause 7.5.5 Preservation of Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M What is "protection" as in section 7.5.5 "Preservation of product" ? IATF 16949 - Automotive Quality Systems Standard 7
M ISO 9001 - 7.5.5 - Meaning of Identification and how it helps Product Preservation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Clause 7.5.5 Preservation of Product in a Home-Care Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R ISO 9001 Clause 7.5.5 Preservation of Product - Application to Software Products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO 9001 Clause 7.5.5 Preservation of Product - Apply or exclude? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
N Note interpretation - Ensure that the preservation of the product has been consider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Material Handling, Storage & Preservation Procedure for Aerospace Mechanical Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Engineering Consultancy - Clause 7.5.5 (Preservation) and 7.6 Equipments ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Applicability of 7.5.5 Preservation of Product in a Service Industry like Insurance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J Basic template for Preservation, Storage and Handling Document Control Systems, Procedures, Forms and Templates 5
C 7.5.5 Preservation of Product - Marking and Labeling AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Preservation of Product - Service Industry - AS9100 Clause 7.5.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Preservation of Product in Administrative Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M How is 7.5.5 Preservation of Product applicable to Health Care Services? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Product Preservation - Measure of effectiveness IATF 16949 - Automotive Quality Systems Standard 12
W Process inputs and outputs - Purchasing and Preservation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M Element 7.5.5 - Preservation of Product - We ship the product FOB Point of Origin ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Preservation of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
D Advice on capturing electronic signatures ISO 13485:2016 - Medical Device Quality Management Systems 8
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Cleaning of electronic transmitter Other Medical Device Related Standards 2
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
D Benefits of electronic QMS software Software Quality Assurance 5
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
R Electronic handwritten signatures for approvals - Signed with a Stylus or a Finger Document Control Systems, Procedures, Forms and Templates 2
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
P FDA inspections and electronic signatures Other US Medical Device Regulations 2
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Looking to move to an electronic QMS software Software Quality Assurance 11
QIE Electronic IFU - new project, need input Other Medical Device and Orthopedic Related Topics 0
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
M Informational USFDA – Radiological Health Regulations; Amendments to Records and Reports for Radiation Emitting Electronic Products; Amendments to Performance Stand Medical Device and FDA Regulations and Standards News 0
