Preventive Action (PA) and Corrective Action (CA) - One or Two Procedures?
One procedure or two
  • One procedure
    Votes: 64 54.7%
  • Got one, changing to two
    Votes: 8 6.8%
  • Two procedures
    Votes: 44 37.6%
  • I need more than two for my system (OUCH!!)
    Votes: 1 0.9%
  • Total voters
    117
Status
Not open for further replies.
SteelMaiden
Re: Corrective Action (CA) and Preventive Action (PA) - One or Two Procedures?
Say I want to add rubber protection pads to a fixture to prevent nicks/scratches on parts.Should I have to (or need to) send the PA to my QA director for review,then he passes it on to the department head,then back to him for review/exceptance or rejection.What do you think?
In the interest of making sure that 1) your preventive action does not negatively impact downstream operations, 2) preventive actions are assessed for possible implementation (or similar implementation) elsewhere in your facility, why would you NOT send it through your QA Director (or some other "gatekeeper") to help keep the lines of communication open?
Now, in your scenario of protection pads, it might not be a problem, but in my business if someone decides to turn the cooling water down on a new grade to improve something, we might want to look at the downside, or scale build-up, to see the negative impact.
I think that the biggest misunderstanding we perpetuate about preventive actions is that they are somehow less worthy of scrutiny than their cousin corrective actions. The impact of preventive actions to the bottom line can be as great as corrective actions, or greater (because if you fix it before it breaks, you aren't going to pay the customer).
Now, that being said, you most certainly may find that 2 procedures are useful. It makes no difference within the ISO requirements, 1, 2 or 20, as long as you have documented procedures that cover all the requirements. Do what works best for you and your company.
Yes! :agree1: The #1 rule in problem solving: Make sure that your "solution" doesn't create a different problem.
qcman
Registered Visitor
I agree 100% and assumed a complete review of a PA would be taken for granted in my post (it would be).My point is I do a lot of little things everyday that would fall under preventive action but I guess nothing says I have to write everything up.
Helmut Jilling
Auditor / Consultant
CA or PA should be appropriate to the magnitude of the risk and issues.
The little stuff should just be done. If it takes longer to fill out the form than to do the action, just do it.
I suggest the CA or PA form should be used to help you determine the cause and appropriate actions. So, if you know the cause, and the actions are obvious, and it is not a big issue, just do it. Save the paperwork for when it serves a purpose.
Juliana - 2008
Our Registration Auditor required 2 procedures so we developed 2. Company Management never understood nor accepted Preventive Action as a seperate entity; "its not how WE do things - not our culture". We maintained our registration less than 18 months. We would have done much better with only one procedure. We still "maintain" a Quality Management System - but now its going "Lean". Guess what managment decided was waste in our "Lean Quality Management System"? :biglaugh:
Rezzi
I think the best you can do as a start is to require that your registrar sends you a new auditor. The auditor may recommend 2 separate procedures and if its true as you mention that the auditor actually required you to have 2 separate procedures, you should then report that to the registrar so that they can do something and to implement corrective actions regarding their issue with incompetent auditors.
Helmut Jilling
Your comment actually has two things going on.
1. I agree that the auditor should not have required 2 procedures. He overstepped. 1 or 2 would meet the requirement either way.
2. However, this statement:
"Company Management never understood nor accepted Preventive Action as a seperate entity; "its not how WE do things..."
is not right. Preventive Action is a separate entity. They are two different kinds of projects. Please reread the definitions in ISO 9000:2000. Preventive actions prevent the occurrance of a root cause.
Corrective actions prevent the REoccurrance of a root cause.
The reason why one procedure can address both is because they are similar. But you still need two sections, or some way to explain the difference between the two.
Juliana - 2008
Although the process developers understood the nuances between these two processes, many in management could not see the benefit of preventive action, especially documenting preventive action. They felt that it was a hindrance to change (no one need explain how it would benefit, I know and have talked myself blue in the face - that's when I hear that "It's not our culture"). Following this thread got me wondering how or if we could have written preventive and corrective action together to get more acceptance and utilization. I will keep it in mind for the future since it is now a moot point - top managment changed and almost the first thing done was to drop our Quality Management System registration and the requirement to follow some of the procedures they didn't see a need for, preventive action was one. At the moment those of us still involved in what is called a quality managment system are doing our best to keep the system as close to the standard as we can and we wait to see what will happen with the next change in managment.
Sometimes you can lead 'em to water, but... In a similar situation I once suggested to a clueless manager that since a preventive action process wasn't necessary, we could get rid of all of the maintenance done on machines, just wait for them to break down, and save a lot of money. I also suggested that he could save some money personally by no longer changing the oil in his car. Somehow I wasn't able to convince him that processes break down just like machines do, and often with similar consequences. Fortunately he wasn't in a position of authority on the subject, and I was able to work around him, but there's always at least one.
Status
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
B Questions regarding Non-Conformance, Corrective Action and Preventive Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
kedarg6500 Horizontal Deployment of Corrective Action - is it Preventive Action? Nonconformance and Corrective Action 21
W Are CAPAs (Corrective Action Preventive Action) Input or Outputs ISO 13485:2016 - Medical Device Quality Management Systems 6
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
A When to take Corrective / Preventive Action and Continuous Improvements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W Corrective Action, not Preventive Action? Nonconformance and Corrective Action 10
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
