Preventing Shortage of Product Quantity - Hand Count and Scale Count
K
KCIPOH
Hello Cove members,
I would like to seek help on our injection molding production regarding shortage of product quantity being weigh by counter-hand in production.
Work flow :
1. production operator will inject the part and put in assigned carton box for a particular product (operator will not count the qty at this stage)
2. the carton box which is full will then transfer to QC station for inspection, QC will inspect the parts and reject parts will be segregated out into a basket (which they put at the side of the station) and after finished inspection for that particular carton box, QC will chop on the carton slip for that carton box. (QC will not count the qty at this stage also)
3. Counter-hand will then take the inspected carton box from the QC station to check the product qty in the carton box vs the qty written on the carton slip.
Counter-hand is checking the qty by weighing the carton box with digital scales (the unit weight and number of pcs for a particular product has been set as product code in the scale by production shift leader, any error, shift leader will reset the program fr the particular product code) and counter-hand will only need to select the product code on the digital scale each time they want to check the qty through weighing the filled carton box on the digital scale.
Note : counter-hand (1 shift 1 counter-hand, 2 shifts, 12 hour/shift) job is to preparing the carton slip in advance for the product to be run in their own shift and responsible to check the product qty in a carton box inspected by QC.
"QTY ARE CHECKED BY COUNTER-HAND ONLY, NO OTHER PARTY TO VERIFY IT, ONLY THE DIGITAL SCALE"
Questions :
a) Since counter-hand only check the product qty in the carton box by referring to the "number of pcs" displayed on the digital scales and not counting it physically (piece by piece) since the qty is quite huge (~800pcs to 2000pcs) how can they really assure the, let say 800 pcs being displayed by the scales are really 800 pcs inside the carton box? The scale are calibrated externally as per scheduled.
b) is there any suggestion on how to error proof this problem from re-occur by using low-cost or economy yet effective method?
This issue happened in the past but not so frequent and it happened to our toothbrush product in the past track record compared to our household and industrial container product which is bigger in size and much more easier to count and whenever it occur, we just top up the shortage qty to our customers.
I would like to improve this issue.
Really need suggestion from cove members.
Appreciate and Thank You. :confused:
Stijloor
Re: Prevent shortage of product quantity
Hello Cove members,
Work flow :
Questions :
Can someone help?
Thank you!!
Stijloor.
qusys
Hello Cove members,
Work flow :
Questions :
Did you perform a risk analysis for this process flow ( for example, FMEA).
This could help to understand and evaluate the risk and just in case take action based upon Risk Priority Number.
It is a good method to assure objectivity and it is valuable because it involve all counteparts , assuring multidisciplinary approach.
Howver, just to share idead and advices, I do not know if you have evaluate the chance to use bar code reader in this counting and loading in associated electronic system.
The process flow should have some modification , applying a label with electronic code to each item to count. The operator could shoot each time and the system will have the final count at the end of the operation.
If there are many itam, you can think to apply an unique label to an equal small quantity of times and packed them with plastic ( for istance, 10 items with one label).
hope this helps:bigwave:
AgnieszkaSz
The method will depend on product shape and weight, but I can guess that your details are not big, because the batching quantities you mentioned are huge.
We used to throw our parts - rather light - through a small hole into a box; on its way, the part cut the light beam emitted by a sensor; the sensor itself was connected to a counter. The counter opened the box only after demanded quantity was reached.
That was built in-house and relatively cheap.
Mind that there was a need to put these details into the box piece by piece. This can raise the operation time - and affect the profit.
K
KCIPOH
Hello Stijloor,
Thanks for getting other to help :thanks:
Hello Dominic,
I'm quite new to process improvements tools such as using FMEA as suggested? fyi, i'm the employee with higher education and the rest of the management staff are lower education, just wondering how to get to work out with me in this situation? by the way, can you refer me so that i can get a better idea of what a FMEA is and how to apply it in my production workflow improvements?
I'm thinking of this initially but havent been brought it to discussion with management, i will look into it but is there any simple, economy yet effective method for the improvement? pls advice.
Thank You and appreciate :agree:
Hello AgnieszkaSz
Thank you for your suggestion but as i mentioned to Dominic, i still hope for a much simple, economy yet effective method for the improvement, any idea you can help me with this?
Thank You and Appreciate your feedback soon:thanx:
qusys
Hello Stijloor,
Hello Dominic,
Hello AgnieszkaSz
Hi, appreciated your thanks!
As to FMEA , you can have some indication on this link ( I made a research in the forum):
https://elsmar.com/elsmarqualityfor...files&sortby=filename&pageamt=1&criteria=FMEA
You can also click on "more free files", there are other documents.
In brief, Failure Mode and Effect Analysis is a method to prevent potential failure mode in a process, activity, product .
There is a risk analysis and if the risk is high, the organization should put in place controls to improve detection, decrease occurrence etc...
On your case, before taking some action, you should assess if there is a really issue or not, if you want to "live" with this issue or it is dangerous for your business.
:bigwave:
Golfman25
First, what is the big deal if your counts are off?
Second, the best way to scale count is to calibrate and confirm the scale with each count. We have a scale which you start by putting in 25 or 50 pcs. The scale then tells you if you need to add more pcs. Once it is ready, we add another 10 to make sure the scale counts the 10 pcs. correctly. Then we "dump" the rest of pcs. in and take the count off the scale. Pretty simple and works extremely well. Every so often, we'll get a count discrepency, but it is not the end of the world. Good luck.
W
WKHANNA
Make a weight that is equal to a known quantity of parts.
Mark the weight with the part product code & number of parts it represents.
Conduct periodic checks during the shift on the scale using the weight (now used as a Standard).
You could even put the 'Standard' in your calibration system if you want.
K
KCIPOH
Hello Dominic,
Thanks for your explanation and reference, so far this has not been a major issue from our customer, just thinking whether there is any option for me to do things better.
Thank you again and appreciate:applause:
Hello Golfman25, WKHanna,
Thank you for your inputs, but i think if i'm not misunderstanding, the propose method are currently being practice by our counter-hand, currently this has not been a critical issue from our customer, will look into your suggestions.
Appreciate and Thank you :)
