Preventing Photocopies of a Controlled Document
sam_ck
#11
:)Yup, I think so. Thanks for the comment.
In a 'traditional' hard copy system, part of the reason why you also control the distribution is to overcome the problem you are facing now. I would check the illegally copied document to determine from which of the controlled copies did it originate from and then go after the person who holds that controlled copy. In other words, control should be centered around the few and known holders of the 'controlled' document.
Appears like a system problem to me.
G
Geoff Withnell
#12
My advice is to use " sunset clause" for each paper document you use in the organization if copied or photocopied. They could be valid only for the day in course and each of them should have a stamp on it.
The problem with "sunset" clauses is that they do not address the issue of why the employee found it necessary to go around the system to get a copy of the document. They also do nothing to prevent someone from using a "sunset" document multiple days, because it is a pain to get a new one. It's not a compliance to standard issue! It's a system issue that you are not efficiently getting the correct, up-to-date information to the people who need it! Do that, and compliance is easy.
Geoff Withnell
Bill Pflanz
#13
You should be cautious about assuming why the person made an uncontrolled copy. I found an uncontrolled copy of a procedure that was in a truck loading station that was needed for reference. Since the official copy was at ground level in another building it made sense to have a copy there. Normally as an auditor I would not actively recommend a corrective action but the operations manager was ready to "re-train" his workers on documental control and that was the wrong solution. I suggested that a controlled copy be made of the procedure and kept on site for their use. The controlled copy became part of the regular controlled document list.
Bill Pflanz
G
Geoff Withnell
#14
Bill Pflanz
Exactly! Get the information to the people who need it and location where it is needed.
Geoff Withnell
SpongeMouse
#15
i agree to all, most especially on re-orientations to all staff.
but to make things more secure, have all the controlled copy (if economically viable) distributed with watermarked logo or something.
another is the stamp "controlled copy", what we do is we litterary stamped all the controlled docs with RED ink, so any copy with just result in black or even colored copy will have a different result, but it will surely consume more time.
bottomline is the above mentioned... my 2 cents ;)
G
Geoff Withnell
#16
Again, that does not address the issue of getting the information to the person who needs it. If the people who need the doc HAVE it, through the system, all these stamps, water marks, etc, etc ad infinitum ad nauseum are unnecessary. Photocopies of controlled documents occur because someone needs the information and can't easily get it through the official system. That is the issue that needs to be addressed.
Geoff Withnell
SpongeMouse
#17
Geoff Withnell
i aggree, your correct. this is much better. thnx mate!:)
michaelrm
#18
All our controlled documents are stored in a database – and all staff have access to view documents (security is based on department and user groups set up in active directory) – all documents when viewed are stamped on the fly when presented to the user, if the document category defines that it is a controlled document and the user prints the document it stamps the document as a
“UN CONTROLLED COPY” before printing - all users who access documents etc. are logged and tracked as some internal documents like supplier agreements and estimation quotes need to be secure as we have a high turn over of staff and some are head hunted by our competitors.
Some print management photo copiers have the ability to set up and print water marks – Cannon etc. You may want to investigate this.
Wes Bucey
#19
The point I see here is "security is deemed necessary by management" (i.e. not just because the technology is available.)
Most small outfits do not need super stringent security as long as they are reasonably assured folks who NEED the documents to perform work can get them when they need them without resorting to keeping a secret stash.
Sidney Vianna Interesting Discussion UNI/PdR 42:2018 - Preventing and Combating Bullying Guidance Standard Other ISO and International Standards and European Regulations 5
G Setup Part Management - Preventing Escape Manufacturing and Related Processes 13
C Preventing Torque Wrench Deterioration Calibration Frequency (Interval) 5
I RoHS vs Non-RoHS - Best Practice for preventing Cross-Contamination? RoHS, REACH, ELV, IMDS and Restricted Substances 1
T How to preventing the drawing revision not being up to date Preventive Action and Continuous Improvement 1
T Preventing Wrong Terminal Crimped on a Wire Harness Manufacturing and Related Processes 7
Q Preventing Audit Finding by your third Party Registar IATF 16949 - Automotive Quality Systems Standard 5
K Preventing Shortage of Product Quantity - Hand Count and Scale Count Manufacturing and Related Processes 13
Richard Regalado ISO 27001 A.10.4.1 - Detecting, Preventing and Recovering from Malicious Code Threats IEC 27001 - Information Security Management Systems (ISMS) 3
M Preventing Missed Welds on Assemblies Manufacturing and Related Processes 4
S What are the common Problems preventing (Gaps) Implementation of ISO 14001? ISO 14001:2015 Specific Discussions 7
W Chain of Custody for Documents - Preventing Misplaced SOPs Document Control Systems, Procedures, Forms and Templates 4
Q Preventing, corrective for valves in field? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Preventing Set Up Parts from getting in with Finished Goods Manufacturing and Related Processes 17
A Preventing Quality System Non-conformities QS-9000 - American Automotive Manufacturers Standard 5
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CS2 (Controlled Shipping Level) by GM - CB notified. What about other customers? IATF 16949 - Automotive Quality Systems Standard 1
R Digital Storage of ITAR Controlled Documentation Other ISO and International Standards and European Regulations 7
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
