Preventative Action vs. Corrective Action - ISO 9001
Coury Ferguson
Moderator here to help
#11
QE Bob said:
Thanks for the heads up on the prior post's I have been reading through and have found them to interesting and helpfull. One more favor, how do I kill this post so it will stop nay more discussion. As you can tell I am new to this posting thing.
Thanks again
Edit it and delete it. But one of the fine moderators will handle the rest,. Send them a PM expressing what you would like.
BadgerMan
#12
No need to kill it, I'll just move it to the corrective action forum.
Good topic and discussion. Thanks for posting. :bigwave:
CarolX
#13
Re: ISO 9000 Preventative vs. corrective action
Thanks again
Like badgerman said...no need to kill it. This subject can be a difficult concept to understand -
Preventative action are steps you take to prevent potential problems. Actions like this may include calibration, machine maintainence, even monitoring customer satisfaction is preventive in nature.
Corrective actions are steps you take after a problem is discovered. How to fix the problem and what can be done to prevent (hence the confusion) it from re-occuring.
F
favqty
#15
QE Bob said:
I am in a discussion with different parties on how we address these two elements in the standard. One opinion is that they are both relatively the same and that preventive action can follow corrective action and so their use of common means to achieve either is acceptable. The other thought is preventive is not part of corrective action because the standard references pre-considerations in section 8.5.3. Because of wording such as "eliminate the causes of potential nonconformities" and "prevent their occurrence" it means consider the possibility of non-conformances. Any ideas or thoughts on this?
Just one way to see it:
Once you decide to implant the International standart through your organization you may will be ready to find a lot of situations that increase the likelyhood of process/product deviation. It is not a matter of your company is wrong, No. Your business is going well and profits are presen at the end of the balance. Beside this you are changing the way to see or measure your processes. That is why something will be determined as a Out of Control or risky. This facts will define your GAP between your reality and the new standard. This GAP may be closed or narrowed as much as you can to satisfy the Standard. The tool to accomplish this task is Corrective Action procedure.
Once you have your GAP closed and your QMS running, continuos improvement (Which is the soul of the new standard you are using) methods will give to your organisation the power to interprete variable trends and if you see something wrong :mg: (You are not achieving some target along three consecutive months or if you keep doing what are doing you sill not reach cost goals) you may want to do something to prevent the caotic situation and correct the trend. This is a Preventive Action.:biglaugh:
I hope you can understand my rough English. HAVE A GOOD ONE!:cool:
A TS 16949 Type of Corrective and Preventative Action Procedure wanted Document Control Systems, Procedures, Forms and Templates 3
C Should Preventative Action follow a Corrective Action Nonconformance and Corrective Action 27
J Corrective/Preventative Action External - Corporate Supplier Quality Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Corrective and Preventative Action in Practice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
F Corrective Action and Preventative Action cover Control of Nonconformance? Nonconformance and Corrective Action 13
J Corrective Action and Preventative Action Procedures Combined- good or bad? IATF 16949 - Automotive Quality Systems Standard 2
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 1
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 8
L Preventative Action vs. Opportunity for Improvement Preventive Action and Continuous Improvement 21
C PFMEA RPN rankings - Preventative action must be opened if RPN over 100 ISO 14971 - Medical Device Risk Management 9
Q Difference between Preventative Action and Preventive Action Preventive Action and Continuous Improvement 30
R Preventative Action - Organizational ideas - Process or Work Instruction Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Seeking: Preventative Action Form Template Document Control Systems, Procedures, Forms and Templates 4
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
W Corrective /Preventative/Rectification actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Document Revision for each new Preventative Maintenance Checklist? Document Control Systems, Procedures, Forms and Templates 5
Q Preventative Maintenance Procedure that meets ISO TS 16949 Requirements IATF 16949 - Automotive Quality Systems Standard 4
R Preventative Maintenance - Moving to a Predictive Maintenance Program Manufacturing and Related Processes 10
J HVAC-Refrigeration Preventative Maintenance Checklist Manufacturing and Related Processes 4
M Do you use Software to Control Preventative & Corrective Actions? Quality Assurance and Compliance Software Tools and Solutions 1
P Sampling Plans for Corrective and Preventative Maintenance Service Orginizations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Alternate Terms for NonConformance, Internal Audits, Corrective and Preventative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
L How to start with TPM (Total Preventative Maintenance) Quality Tools, Improvement and Analysis 13
R How to rank Detection for Existing Preventative design controls FMEA and Control Plans 7
B Can Training be used as Preventative Control on FMEA? FMEA and Control Plans 10
B FMEA - Reduced Detection Ranking by Use of Preventative Maintenance FMEA and Control Plans 6
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 6
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
I Setting action completion dates Nonconformance and Corrective Action 3
A Medical device Mode Of Action CE Marking (Conformité Européene) / CB Scheme 2
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
nadhar2 Classification of Action Items Misc. Quality Assurance and Business Systems Related Topics 3
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
Q Tips for Action Requests on Communication and Leadership ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
M Informational TGA – Australian regulatory action on breast implants and breast tissue expanders Medical Device and FDA Regulations and Standards News 0
M Informational Medical Device Safety Action Plan: Protecting Patients, Promoting Public Health Medical Device and FDA Regulations and Standards News 0
