Preventive Maintenance Requirements - ISO 9001
Stijloor
#11
Re: Seek advice on preventive maintenance under ISO 9001
Our quality system is in compliance with ISO TS 16949 but we are only ISO 9001 certificated.
If in internal Audit we have a non conformity on maintenance we should address it to process 6.3 or 7.5 (7.5.1.4/5)?
:confused:
Refer to 7.5.1 c). However, if you have requirements (procedures, instructions, schedules, etc.) for maintenance, you should cite those when writing a nonconformity report.
Stijloor.
Ettore
#12
Stijloor.
thank you. I'm agree. Generally our thirth part auditors referred to 6.3. Have a good day. By.
I
ISO 9001 Guy
#13
If you read the standard closely (ISO 9001:2000 and 2008), there is technically no requirement for PREVENTIVE maintenance. Although there is a requirement to MAINTAIN the infrastructure, and of course preventive maintenance is generally a great idea, the standard does not require "preventive maintenance." (Some organizations, like service organizations, might have nothing to maintain "preventively" so the standard can't require it of everyone.)
Any records of maintenance generally suffice to demonstrate maintenance was performed as required of the standard. However, if your system calls for preventive maintenance, as it should if you have any kind of production operations, the auditor is correct in assessing whether you comply with your own requirements for preventive maintenance. If you do not maintain the infrastructure according to your own requirements, the auditor will rightfully raise a nonconformity.
Raffy
#15
In our end, as TS16949 Certified Company, we are required to follow the requirement of Clause 7.5.1.4 Preventive and Predictive Maintenance. :)
JaneB
#16
Sure - but that's per the other standard you quote (TS16949) and not ISO 9001.
#17
If you are claiming compliance to TS, then I would say that the TS requirement is the better fit, because there is no "shall" associated with preventive maintenance in ISO 9001. However, as already stated, you sould cite your local level documentation, since that is where the specific requriements for maintenance will probably be found.
I
ISO 9001 Guy
#18
Correct, there is no requirement for records in 6.3. But that doesn't mean that records of maintenance are not required. Record requirements reside in 4.2.4. If an organization has requirements to perform maintenance, 4.2.4 requires records are maintained to demonstrate conformity to these maintenance requirements. If an organization has no requirements for maintenance, then records are not required.
Stijloor
#19
I disagree. While it is a good practice to establish records for maintenance activities, it is not required. Other than the 4.2.4 references in the Standard, any additional records to be established are an organization's decision.
Stijloor.
I
ISO 9001 Guy
#20
ISO 9001:2008, 4.2.4 states, "Records established to provide evidence of conformity to requirements . . . shall be controlled." Conformity to requirements is not limited to requirements of the standard, but includes management's own requirements. However, if management has established requirements for maintenance, it is possible that no records of maintenance were established. (In some cases, it might be obvious that maintenance was performed, thus no records are required.) In this case, maintenance records are not required of the standard. Certainly in most cases, if maintenance is required, some record of maintenance is generated. If management needs these records to ensure maintenance is being performed as required, these records have been established as records to provide evidence of conformity to requirements and the standard requires them to be controlled accordingly.
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q ISO 9001 Clause 6.3 Infrastructure - Preventive Maintenance Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
R A GRP model that also considers the Preventive Maintenance Efficiency Reliability Analysis - Predictions, Testing and Standards 3
M Tracking Preventive Maintenance Effectively Nonconformance and Corrective Action 5
R Preventive Maintenance Checks Advice Manufacturing and Related Processes 4
M Preventive Maintenance & Operating Procedures for Measurement Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Which ISO/AS Clause directly relates to Preventive Maintenance of Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Free Preventive Maintenance Software Manufacturing and Related Processes 3
S NC Lathe Preventive Maintenance Boiler Plate checklist Reliability Analysis - Predictions, Testing and Standards 3
S Does overdue preventive maintenance require an evaluation on product quality? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Benchmarking Preventive Maintenance Sales Benchmarking 0
M Preventive Maintenance Scheduling Software recommendations Lean in Manufacturing and Service Industries 8
L Any ideas for Preventive Maintenance checklist? Quality Manager and Management Related Issues 5
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
R Who runs your Preventive Maintenance Program? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
G Preventive Maintenance for Assembly Line Bar-Code & General Printers - Necessary? IATF 16949 - Automotive Quality Systems Standard 4
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
Crusader Preventive Maintenance - Electronic Records Deleted/Erased OR Are Records Required? Records and Data - Quality, Legal and Other Evidence 62
I Preventive Action Examples, Excluding Preventive Maintenance, Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Calibration - Not willing to spend money in calibration/preventive maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Preventive Maintenance Program in a non-production facility Misc. Quality Assurance and Business Systems Related Topics 4
S Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms Document Control Systems, Procedures, Forms and Templates 8
H Preventive Maintenance - Does anyone have a sample of a PM procedure? Document Control Systems, Procedures, Forms and Templates 5
Marc Definition Preventive Maintenance - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Randy Preventive and Corrective Maintenance - Looking for a basic procedure Document Control Systems, Procedures, Forms and Templates 19
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
N 3% of the scheduled preventive maintenance (PMs) cancelled - You make the call! Preventive Action and Continuous Improvement 11
A Preventive maintenance outsourcing - What type of controls? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
V Can an Ionizer be calibrated or perform preventive maintenance when in use? General Measurement Device and Calibration Topics 6
V Does preventive maintenance have any positive effect on smart transmitters? General Measurement Device and Calibration Topics 1
Marc Preventive Maintenance - Suppliers & Delivery Vehicles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Preventive Maintenance Interpretation - Clause 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 5
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
Marc Preventive Maintenance & Machine Manual Control QS-9000 - American Automotive Manufacturers Standard 0
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
