Print Requirements
J.Enger
So I have a question about manufacturing a cast part. This may not be the correct forum for this, if so, please remove it.
We are manufacturing a part that is made from a casting on its own print (Note 1 on the machine print stats " Machine from 32-0123-1 Casting."). When we find porosity, on the machining print there is no Spec callout for castings ( AMS2175, MIL-C-6021, etc) so do we go back to the casting print for allowances of the porosity or do we allow the porosity through as there is no call out on the machining print. If so, what about other requirements from the cast print. An example is the specification called out for the casting inspection states that machined features from the casting must be penetrant inspected to ensure there are no issues with the part.
Mike S.
Happy to be Alive
I'd look at the casting print.
Of course some porosity may not be apparent until machined unless x-rayed.
J.Enger
The casting is purchased from a Sole Source supplier for our customer. The issue we have is the porosity usually shows itself when we machine the casting, and it fails the requirements of AMS2175 for surface discontinuities, but is acceptable size under the radiographic requirements, hence we get "its a latent defect" reply from the casting house.
In other words, this is a "directed buy"? You have no options as to casting supplier selection? Is your company paying the casting supplier? If the answer to each question is "yes," you're in a tough spot that shouldn't have been agreed to in the first place. That being said, one more question: Do the castings meet the requirements of the casting print?
This is the primary reason you should never accept a directed-buy arrangement for castings. It's like Forrest Gump's box of chocolates--you never know what you're going to get. Given the casting supplier is a sole source and probably knows it, they will stand their ground despite incontrovertible evidence of nonconformity. What do they have to lose? You need to get your customer involved because for practical purposes, it's their their supplier, not yours.
J.Enger
Yes, the castings meet the requirements of the casting print. Its when we machine it and the subsurface nonconformities arise and we have to scrap out the parts. Sometimes we can get a casting house to give us an RMA for Credit on the cost of the casting, but not the time and effort put into machining it.
We have tried that, and the customer doesn't get much positive feedback from the casting house as well. They have tried sourcing other foundries, but no one seems to want the jobs.
Let me ask a different way. Do the conditions you find when machining violate the requirements of the casting print?
J.Enger
Once we machine and the porosity is exposed, it does violate the requirements of the casting print. Their response to this is that they are selling the cast part, not the machine cast part and as they meet the requirements prior to machining, they are not liable for them.
That's BS. Tell them and the customer that you're going to start rejecting things when latent defects are discovered. Then do it. They might tell you to poop in your hat, but again that's the hazard of dealing with a directed source for these things.
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Printer Calibration Requirements - Documents and Pictures (Print Shop) Calibration and Metrology Software and Hardware 11
D ISO 9001: Drawing/Print Control Requirements Document Control Systems, Procedures, Forms and Templates 10
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Conflicting dimensions on customer print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
P New Yellow Print VDA 6.3 (2016) VDA Standards - Germany's Automotive Standards 10
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Multiple Features With Only One Toleranced on the Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
A Algorithm to Detect flaw and burr on print characters Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q In a Print Shop the Products are Special Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J A Euro sign on a print tolerance? Manufacturing and Related Processes 8
T More than One Original Test Report - Original Print General Measurement Device and Calibration Topics 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
N Excel Bubble Print Utility - Bubble Prints/Roadmap Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Print (Drawing) Bubble Techniques Document Control Systems, Procedures, Forms and Templates 45
H Example of Contract Review for Print Industry wanted Contract Review Process 4
Jim Wynne An Oldie but Goodie - A Print Block from 1937 Coffee Break and Water Cooler Discussions 1
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Perpendicularity Callout on a Print - GD&T Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
