Print asking for Straightness of 0.013 and it has a note "Any Radial Element"
jager
I have a print asking for Straightness of 0.013 and it has this note "Any Radial Element". Can you tell me what that means? Does it mean straightness over the total part? It is a small washer. Thanks for any help.
Re: Straightness 0.13 Any Radial Element
I can't imagine what a straightness callout would do for a washer. If you could post the drawing (or a detail view from it) it might be helpful.
jager
I think they should have used Flatness instead. I don't think I can attach a drawing, but it is a washer with a 1 inch OD and in the ID are 4 equally spaced small radii and the part is about .030" thick. I hope that helps. Thank you
It's common to see flatness/parallelism callouts for washers, but not straightness. You should talk to whomever it is that owns the drawing and make sure you understand what's intended.
jager
Re: Straightness 0.013 Any Radial Element
Thank you. I see a lot of prints with small errors and unclear notes. We'll check it out.
I appreciate your reply.
David DeLong
I agree that it should have been flatness but let's get back to your original question.
Straightness is a line or axis and is set up by 2 points at the ends of the line. If one has a drawing with a straightness feature control frame and stating "all radial elements", it means that one has to check in many locations from the centre (radial element) out to the circumference. The straightness tolerance applies to each element.
Please remember that the actual straightness is the worst condition found on any of the radial elements. Do NOT total them or combine readings.
Z
zancky
my modest opinion:
it is right that flatness and parallelism callout are the most appropriate requirements for a washer but You may consider how to check it too.
Flatness may requires special device (very low flatness value can be check by glass light franges e.g. checking micrometer, common flatness values are inspected by CMM, etc).
Asking for Straightness seems to me your customer is requiring / suggesting a profile tracer as device (easy to use and easy to print out results)
by the way are you talking about 0.013 inch or mm?
jager
Thank you for the additional explanations. They are helpful and I do now understand radial elements. I would use the worse condition on my layout.
The spec is 0.013mm.
Thanks again.
Stijloor
Although not very common, I've seen straightness applied to surface elements and median/center planes of planar features.
Stijloor.
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K Yet another design question - Customer is asking for a print but we do not do design Design and Development of Products and Processes 19
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Print Requirements Manufacturing and Related Processes 9
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Conflicting dimensions on customer print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
P New Yellow Print VDA 6.3 (2016) VDA Standards - Germany's Automotive Standards 10
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Multiple Features With Only One Toleranced on the Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
A Algorithm to Detect flaw and burr on print characters Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q In a Print Shop the Products are Special Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J A Euro sign on a print tolerance? Manufacturing and Related Processes 8
T More than One Original Test Report - Original Print General Measurement Device and Calibration Topics 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
N Excel Bubble Print Utility - Bubble Prints/Roadmap Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Print (Drawing) Bubble Techniques Document Control Systems, Procedures, Forms and Templates 45
H Example of Contract Review for Print Industry wanted Contract Review Process 4
Jim Wynne An Oldie but Goodie - A Print Block from 1937 Coffee Break and Water Cooler Discussions 1
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Perpendicularity Callout on a Print - GD&T Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
