Definition Preventive Maintenance vs. Predictive Maintenance - Distinction between
darkafar
Case description:
One manufacturer designates 22 machines as key equipments needing planned maintenance. This company has daily, weekly, monthly and yearly planned maintenance. When asked, their maintenance director said, “We have a very good maintenance system. In the past two years the equipments have never been down by accident.” When asked for relevant data, he said that because the equipments hadn’t been down they had no data.
A senior auditor suggested this company violated TS2 clause 7.5.1.4, saying they didn’t have a predicative maintenance system.
I found I disagree with him, because I think the daily, weekly, monthly and yearly maintenance can be counted as both preventive maintenance and predicative maintenance. I think I might be a little confused with the distinction preventive maintenance and predicative maintenance. May someone help to explain the difference between the two kinds of maintenance?
Govind
Re: distinction between preventive maintenance and predicative maintenance
Case description:
..... I think I might be a little confused with the distinction preventive maintenance and predicative maintenance. May someone help to explain the difference between the two kinds of maintenance?
I believe you mean “Predictive Maintenance”.
See Wikipedia definition Wikipedia reference-linkPredictive_maintenance
The Overview paragraph provides a good distinction between both approaches.
In short, adding intelligence to an existing preventive maintenance is Predictive maintenance.
Regards,
Govind.
Marc
Summary:
PdM or condition based maintenance attempts to evaluate the condition of equipment by performing periodic or continuous (on-line) equipment monitoring. The ultimate goal of PdM is to perform maintenance “just in time”, before the equipment fails in service. This is in contrast to time and/or operation count based maintenance where a piece of equipment gets maintained whether it needs it or not. Time based maintenance is labor intensive, ineffective in identifying problems that develop between scheduled inspections and is not cost effective.
Most PdM inspections are performed while equipment is in service, thereby minimizing disruption of normal system operations. Adoption of PdM in the maintenance of equipment can result in substantial cost savings and higher system reliability.
Steve Prevette
Deming Disciple
Another item to be wary of is "have never been down by accident". Some companies play games with downtime, shuffling the books to make it look like the equipment was down for "planned maintenance". You do have to watch out for "the machine just broke, now it is time to do its planned maintenance". I'd ask to see the records for downtime for non-accidental reasons.
Tim Folkerts
Or at least, such scheduled maintenance can be ineffective.
I have heard tales (although I haven't seen the raw data) that some operations like changing lightbulbs can be more efficient on a fixed schedule. If you have to run a requisition, call a guy to get a ladder from some other building and then climb up to change one bulb, there is a lot of extra labor. By changing bulbs before they actualy wearout, there is extra material cost, but reduced labor cost. In some cases, this type of maintenance might be the most effective approach.
Tim F
V
vanputten
Also, Predictive maintenance tends to include direct measurement of the item. Example, an infrared picture of a circuit board to determine hot spots.
Preventive tends to be done on time schedules (as you have.) Predictive tends to be direct measurement of the item to determine if it needs maintenance.
Other examples of Predictive Maintenance - evaluation of particles in suspension in a lubricant, sound and vibration analysis of a machine.
Regards,
Dirk
Tadek
Regards,
Dirk
I agree with you
jrubio
:bigwave: In Europe we are involved in a new and Experimental Standards EN (Europeean Norms) for Maintenance.
ENV 13269: Maintenance - Guideline on preparation of maintenance contracts
EN 13306: Maintenance - Terminology
prEN 13460: 2001 Maintenance - Documents for Maintenance
prCEN/TS 15331: Criteria for design, management and control of maintenance services for buildings
prEN 15341: Maintenance - Maintenance Key Performance Indicators
http://www.wear-management.ch/?path=root+standards&lang=en
PDF:
http://www.dienstleistungs-standards.de/englishsite/020903/franlund.pdf
My University of Engineers of Seville (Spain) is leadering these new Standards
M TS 16949 Clause 7.5.1.4 Preventive and Predictive Maintenance - Requirements Scope IATF 16949 - Automotive Quality Systems Standard 3
T Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements Manufacturing and Related Processes 7
D How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? IATF 16949 - Automotive Quality Systems Standard 8
M Definition Predictive Maintenance vs Preventive Maintenance - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
S Definition Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 32
R Definition Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
F Preventive and Predictive Maintenance - Benchmarking Partner Benchmarking 6
F QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 1
M Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 16
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
R A GRP model that also considers the Preventive Maintenance Efficiency Reliability Analysis - Predictions, Testing and Standards 3
M Tracking Preventive Maintenance Effectively Nonconformance and Corrective Action 5
R Preventive Maintenance Checks Advice Manufacturing and Related Processes 4
M Preventive Maintenance & Operating Procedures for Measurement Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Which ISO/AS Clause directly relates to Preventive Maintenance of Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Free Preventive Maintenance Software Manufacturing and Related Processes 3
S NC Lathe Preventive Maintenance Boiler Plate checklist Reliability Analysis - Predictions, Testing and Standards 3
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Does overdue preventive maintenance require an evaluation on product quality? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Benchmarking Preventive Maintenance Sales Benchmarking 0
Q ISO 9001 Clause 6.3 Infrastructure - Preventive Maintenance Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Preventive Maintenance Scheduling Software recommendations Lean in Manufacturing and Service Industries 8
L Any ideas for Preventive Maintenance checklist? Quality Manager and Management Related Issues 5
R Who runs your Preventive Maintenance Program? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
G Preventive Maintenance for Assembly Line Bar-Code & General Printers - Necessary? IATF 16949 - Automotive Quality Systems Standard 4
Crusader Preventive Maintenance - Electronic Records Deleted/Erased OR Are Records Required? Records and Data - Quality, Legal and Other Evidence 62
I Preventive Action Examples, Excluding Preventive Maintenance, Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Calibration - Not willing to spend money in calibration/preventive maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Preventive Maintenance Program in a non-production facility Misc. Quality Assurance and Business Systems Related Topics 4
S Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms Document Control Systems, Procedures, Forms and Templates 8
G Preventive Maintenance Requirements - ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
H Preventive Maintenance - Does anyone have a sample of a PM procedure? Document Control Systems, Procedures, Forms and Templates 5
Marc Definition Preventive Maintenance - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Randy Preventive and Corrective Maintenance - Looking for a basic procedure Document Control Systems, Procedures, Forms and Templates 19
N 3% of the scheduled preventive maintenance (PMs) cancelled - You make the call! Preventive Action and Continuous Improvement 11
A Preventive maintenance outsourcing - What type of controls? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Can an Ionizer be calibrated or perform preventive maintenance when in use? General Measurement Device and Calibration Topics 6
V Does preventive maintenance have any positive effect on smart transmitters? General Measurement Device and Calibration Topics 1
Marc Preventive Maintenance - Suppliers & Delivery Vehicles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Preventive Maintenance Interpretation - Clause 4.9.g.1 QS-9000 - American Automotive Manufacturers Standard 5
Marc Preventive Maintenance & Machine Manual Control QS-9000 - American Automotive Manufacturers Standard 0
