Print Inspection Requirement to measure Thread Pitch for an 0-80 Thread
bobdoering
Stop X-bar/R Madness!!
#11
Re: 0-80 thread measurement
We were avoiding thread ring gages also. Especially with this small a thread. Never fully trusted our calibration of ring gages. As stated, very operator dependent, very subjective.
That's true - but the price jumps quick after you pass up that option.
RoscoeSplevins
#12
SOLUTION FOUND !!! We have a solution; we're not measuring the pitch diameter, because we can't. We will measure Major diameter and Minor diameter. Both are within our capability. We'll measure thread angle at setup and last piece, both diameters and be happy. Customer should never have specified fit for the item we are treading. Probably taken from a book somewhere...
Thanks all for the suggestions. Wish all our soulutions were this easy.
Stijloor
#13
Thanks all for the suggestions. Wish all our solutions were this easy.
Solution? Well, prior to accepting the order from the Customer. this issue should have been identified and discussed. Trying to come up with "solutions" without customer involvement after the fact can come to bite you in the butt...
Stijloor.
RoscoeSplevins
#15
Things like this are ALWAYS by passing our quoting folks. Luckily our customers, though extremly large companies, are no more sophisicated than we. As evidenced by the thread fit callout for an external, self tapping thread, for a temporary fixture. We feel confident our product will meet design intent. And we feel confident our customer is as poorly prepared to measure the thread pitch diameter as we are. But we did try.
Thanks to all for the assistance. We were in a hurry to resove the delima. We may not have the most technically correct solution, but we have a workable solution.
Stijloor
#16
<snip>Things like this are ALWAYS by passing our quoting folks.<snip>
When I wear my auditor hat, I will write this up as a nonconformity.
And when it's "always" recurring, it will become a major nonconformity.
Something to consider. ;)
Stijloor.
DetroitKeith
#17
Find a local thread grinding house, they may inspect cheaply or as a favor if you know them.
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
K Verify paper print to CAD file so we can use the CAD models for inspection purposes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M Dimension Inspection - Results recorded on print - Seeking a better method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Conflicting dimensions on customer print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
P New Yellow Print VDA 6.3 (2016) VDA Standards - Germany's Automotive Standards 10
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Multiple Features With Only One Toleranced on the Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
A Algorithm to Detect flaw and burr on print characters Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q In a Print Shop the Products are Special Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J A Euro sign on a print tolerance? Manufacturing and Related Processes 8
T More than One Original Test Report - Original Print General Measurement Device and Calibration Topics 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
N Excel Bubble Print Utility - Bubble Prints/Roadmap Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Print (Drawing) Bubble Techniques Document Control Systems, Procedures, Forms and Templates 45
H Example of Contract Review for Print Industry wanted Contract Review Process 4
Jim Wynne An Oldie but Goodie - A Print Block from 1937 Coffee Break and Water Cooler Discussions 1
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Perpendicularity Callout on a Print - GD&T Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Definition WDA and WRP on a Boeing print - What are these acronyms? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
