Preventive Action (PA) and Corrective Action (CA) - One or Two Procedures?
One procedure or two
  • One procedure
    Votes: 64 54.7%
  • Got one, changing to two
    Votes: 8 6.8%
  • Two procedures
    Votes: 44 37.6%
  • I need more than two for my system (OUCH!!)
    Votes: 1 0.9%
  • Total voters
    117
Status
Not open for further replies.
V
Vu Nguyen
Re: Eliminate misunderstanding
Dear Manix,
CA & PA is easy to be misunderstand, but could you view the FMEA form that can show you the preventive actions, most of preventive actions are applied for big issues. Let take an example: A problem had occurred on product A, then we take CA to remove the reasons, beside we also apply PA for product B. In this case, the problem already happened on product A, but not yet happened on product B. So the PA is correct for product B only.
That is my idea, please discuss.
Thanks, Vu Nguyen
Coury Ferguson
Moderator here to help
Manix said:
Urm? Correct me if I am wrong but isn't prevention of reoccurrence the same as preventing occurrence?
How can you prevent something you do not know could exist!?
I see it as this:
Corrective action is stopping the bleed. Correcting something that is wrong. What oyu do with something you have found to be wrong.
Preventative Action is stopping the cause of the bleed from occuring again. How will you prevent it from happening. This PA can then be carried over for future Cont Imp activities to ensure the occurence cannot OCCUR!!!! :bonk:
My take (opinion) on the differences between PA and CA are as follows:
CA=To correct the initial escape/nonconformity (otherwise bandage)
PA=To eliminate the potential escape/nonconformity (process failure)
Coury Ferguson
PS: I voted for two procedures
Wes Bucey
Prophet of Profit
Coury Ferguson
I see what you describe as CA as "correction" and my definition of CA is to change the process to eliminate (as much as possible) future nonconformance.
Imagine a loose fitting causing a machine to turn out non-conforming product. A "correction" would be to tighten the fitting. A "corrective action" might be to add Loctite or other sealant to reduce the probability of future loosening.
Preventive action is an outgrowth of FMEA (Failure Mode & Effects Analysis) - essentially a "what if" exercise which allows us to build in controls into the process to reduce or eliminate the possibility of a nonconformance BEFORE any nonconformance occurs (meaning there is nothing to correct.)
In FMEA, we sit down and imagine, "What if this fitting works loose from vibration during operation? How will that affect the product? Let's put Loctite on it to reduce the chance of it working loose." Thus reducing the probability of ANY nonconformance.
Coury Ferguson
Wes, that is a good definition of PA vs CA. Yes the PA would require the "what if" questions to ensure that the potential failure/escape/nonconformity would not occur.
Coury Ferguson
Rajeeva
Quality Manager, CMQ/OE, CQA
Re: Corrective Action (CA) and Preventive Action (PA) - One or Two Procedures?
In my view, for all Corrective Action Requests, three below actions are to be implemented.
1. Remidial Action - (Immediate) - Immediate action to be implemented to make it acceptable.
2. Corrective Action - Action required to prevent the recurrance of the same in the same location/ project/ section
3. Preventive Action - Action implemented at some other location/ project/ section from the occurance of similar type of problem.
I believe that the ultimate aim of implementing all corrective actions/ preventive actions is to ensure the elimination of non-conformances. So the preventive action is effective only if the implemented corrective action is able to prevent the recurrance of the similar nonconformances.
Rajeev
Baldrick
Boy, this thread does seem to go round and round in circles!
Rajeeva, your number 1 and 2 are correct :agree1: but the activity you describe in number 3 is the part of the standard defined as Corrective Action Impact.
You CANNOT do preventive action in response to something that has already gone wrong.
If the problem has already happened, everything you do in response is CORRECTIVE. Stopping something happening again is CORRECTIVE ACTION. Applying this learning to other similar products and processes is CORRECTIVE ACTION IMPACT.
