Preventive Maintenance Scheduling Software recommendations
mitch37
Hi Guys
I was just wondering about PM scheduling software that can be used in a plant/factory etc. Any good ones that someone recommends? Any free ones?
BradM
Mitch, I'm sorry I did not get back with you. I meant to post, but I got distracted.
From my experience, maintenance scheduling is not too unlike calibration scheduling. Check out this thread: Calibration software
It will depend on how involved you want to get. As mentioned in the other thread, Excel can work pretty well just keeping track of the dates and all. Icy Mountain provided an Access application you could adapt and adjust for it.
If you really want to get into specialized application like printing spare part reorders, detailed time reports, and such, Maximo is a good program. Unfortunately, it's not free.:)
Hope something helps.
N
Neil V.
We use the Preventive Maintenance database that is built into our MRP system (Hennings Esti-Track). We just got the bugs worked out and paid for some additonal programming to suit our needs. We are keeping it pretty basic, frequency of PM, last complete, next due, list of items to complete, notes for future (filter p/n's, oil type, etc.), and maintenance personel sign off. As i'm told is usually the case, the PM portion of the MRP system seems to be an afterthought. Previously we used a software program called Quality Link (must purchase). It was cumbersome to use, hence our switch, however this system is not much better (as far as user friendliness). So, we are forced to have somone from the office with computer skills do all the data entry and print off maintenance assignments, which we were trying to avoid. Not sure if the end user will be an issue in your case or not, just a thought.
mitch37
Thanks BRAD...no need to apologise. will take a look at the the calibration software and see what it is about :)
Neil..thanks for your input as well. Much appreciated.
tsmith7858
I have seen several places that have been succesful with Access Data bases but you need to have someone that knows how to set it up. I have set up PMs on excel in the past but it requires a lot of back end work if you want to use it to track the PMs. We just printed out schedules and kept hard copies as records. Depends on your scope on whether either are viable.
As mentioned, many MRPs include PM modules. This is also true for a lot of QMS software that is available.
My current company uses MP2 (from Infor/Datastream) whichs ties together MRO tracking, purchasing, preventive and predictive maintenance. It is a good program at a cost and a previous employer also used it.
D Scott G
Greetings;
I would also recomend the MP2 program I have implemented it in a facility and used it for the PM program and more. It requires a lot of up front work, the data base must be set up perfectly, but with some tech support you can do it. i tracked mold, machine and assembly equipment PM's.
It will also track tons more, parts inventory, personell data and reorder points.
The self designed access data base is not nearly as useful and as stated above you need a access guru.
Scott
mitch37
Thanks Guys. My colleague has performed a SWOT analysis on 4 packages - Maintenance Pro (IMS);MAPCON (Lite);PM Coordinator CMMS (webpage) and PMXpert CMMS. Any thoughts?
Checking out MP2...it looks pretty darn good :)
P
palmer
We use maintscape by GrandRavine Software limited. It is used in 7 plants. We are quite happy with it.:cool:
S Netsuite Preventive Maintenance and Calibration Manufacturing and Related Processes 0
G Why do you guys think ISO 9001 doesn't ask specifically for preventive maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
R A GRP model that also considers the Preventive Maintenance Efficiency Reliability Analysis - Predictions, Testing and Standards 3
M Tracking Preventive Maintenance Effectively Nonconformance and Corrective Action 5
R Preventive Maintenance Checks Advice Manufacturing and Related Processes 4
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
M Preventive Maintenance & Operating Procedures for Measurement Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Which ISO/AS Clause directly relates to Preventive Maintenance of Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
R Free Preventive Maintenance Software Manufacturing and Related Processes 3
S NC Lathe Preventive Maintenance Boiler Plate checklist Reliability Analysis - Predictions, Testing and Standards 3
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Does overdue preventive maintenance require an evaluation on product quality? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Benchmarking Preventive Maintenance Sales Benchmarking 0
Q ISO 9001 Clause 6.3 Infrastructure - Preventive Maintenance Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
L Any ideas for Preventive Maintenance checklist? Quality Manager and Management Related Issues 5
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
R Who runs your Preventive Maintenance Program? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
G Preventive Maintenance for Assembly Line Bar-Code & General Printers - Necessary? IATF 16949 - Automotive Quality Systems Standard 4
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
Crusader Preventive Maintenance - Electronic Records Deleted/Erased OR Are Records Required? Records and Data - Quality, Legal and Other Evidence 62
I Preventive Action Examples, Excluding Preventive Maintenance, Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Calibration - Not willing to spend money in calibration/preventive maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Preventive Maintenance Program in a non-production facility Misc. Quality Assurance and Business Systems Related Topics 4
S Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms Document Control Systems, Procedures, Forms and Templates 8
G Preventive Maintenance Requirements - ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
H Preventive Maintenance - Does anyone have a sample of a PM procedure? Document Control Systems, Procedures, Forms and Templates 5
Marc Definition Preventive Maintenance - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Randy Preventive and Corrective Maintenance - Looking for a basic procedure Document Control Systems, Procedures, Forms and Templates 19
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
N 3% of the scheduled preventive maintenance (PMs) cancelled - You make the call! Preventive Action and Continuous Improvement 11
A Preventive maintenance outsourcing - What type of controls? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
V Can an Ionizer be calibrated or perform preventive maintenance when in use? General Measurement Device and Calibration Topics 6
V Does preventive maintenance have any positive effect on smart transmitters? General Measurement Device and Calibration Topics 1
Marc Preventive Maintenance - Suppliers & Delivery Vehicles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Preventive Maintenance Interpretation - Clause 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 5
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
