Preventive Maintenance Requirements - ISO 9001
Helmut Jilling
Auditor / Consultant
#41
Re: Seek advice on preventive maintenance under ISO 9001
Perhaps I see the TC 176 ruling differently than you do. It tells me that records are not required for maintenance. The exception would be when an organization chooses to keep records.
The requirement for keeping records for maintenance does not come from element 6.3.
And it doesn't come from 4.2.4 either. "Records established to provide evidence of conformity . . ." If records are not established they do not need to be controlled. Who gets to determine if records need to be established? Except for the places in the standard where 4.2.4 are cited, THE ORGANIZATION GETS TO DECIDE. Auditors don't have a say it that.
I agree. However, it is incumbent on the organization to demonstrate evidence that systems are effective and meet requirements. In this case, that maintenance is suitable. This may cause them to decide to maintain records.
Big Jim
#42
I absolutely agree.
And if they decide not to keep records, that makes an auditor's job harder. He may need to observe their practice. He may need to look at equipment to see if it is obviously falling apart. He may need to ask question about how and when maintenance is performed.
Is this the preferred way? In my opinion it is not, but we need to play the hand that is delt.
I
ISO 9001 Guy
#43
Precisely, Jim! If management has established records requirements, then the STANDARD REQUIRES that those records are maintained and controlled. So, if management has established record requirements, THESE RECORDS ARE WITHIN THE SCOPE OF A QMS AUDIT. So, an auditor SHOULD verify that records are being maintained AS REQUIRED.
#44
I absolutely agree.
What about objective evidence? 6.3 requires maintenance of infrastructure, and if "the organization" has its own documented requirements for machine maintenance, how does an auditor verify that the maintenance has been done if there are no records? The fact that a machine is operating normally (or it's not "obviously falling apart") is evidence, but not objective evidence.
Look at it this way: say a company has, for a particular product, a documented requirement for final inspection, but the requirement doesn't explicitly call for records to be kept.. On the day of the audit, that product isn't running, so it's not possible to actually see inspection being done. Given the opinions here on maintenance, we should apply the same logic and say that we can just assume that inspections were done because there's no history of rejections for the product in question.
So the question is: how does an auditor verify a documented requirement in the absence of objective evidence?
Brunetta
#45
Wouldn't the same techniques for auditing an undocumented process apply?
Couldn't an auditor pointedly ask from several auditees when the maintence occurred?
If the answers are the same, coupled with the evidence mentioned before, then wouldn't this be a body of objective evidence?
Stijloor
#46
Yes.
From ISO 19011:
3.3
audit evidence
records, statements of fact or other information, which are relevant to the audit criteria (3.2) and verifiable
Statements of fact (auditee responses) are valid objective evidence.
Stijloor.
Big Jim
#47
I think I see what you are getting at Jim, but you chose a poor example. There is a requirement to keep records for inspection.
I
ISO 9001 Guy
#48
Correct, there is no requirement for records in 6.3. But that doesn't mean that records of maintenance are not required. Record requirements reside in 4.2.4. If an organization has requirements to perform maintenance, 4.2.4 requires records are maintained to demonstrate conformity to these maintenance requirements. If an organization has no requirements for maintenance, then records are not required.
I also disagree (with myself). I should have said, "If an organization has requirements to retain maintenance records, 4.2.4 requires records are maintained to demonstrate conformity to these maintenance requirements. If an organization has no requirements for maintenance records, then records are not required."
samsung
#49
Yes.
From ISO 19011:
Stijloor.
But IMO, Jim was referring to 'Objective Evidence' which is what the auditor needs to aim at. Even if all (auditees) are telling the same thing, how can it become an objective evidence. All can unanimously tell a lie to invalidate the 'statement of fact'. These 'facts' are valid until proved otherwise by the auditor through analysis, measurement, observation or some sort of research to ensure the validity of the statement.
#50
There's a difference between evidence (objective or otherwise) and proof. While several auditees might tell the same lie, it's also possible that documents have been falsified in concert with the verbal prevarications. Whether there's evidence for something or a lack thereof, an eternal auditor has to work with what he's given or what he can discover in a limited amount of time and understand that there's very little absolute proof in any case.
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q ISO 9001 Clause 6.3 Infrastructure - Preventive Maintenance Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
R A GRP model that also considers the Preventive Maintenance Efficiency Reliability Analysis - Predictions, Testing and Standards 3
M Tracking Preventive Maintenance Effectively Nonconformance and Corrective Action 5
R Preventive Maintenance Checks Advice Manufacturing and Related Processes 4
M Preventive Maintenance & Operating Procedures for Measurement Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Which ISO/AS Clause directly relates to Preventive Maintenance of Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Free Preventive Maintenance Software Manufacturing and Related Processes 3
S NC Lathe Preventive Maintenance Boiler Plate checklist Reliability Analysis - Predictions, Testing and Standards 3
S Does overdue preventive maintenance require an evaluation on product quality? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Benchmarking Preventive Maintenance Sales Benchmarking 0
M Preventive Maintenance Scheduling Software recommendations Lean in Manufacturing and Service Industries 8
L Any ideas for Preventive Maintenance checklist? Quality Manager and Management Related Issues 5
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
R Who runs your Preventive Maintenance Program? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
G Preventive Maintenance for Assembly Line Bar-Code & General Printers - Necessary? IATF 16949 - Automotive Quality Systems Standard 4
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
Crusader Preventive Maintenance - Electronic Records Deleted/Erased OR Are Records Required? Records and Data - Quality, Legal and Other Evidence 62
I Preventive Action Examples, Excluding Preventive Maintenance, Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Calibration - Not willing to spend money in calibration/preventive maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Preventive Maintenance Program in a non-production facility Misc. Quality Assurance and Business Systems Related Topics 4
S Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms Document Control Systems, Procedures, Forms and Templates 8
H Preventive Maintenance - Does anyone have a sample of a PM procedure? Document Control Systems, Procedures, Forms and Templates 5
Marc Definition Preventive Maintenance - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Randy Preventive and Corrective Maintenance - Looking for a basic procedure Document Control Systems, Procedures, Forms and Templates 19
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
N 3% of the scheduled preventive maintenance (PMs) cancelled - You make the call! Preventive Action and Continuous Improvement 11
A Preventive maintenance outsourcing - What type of controls? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
V Can an Ionizer be calibrated or perform preventive maintenance when in use? General Measurement Device and Calibration Topics 6
V Does preventive maintenance have any positive effect on smart transmitters? General Measurement Device and Calibration Topics 1
Marc Preventive Maintenance - Suppliers & Delivery Vehicles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Preventive Maintenance Interpretation - Clause 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 5
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
Marc Preventive Maintenance & Machine Manual Control QS-9000 - American Automotive Manufacturers Standard 0
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
