Preventive Maintenance Requirements - ISO 9001
I
ISO 9001 Guy
#32
Re: Seek advice on preventive maintenance under ISO 9001
Amazing. Even with the TC 176 ruling in your face, you are still trying to make up your own rules. TC 176 WROTE THE STANDARD!
Also, you may or may not have noticed that there is no reference to 4.2.4 in element 6.3.
The question posed in your TC 176 ruling is, "Does 6.3 require maintenance records?" The answer from TC 176 is precise and correct: no. Although 6.3 requires maintenance, it does not contain a record requirement. From this we cannot infer that ISO 9001 never requires records of maintenance. (Well, apparently some can . . .)
4.2.4 requires records to provide evidence of conformity to requirements. IF management has established records requirements for maintenance (and many do), then these records must be maintained as evidence to conformity of requirements. That way, management can tell whether maintenance is being done as required.
To more directly address the "in your face" comment, I am fully aware that TC 176 wrote the standard; for you to assert that your cited reference means that TC 176 says records of maintenance are not required is not being precise. All your reference says is that records of maintenance are not required of 6.3. If management requires records--including maintenance records--ISO 9001 requires them to be maintained per 4.2.4 to provide evidence of conformity to requirements. Also, to address your concern that I overlooked the fact, I am keenly aware that there is no reference to 4.2.4 in element 6.3. In fact, that's what I stated in the very quote you took from my posting: "Correct, there is no requirement for records in 6.3". :)
Helmut Jilling
Auditor / Consultant
#33
Can you cite the "shall" for that?
ummm, well, you might want to try 4.2.4:
4.2.4 Control of records
Records shall be established and maintained to provide evidence of conformity to requirements and of the effective operation of the quality management system.
...:cool:
Note: it does not state records are only required for those clauses where the standard makes a reference that records are required. I don't take that reference to be that exclusive.
Big Jim
#34
...:cool:
As long as you are quoting it, you might as well quote it correctly. When quoted correctly the shall just isn't there.
4.2.4 Records established to provide evidence of conformity to requirements and of the effective operation of the quality management system shall be controlled.
Perhaps you mixed part of the next paragraph in.
The organization shall establish a documented procedure to define the controlls needed for the identification, storage, protection, retrieval, retention and disposition of records.
Big Jim
#35
I am very aware that if an organization says in their documentation that they will keep maintenance records then they need to. That's pretty much true of anything they decide needs to be part of their QMS even if it is above and beyond the requirments of the standard.
If they choose to do maintenance and not keep records they are free to do so unless they say they will keep maintenance records.
I
ISO 9001 Guy
#36
Jim, you wrote:
"As long as you are quoting it, you might as well quote it correctly. When quoted correctly the shall just isn't there. [Italics mine.]
4.2.4 Records established to provide evidence of conformity to requirements and of the effective operation of the quality management system shall be controlled."
Come on, now. The shall is clearly there--in your own citation of the requirement! Can't you put your finger on the SHALL in the above requirement?
samsung
#37
IMO the above sentence does not mandate records to be maintained. I interpret it as emphasizing more on 'control' of records, if established. If it had to emphasize the need for establishing records, the sentence would probably have begun as,
'Records shall be established or maintained to provide............ The records shall be controlled....or like that.
Later, Sorry I failed to see it before. Helmut had already quoted it.
Just have a look at the attached interpretation of Clause 6.3 (Infrastructure),
Helmut Jilling
#38
Jim, I took it straight from the standard -
4.2.4 Control of records (ISO 9001:2000) -
Records shall be established and maintained to provide evidence of conformity to requirements and of the effective operation of the quality management system. Records shall remain legible, readily identifiable and retrievable. A documented procedure shall be established to define the controls needed for the identification, storage, protection, retrieval, retention time and disposition of records.
4.2.4 Control of records (ISO 9001:2008) -
The 2008 version of the standard moved the word "shall" to the back of the sentence, but it does not materially change the meaning of the requirement. The standard requires people to demonstrate conformity to requirements. That is the backboone of the whole auditing program. I guess I don't see how the slight rewording changes the intent.
Helmut Jilling
#39
...If they choose to do maintenance and not keep records they are free to do so unless they say they will keep maintenance records.
Well, somehow they will need to demonstrate that they have a suitable maintenance program. Typically, that includes records. I suppose that could be done without records, but it would be rather unusual. Metrics maybe.
Big Jim
#40
Perhaps I see the TC 176 ruling differently than you do. It tells me that records are not required for maintenance. The exception would be when an organization chooses to keep records.
The requirement for keeping records for maintenance does not come from element 6.3.
And it doesn't come from 4.2.4 either. "Records established to provide evidence of conformity . . ." If records are not established they do not need to be controlled. Who gets to determine if records need to be established? Except for the places in the standard where 4.2.4 are cited, THE ORGANIZATION GETS TO DECIDE. Auditors don't have a say it that.
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q ISO 9001 Clause 6.3 Infrastructure - Preventive Maintenance Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
R A GRP model that also considers the Preventive Maintenance Efficiency Reliability Analysis - Predictions, Testing and Standards 3
M Tracking Preventive Maintenance Effectively Nonconformance and Corrective Action 5
R Preventive Maintenance Checks Advice Manufacturing and Related Processes 4
M Preventive Maintenance & Operating Procedures for Measurement Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Which ISO/AS Clause directly relates to Preventive Maintenance of Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Free Preventive Maintenance Software Manufacturing and Related Processes 3
S NC Lathe Preventive Maintenance Boiler Plate checklist Reliability Analysis - Predictions, Testing and Standards 3
S Does overdue preventive maintenance require an evaluation on product quality? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Benchmarking Preventive Maintenance Sales Benchmarking 0
M Preventive Maintenance Scheduling Software recommendations Lean in Manufacturing and Service Industries 8
L Any ideas for Preventive Maintenance checklist? Quality Manager and Management Related Issues 5
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
R Who runs your Preventive Maintenance Program? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
G Preventive Maintenance for Assembly Line Bar-Code & General Printers - Necessary? IATF 16949 - Automotive Quality Systems Standard 4
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
Crusader Preventive Maintenance - Electronic Records Deleted/Erased OR Are Records Required? Records and Data - Quality, Legal and Other Evidence 62
I Preventive Action Examples, Excluding Preventive Maintenance, Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Calibration - Not willing to spend money in calibration/preventive maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Preventive Maintenance Program in a non-production facility Misc. Quality Assurance and Business Systems Related Topics 4
S Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms Document Control Systems, Procedures, Forms and Templates 8
H Preventive Maintenance - Does anyone have a sample of a PM procedure? Document Control Systems, Procedures, Forms and Templates 5
Marc Definition Preventive Maintenance - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Randy Preventive and Corrective Maintenance - Looking for a basic procedure Document Control Systems, Procedures, Forms and Templates 19
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
N 3% of the scheduled preventive maintenance (PMs) cancelled - You make the call! Preventive Action and Continuous Improvement 11
A Preventive maintenance outsourcing - What type of controls? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
V Can an Ionizer be calibrated or perform preventive maintenance when in use? General Measurement Device and Calibration Topics 6
V Does preventive maintenance have any positive effect on smart transmitters? General Measurement Device and Calibration Topics 1
Marc Preventive Maintenance - Suppliers & Delivery Vehicles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Preventive Maintenance Interpretation - Clause 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 5
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
Marc Preventive Maintenance & Machine Manual Control QS-9000 - American Automotive Manufacturers Standard 0
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