If you have foreseen a problem BEFORE IT HAS HAPPENED then everything you do to prevent it happening is PREVENTIVE.
Hope this helps. :)
Another way of putting it:
If your action is REACTIVE then it is CORRECTIVE
If your action is PROACTIVE then it is PREVENTIVE
RoxaneB
You'll probably find that many people will disagree with you on this to a certain degree...but I think I know what you're trying to say. Unfortuantely, not everything in Management Systems is so black-and-white.
I look at like this...the Corrective Action methodology can (and should) include Preventive Action, however, not all Preventive Actions are generated from a Corrective Action.
Situation
I'm going out for a long bike ride. Suddenly, my rear tires goes flat, my chain slips off and my brakes fail to work. Thankfully, I manage to roll my bike (and myself) into a soft field of grass. Phew!
Correction
Apply patch to tire and reinflate. Slip chain back on. Bike slowly home.
Corrective Action (developed after root cause analysis)
1. Purchase and install new tire.
2. Bring bike in to shop for service.
3. Bring all bikes of family members in for service, as well (don't want this to happen to them!)...sounds rather preventive.
4. Bring bikes in for tune-up prior to spring cycling season...rather preventive, too, don't you think?
Of course, the solely Preventive situation would involve a scenario where I am out for a bike ride and I find that my bike is becoming increasing more difficult to stop and my butt is beginning to hurt from the low pressure in the tire.
Preventive Action would have me bring in my bike before something horrible happens...better yet, Preventive Action would have me doing regular tune-ups and inspections of my bike so that I don't even have to worry about the brakes or tire pressure.
I'm all for simplicity...but just keep in mind that a proper corrective action, will include proactive steps...actions that go behind merely fixing the description of the corrective action, but may apply to other areas.
We had a recent external audit finding where a micrometer was found to past due for calibration.
We calibrated it...correction.
We ensured that it had a history set-up in the software to ensure it wouldn't be missed again...corective action.
We checked every other piece of equipment in the software to ensure that it had a history which would guarantee a reminder of every calibration due date...preventive action within a corrective action.
Baldrick
Situation
Correction
People are entitled to disagree, but I stand by everything I wrote.
The steps you talk about taking in your examples which you cite as "Preventive" are not Preventive Action - they have only come about as a result of something which went wrong - this puts them under the category of CORRECTIVE ACTION. In the case of some of your steps, CORRECTIVE ACTION IMPACT.
Had you thought to do these things BEFORE your mishap, they would have been PREVENTIVE ACTION.
Remember, we are not debating the meanings of English words - we're debating what the standard requires, and how the standard defines these terms.
In your examples, which steps would you define as the Corrective Action Impact? This is a required clause of the standard which no-one seems to remember. :nope: But it defines the type of action you describe as "preventive action within a corrective action".
All of the terms we're using are clearly defined in the standard - I understand there is still a lot of confusion, but people will grasp things a lot easier if they start by accepting the basic premise I mentioned previously:
BY DEFINITION - You CANNOT do preventive action in response to something that has already gone wrong.
Preventing something happening AGAIN is called CORRECTIVE ACTION IMPACT.
Regards,
Alex
Rajeeva
Hope this helps. :)
It is good to start with common ground i.e., you agree for number 1 & 2. The lesson learnt or the action implemented is effective and if you implement at another location/ project/ section (where this kind of problem may occur but not occured so far), then # 3 is the preventive action.
Rajeev
Status
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
B Questions regarding Non-Conformance, Corrective Action and Preventive Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
kedarg6500 Horizontal Deployment of Corrective Action - is it Preventive Action? Nonconformance and Corrective Action 21
W Are CAPAs (Corrective Action Preventive Action) Input or Outputs ISO 13485:2016 - Medical Device Quality Management Systems 6
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
A When to take Corrective / Preventive Action and Continuous Improvements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W Corrective Action, not Preventive Action? Nonconformance and Corrective Action 10
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
