Pressure energy - Essential Requirements (MDD/MDR)
Rincewind
I was wondering if a device that puts pressure on a patients limb, for example would have to be considered under Annex I MDD (12.8.1.) or respective Annex I MDR (21.1.)
"21.1. Devices for supplying the patient with energy or substances shall be designed and constructed in such a way that the amount to be delivered can be set and maintained accurately enough to ensure the safety of the patient and of the user." (MDR, Annex I, p. 102).
As the device is non active and class I, no electrical energy is involved, this was discussed.
I am leaning towards: Yes, this clause should be applicable as pressure is still a form of kinetic energy and the regulation does not differentiate between thermic, electrical, light and so on.
Any opinions on this? :)
planB
From a purely physical perspective and in terms of SI basic physical quantities:
Pressure = Force / Area
Energy (expressed as Work) = Force X Distance
So pressure is not a form of any kind of energy. Pressure and energy are two distinctly different physical quantities.
HTH,
Gerhard
dgrainger
Not strictly applicable, but MEDDEV 2. 1/2 rev 2 has guidance on being an active device and pressure:
2.1.2. For the purpose of the Directive 90/385/EEC a medical device is active if it "relies for its​
functioning on a source of electrical energy or any source of power other than that directly​
generated by the human body or gravity. This includes, for instance, devices activated by​
means of pressure unless this effect is achieved by energy resulting from the body of the​
patient. The definition implies that the function of the device involves using the source of​
power to perform useful work. The mere transmission of heat, light, pressure or vibration​
does not mean that a device is active.​
Examples :​
- a hydrocephalus pressure relief allowing release of cerebro-spinal fluid when a spring
is overcome is not "active". Even where the setting of the spring can be adjusted by
electro-magnetic means, it remains non-active as the medical function of the device is
to relieve pressure, not to be adjusted,
- a drug delivery device in which the drug is driven from a reservoir by means of a stored
energy source (spring, fluid, gas, etc...) is "active"
- an intravascular cathether containing a fibre-optic bundle connected to an external light
source may be used to measure pressure or other characteristics of blood if some
quality of the light can be changed by the blood characteristic and detected. Although
the system as a whole depends on a power source to achieve its medical function (the
measurement of a blood characteristic) the invasive element is not "active" as it does
no more than transmit light
- a cochlear implant activated by an external power transmitter is regarded as "active"
as the implanted component clearly depends on a power source for its function and its
purpose is to convert the power it receives into electrical signals which trigger
appropriate sensory channels in the brain, i.e. it performs useful work.
J Cleanroom Differential Pressure Monitoring, frequent manual observation US Food and Drug Administration (FDA) 6
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
Q Autoclave and Sample Container - Pressure-steam cooking's effect Reliability Analysis - Predictions, Testing and Standards 1
O Selection of a calibrator (pressure generator, temperature) for my field devices General Measurement Device and Calibration Topics 2
M Proper ISO standard for Pressure Testing and Leak Rates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
C Pressure requirement of home based Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Opening pressure of one-way valve in anaesthetic workstation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Colin Pressure Vessels for Human Occupation (PVHO) Various Other Specifications, Standards, and related Requirements 4
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
renenatasha MDD Classification for Pressure Monitoring Set CE Marking (Conformité Européene) / CB Scheme 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Pressure Equipment Directive (PED) - Fastener questions CE Marking (Conformité Européene) / CB Scheme 4
R Pressure Equipment Directive (PED) Manufacturing and Related Processes 3
M Control Plan MSA's - Pressure Gages IATF 16949 - Automotive Quality Systems Standard 2
R Looking for calibration specification for Fluke 7250 pressure controller General Measurement Device and Calibration Topics 5
A FDA Blood Pressure Monitoring Equipment Measurement Requirements US Food and Drug Administration (FDA) 1
O CE TCF (Technical Construction File) Template for LVD/EMC/Pressure Directive CE Marking (Conformité Européene) / CB Scheme 5
A German MTK (MPBetreibV ? 11) Blood Pressure Meter Requirements EU Medical Device Regulations 2
S Pressure from Directors - confused! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
O Pressure Equipment Directive PED (97/23/EC) CE Marking (Conformité Européene) / CB Scheme 3
C What would be the Device Classification for a Blood Pressure Monitor in EU ? EU Medical Device Regulations 3
R Applicable Medical Device Standards for Home Use Blood Pressure Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
GURU SDI Measurement - Pressure Drop vs. Leak Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
F Pressure Regulator Testing and Selection Other Medical Device Related Standards 2
R Pressure Test Dial Gage Selection Quality Tools, Improvement and Analysis 1
T Who pays for certification to the PED (Pressure Equipment Directive)? Registrars and Notified Bodies 9
D Calibration and Tolerance Ranges of Pressure Gages General Measurement Device and Calibration Topics 8
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
K ASME BPVC (Boiler & Pressure Vessel Code) Calibration Requirements General Measurement Device and Calibration Topics 6
M Pinout of Keller PAA-15 Pressure Transducer General Measurement Device and Calibration Topics 1
P EN 1618 Clarification Re: Catheter Pressure Testing Other ISO and International Standards and European Regulations 4
B Validation of a Pressure Decay Leak Tester for a Medical Device Design and Development of Products and Processes 2
R How to Inspect the Weld Strength of High Pressure Vessel & Oil Pipe Line Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
W Pressure Calibration to psiA (psi Absolute) General Measurement Device and Calibration Topics 8
S Pressure Gages - Equipment Tolerance vs. Product Specification Calibration and Metrology Software and Hardware 2
W Pressure Transducer Calibration Standards General Measurement Device and Calibration Topics 6
M Pressure gage on a machine-monitoring tool or measuring tool? IATF 16949 - Automotive Quality Systems Standard 9
S Air Line Devices Filters, Pressure Regulators, Lubricators Manufacturing and Related Processes 3
P Pressure Corrections and associated MU for Dead Weight Testers Calibration and Metrology Software and Hardware 1
R Blood Pressure Transducers - Need to perform EMC test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
C Degrees of Freedom with Linear Regression - Pressure Sensor Uncertainty Measurement Uncertainty (MU) 15
C Gage R&R not passing for Check Valves Crack Pressure - No Reproducibility Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
