Preventing Photocopies of a Controlled Document
sam_ck
Hi there,
I am from Document control dept as a document controller. Recently i found that some one in my company has duplicate a copy of a controlled document without request the doucment throughout the document control dept. what would be happen and what should I do ?
Marc
Do you know if they actually photocopied the document, or just printed a copy?
sam_ck
They never let me know they need the copy and they just get the photocopied themselves. By right the control document shouldn't be printed without DOC. con.
Ajit Basrur
You have to analyze what prompted those guys to photocopy the controlled document.
I would recommend you to review the distribution list again with all concerned personnel and issue the controlled copies.
All personnel must be highlighted the importance of using "controlled" copies and steps to be undertaken in case they want additional copies.
Marc
So this is a paper system, correct? Printing out an electronic document is different than photocopying a paper document.
Either way - Essentially your document control system procedure should define how people get controlled documents. If it does not, you should redesign the system because it isn't compliant with basic document control requirements.
If people are not following the procedure/system and it was me, and I was given a bunch of "stories" about why the procedure wasn't followed, I would get them/the area/the department on the Internal Audit schedule and let them get written up so there is formal documentation. There is simply no excuse for not following a procedure.
ADD: See Ajit's post above. It distills what I was trying to say.
sam_ck
Yes, Our doc con procedure is stated all control document must be stamp control chop and distributed. A record of distribution list is available. They all know.
what would be the proper solution to handle the printed copy of control document.
1. Ask them to return the copy and chop control stamp?
2. if the copy have passed to customer or vendor?
Wes Bucey
I see by the term "chop" we are dealing with an Asian culture ("chop" being equivalent to a signature stamp for an individual or a department.)
The primary thing is to remain calm.
  1. Ask the individual politely how he came by the copy - did he make the copy or did someone give it to him? If so, who?
  2. How has the individual been using the copy? - does he do work on a product to which the copy refers?
  3. What, exactly, is the nature of the document? Is it top secret? Does it refer to a process or is it something like a detailed drawing used for inspecting the part? Perhaps it's something like a price list?
Once you know who and why the copy was made and how it was used, you can determine whether your system is lax or whether a trusted individual intentionally found a way around the system. THEN you and the bosses can decide whether to change the system or the trust level of the individual!
Note:
If the system to get a copy for an employee to do his regular work is too stringent or complicated, the worker will try to find a way to make his work more efficient. This mentality goes for documents, tools, work gloves, etc. The worker doesn't intend to humiliate anyone or steal; he just wants to make his own work life easier. If this is the case, there should be a frank dialog with workers to make work more efficient without introducing a possibility of using an obsolete document and thus creating nonconforming work.
If these documents contained trade secrets which could have been leaked to outsiders, you have a different problem.
harry
In a 'traditional' hard copy system, part of the reason why you also control the distribution is to overcome the problem you are facing now. I would check the illegally copied document to determine from which of the controlled copies did it originate from and then go after the person who holds that controlled copy. In other words, control should be centered around the few and known holders of the 'controlled' document.
Appears like a system problem to me.
qusys
My advice is to use " sunset clause" for each paper document you use in the organization if copied or photocopied. They could be valid only for the day in course and each of them should have a stamp on it.
sam_ck
  2. How has he individual been using the copy? - does he do work on a product to which the copy refers?
Note:
Thanks , Wes.
Yes, those controlled copy is a control plan & process flow. I have ask the people who get those copy. He make the photocopy by using the existing controlled copy which had stamped chop on it. For sure , his photocopy cannot be used in the production and would issued NCR by auditor if found that copied.
Sidney Vianna Interesting Discussion UNI/PdR 42:2018 - Preventing and Combating Bullying Guidance Standard Other ISO and International Standards and European Regulations 5
G Setup Part Management - Preventing Escape Manufacturing and Related Processes 13
C Preventing Torque Wrench Deterioration Calibration Frequency (Interval) 5
I RoHS vs Non-RoHS - Best Practice for preventing Cross-Contamination? RoHS, REACH, ELV, IMDS and Restricted Substances 1
T How to preventing the drawing revision not being up to date Preventive Action and Continuous Improvement 1
T Preventing Wrong Terminal Crimped on a Wire Harness Manufacturing and Related Processes 7
Q Preventing Audit Finding by your third Party Registar IATF 16949 - Automotive Quality Systems Standard 5
K Preventing Shortage of Product Quantity - Hand Count and Scale Count Manufacturing and Related Processes 13
Richard Regalado ISO 27001 A.10.4.1 - Detecting, Preventing and Recovering from Malicious Code Threats IEC 27001 - Information Security Management Systems (ISMS) 3
M Preventing Missed Welds on Assemblies Manufacturing and Related Processes 4
S What are the common Problems preventing (Gaps) Implementation of ISO 14001? ISO 14001:2015 Specific Discussions 7
W Chain of Custody for Documents - Preventing Misplaced SOPs Document Control Systems, Procedures, Forms and Templates 4
Q Preventing, corrective for valves in field? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Preventing Set Up Parts from getting in with Finished Goods Manufacturing and Related Processes 17
A Preventing Quality System Non-conformities QS-9000 - American Automotive Manufacturers Standard 5
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CS2 (Controlled Shipping Level) by GM - CB notified. What about other customers? IATF 16949 - Automotive Quality Systems Standard 1
R Digital Storage of ITAR Controlled Documentation Other ISO and International Standards and European Regulations 7
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
