I was thinking about writing a program which would prevent different manufacturing plants within the organization about potential failures on electronic components (resistors, chips, condensators, etc.). The point is that for example manufacturing plant X has complaint and after investigation it looks that component X is damaged, there is a risk that whole batch is NOK, so responsible person from manufacturing plant X fills the form (few fields ) with the basic data about component type, part number. batch number, etc. and such message is sent to another manfuacturing locations. There is a big chance that some part of components are common for different locations, so they could for example block suspected batch in advance. What do you think about it? What kind of "fields" to be filled do you think migh be needed, except component type, part number, batch number?
