Preventative Action vs. Corrective Action - ISO 9001
Q
QE Bob
I am in a discussion with different parties on how we address these two elements in the standard. One opinion is that they are both relatively the same and that preventive action can follow corrective action and so their use of common means to achieve either is acceptable. The other thought is preventive is not part of corrective action because the standard references pre-considerations in section 8.5.3. Because of wording such as "eliminate the causes of potential nonconformities" and "prevent their occurrence" it means consider the possibility of non-conformances. Any ideas or thoughts on this?
Coury Ferguson
Moderator here to help
Re: ISO 9000 Preventative vs. corrective action
Please perform a search of this topic. This has been debated here in the cove for a long time. And I really don't think you are going to get many responses on the CA/PA.:frust:
I will make it easy for you:
Corrective and Preventive Action
BadgerMan
Corrective actions prevent recurrence whereas preventive actions prevent occurrence. Do not confuse “preventive action” with “recurrence prevention”. Preventive action is proactive, recurrence prevention is reactive.
You can use the same problem solving process/tools in either case.
Check (and search) this forum for a million discussions on this subject:
http://elsmar.com/Forums/forumdisplay.php?f=40
P
preetham - 2007
The corrective action is to correct the existing non conformance
And the preventive action is to prevent the non conformance happening once again for the futere batch
BadgerMan
Incorrect.
BadgerMan
preetham said:
could you please differentiate between the prevntive & recuurence please
Preventive actions prevent occurrence whereas corrective actions prevent recurrence.
Preventive action prevents something from happening. Corrective action prevents something from happening again.
Q
QE Bob
Thanks for the heads up on the prior post's I have been reading through and have found them to interesting and helpfull. One more favor, how do I kill this post so it will stop nay more discussion. As you can tell I am new to this posting thing.
Thanks again
A TS 16949 Type of Corrective and Preventative Action Procedure wanted Document Control Systems, Procedures, Forms and Templates 3
C Should Preventative Action follow a Corrective Action Nonconformance and Corrective Action 27
J Corrective/Preventative Action External - Corporate Supplier Quality Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Corrective and Preventative Action in Practice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
F Corrective Action and Preventative Action cover Control of Nonconformance? Nonconformance and Corrective Action 13
J Corrective Action and Preventative Action Procedures Combined- good or bad? IATF 16949 - Automotive Quality Systems Standard 2
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 1
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 8
L Preventative Action vs. Opportunity for Improvement Preventive Action and Continuous Improvement 21
C PFMEA RPN rankings - Preventative action must be opened if RPN over 100 ISO 14971 - Medical Device Risk Management 9
Q Difference between Preventative Action and Preventive Action Preventive Action and Continuous Improvement 30
R Preventative Action - Organizational ideas - Process or Work Instruction Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Seeking: Preventative Action Form Template Document Control Systems, Procedures, Forms and Templates 4
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
W Corrective /Preventative/Rectification actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Document Revision for each new Preventative Maintenance Checklist? Document Control Systems, Procedures, Forms and Templates 5
Q Preventative Maintenance Procedure that meets ISO TS 16949 Requirements IATF 16949 - Automotive Quality Systems Standard 4
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
J HVAC-Refrigeration Preventative Maintenance Checklist Manufacturing and Related Processes 4
M Do you use Software to Control Preventative & Corrective Actions? Quality Assurance and Compliance Software Tools and Solutions 1
P Sampling Plans for Corrective and Preventative Maintenance Service Orginizations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Alternate Terms for NonConformance, Internal Audits, Corrective and Preventative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
L How to start with TPM (Total Preventative Maintenance) Quality Tools, Improvement and Analysis 13
R How to rank Detection for Existing Preventative design controls FMEA and Control Plans 7
B Can Training be used as Preventative Control on FMEA? FMEA and Control Plans 10
B FMEA - Reduced Detection Ranking by Use of Preventative Maintenance FMEA and Control Plans 6
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 6
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
I Setting action completion dates Nonconformance and Corrective Action 3
A Medical device Mode Of Action CE Marking (Conformité Européene) / CB Scheme 2
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
nadhar2 Classification of Action Items Misc. Quality Assurance and Business Systems Related Topics 3
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
Q Tips for Action Requests on Communication and Leadership ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
M Informational TGA – Australian regulatory action on breast implants and breast tissue expanders Medical Device and FDA Regulations and Standards News 0
M Informational Medical Device Safety Action Plan: Protecting Patients, Promoting Public Health Medical Device and FDA Regulations and Standards News 0
