Preventive Action (PA) and Corrective Action (CA) - One or Two Procedures?
One procedure or two
  • One procedure
    Votes: 64 54.7%
  • Got one, changing to two
    Votes: 8 6.8%
  • Two procedures
    Votes: 44 37.6%
  • I need more than two for my system (OUCH!!)
    Votes: 1 0.9%
  • Total voters
    117
Status
Not open for further replies.
hjilling said:
The official ISO definitions are pretty clear between CA and PA, but some old dogs don't want to accept the definitions as written. That is what leads to differing opinions, IMO.
ISO 9000-2000 (3.6.4 Note 2):
Preventive action is action taken to prevent occurrence whereas corrective action is taken to prevent recurrence.
The problem with the foregoing definition is that "recurrence" is a form of "occurrence." That is, a "recurrence" is an "occurence," although an "occurrence" is not necessarily a "recurrence."
In point of fact, it doesn't make a diddly-d*mn bit of difference what I call the respective types of actions, except to hopeless pedants who have their heads inextricably stuck in the standard, rather than in the process. Stop confusing the container for the thing contained and look at the work, and the results of the work if you want to find out about the efficacy of the system.Some "old dogs" are smart enough to follow the right scent and not be fooled by inconsequential distractions.
Helmut Jilling
Auditor / Consultant
Aw, c'mon, Jimmie...you may be an ol' dog on some posts...but this time around, your kind wasn't the kind I was talkin' bout.
The post I replied to was commenting on the confusion between what is correction (reactive) and what is preventive action (proactive).
The old dogs I was talking about were those who cling to the twenty year old paradigm of corrective actions become preventive and lump it all together into a mush.
I agree the container and titles are not the issue. However the ISO paradigm that proactive is better than reactive, that is extremely important. Most failures could be prevented if we were proactive.
arff...
PS: by the way, what's a pedant? Isn't that those dirty ol' men that have to register with the cops when they move?
ScottK
Not out of the crisis
Re: Corrective Action (CA) and Preventive Action (PA) - One or Two Procedures?
I'm going to have one procedure, one tracking database, but two forms.
does that make sense?
CarolX
Sure, why not...if it works. I actually have a multitude of PA forms, since we clasify calibration, preventive maintinance and engineering change orders as PA. They each have a seperate form.
Statistical Steven
Statistician
One procedure is sufficient, but remember they are two different processes. Corrective Action fixes the problem. Usually you put in place a preventative action to reduce or eliminate the problem, but preventative action processes should also include actions taken BEFORE a problem arises. Make sense?
jbGUERRA
:frust:
I too have been struggling with this PA -vs- CA issue.
Question: The both 8.5.2 and 8.5.3 state; "A documented procedure SHALL be established to define requirements for...." wouldn't you interpret this as 2 documents rather than combining the two?
I'm looking for direction prior to my upcoming August audit; your feedback is very much appreciated.
Sidney Vianna
Post Responsibly
You can do it either way.
From http://isotc.iso.org/livelink/livelink/3816351/APG-PreventiveAction.doc?func=doc.Fetch&nodeid=3816351
Note: The combination of corrective action and preventive action documented procedures into a single QMS document is acceptable, but is not recommended. If these are combined, then it is important for the auditor to verify that the organization understands clearly the difference between the intent of corrective and preventive actions.
jbGUERRA said:
:frust:
Try not to squeeze more out of the standard than you need to. In addition to Sidney's direct advice, look at the phrase "documented procedure." It's not a redundancy, it's referring to two different things: the procedure (the process) and the documentation of it. In other words, the standard is saying that it's not enough to have a process; the process also has to be documented. In other cases there is no requirment for processes to be documented. So when the two clauses both say that a "documented procedure" is necessary, just substitute "process" for "procedure" and you'll see why it's permissible to have a single document.
CarolX
jbGUERRA said:
:frust:
I have one top level procedure and a variety of lower level work instructions decribing how to accomplish all the points in my procedure.
For example - we clasify calibration and preventive maintainence as part of our PA system. I have seperate work instruction for those processes.
Status
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
B Questions regarding Non-Conformance, Corrective Action and Preventive Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
kedarg6500 Horizontal Deployment of Corrective Action - is it Preventive Action? Nonconformance and Corrective Action 21
W Are CAPAs (Corrective Action Preventive Action) Input or Outputs ISO 13485:2016 - Medical Device Quality Management Systems 6
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
A When to take Corrective / Preventive Action and Continuous Improvements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W Corrective Action, not Preventive Action? Nonconformance and Corrective Action 10
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
