Primary & Secondary Inspection Definitions - Incoming, In-process & Final Inspection
toffeeman
I'm working on a system to define Primary & Secondary inspection criteria in Incoming, Inprocess & Final QC Inspection processes on the basis that:
A Primary Inspection is the point where a defect can be detected in the process, i.e. after this point the defect is unable to be detected. Examples of this could be visual inspection of a heat seal, Unit Final Test, PCBA Functional Test.
A Secondary Inspection is the inspection point where inspection is performed on a part, where the nonconformance can be detected during test in another inspection/test further on in the process.
I am trying to develop a more robust definition of Primary & Secondary Inspections but am having trouble finding any formal definitions.
Has anyone encountered this type of inspection classification and point me in the right direction to ensure that me definitions are correct?
Many Thanks
Proud Liberal
Re: Primary & Secondary Inspection Definitions - Incoming, In-process & Final Inspect
I've only heard them referred to as in-process or post-process inspections.
toffeeman
An further example would be where there is visual inspection on a part in Incoming Inspection (PCBA IPC-A-610), failure to detect the nonconformance could be caught further in the process as part of a 100% test (PCBA Functional or a Subassembly Test). In this instance the primary inspection would be at the PCBA Test and the secondary would be the visual inspection at Incoming Inspection.
PCBA delamination detected at Incoming Inspection per IPC-A-610 would be a Primary Inspection as the delamination would not be detected at Functional Test
howste
Thaumaturge
What's the purpose for defining "primary" and "secondary" inspections?
If we understand what you're trying to accomplish it should help us to help you.
Rameshwar25 What is primary and secondary functions of a part? FMEA and Control Plans 4
G Primary vs. Secondary Standards - Are secondary standards acceptable for calibration? General Measurement Device and Calibration Topics 9
I Hold Time studies for Primary Reference standards Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Primary Operating Functions (POF) in IEC 62366-1:2015. IEC 62366 - Medical Device Usability Engineering 7
S Should the primary drug containers be molded in ISO Class 7 clean room? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
D Gamma Sterilization of Coin Batteries (Primary Batteries) Other Medical Device Related Standards 3
B Primary lithium battery protection and vented gas IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Stability test - primary packaging EU Medical Device Regulations 7
E Requirements for primary battery powered ME with BF-applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R How to determine the ratings of components in primary circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
I Primary Failure Modes in a Production Line - Pls help a new member FMEA and Control Plans 5
B 510K Submission Authoring - Primary Contact Other US Medical Device Regulations 13
L Old and New Primary Standards show a difference between them General Measurement Device and Calibration Topics 9
S Primary Temperature Standard to -65 degrees C - Calibration Help General Measurement Device and Calibration Topics 3
R Primary Weighing Stone - M1 Accuracy Class - Clarification required General Measurement Device and Calibration Topics 7
J Training Strategy for Primary ISO 9001 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna ISO 15378:2006, Primary packaging materials for medicinal products Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
R NIST - Primary Standard - Traceable to what? What exactly does that imply? General Measurement Device and Calibration Topics 10
R TS 16949 - Do our primary operations require registration? IATF 16949 - Automotive Quality Systems Standard 4
A Anyone using a Primary Frequency Standard? General Measurement Device and Calibration Topics 2
C How to place software version for SaMD product in HIBC secondary data structure (UDI-PI)? Other US Medical Device Regulations 4
T Accessible metal parts connected to secondary ground IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Secondary Manufacturing Site on DoC EU Medical Device Regulations 1
S Isolation of secondary grounded circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
L EN 62368 (In an Annex - M.4.2.1) Secondary Lithium Battery Charging Safeguards CE Marking (Conformité Européene) / CB Scheme 2
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
J Secondary circuits and protective earth IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
Ahang Separation between secondary circuit and accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E IEC 60601 subclause 8.9.1.12 - Earthed secondary circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D The necessity of a SECONDARY CIRCUITS in ME EQUIPMENT (IEC 60601-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
G Regulatory requirements for secondary packages in terms of label content Other Medical Device Regulations World-Wide 2
J Medical Device Electronics - Secondary to output isolation for 1 MOPP IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
shimonv Safety requirements for secondary cells and batteries IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Secondary packaging operations in medical device facility Manufacturing and Related Processes 1
H Secondary button cells (LIR2540) in medical products Other Medical Device Related Standards 1
A Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Insulation between Secondary Accessible Parts and Earth IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B In-Process Sampling Plan for a Secondary Package Adjustment Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Creepage and Clearance Distance for MOOP on Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V External power supply with reinforced insulation as a simple secondary circuit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Frequency of Re-Testing Working Standards (Secondary Reference Standard) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
I Connection of Secondary Circuits to Medical Weight Scale Enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Heating Test Failed - Capacitor in secondary exceed its rated temperature IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
N Medical Device Secondary Packaging Facility - Regulatory Compliance Requirements? EU Medical Device Regulations 2
ScottK Validation of SAP - Secondary Packaging Manufacturer Qualification and Validation (including 21 CFR Part 11) 8
