Printed Documents are considered Uncontrolled
Stijloor
#11
Re: Any printed documents are considered Uncontrolled
I think I am understanding my auditor now. He voiced he did not like my controls in my footer. It states "This document is valid for 24 hours from the date printed. It is the users responsibility to ensure they have the current revision of this document." Then there is a printed date and time.
He asked if we print copies everyday. I said no because the revision is still valid. When he asked how I had to show him every document so he could compare it to my documentation control list. When he found all was current he couldn't say anything and there wasn't even a concern on his report. But all of this has made me question my controls and maybe looking into a way where the auditor will not question it again.
I work in a small company where the manufacturing line doesn't have access to the computer to get the current Rev. We have trained our supervisors to make sure their employees have the current rev. Plus as part of my procedure for revising a document is to send an email informing all of the new revision. So far it is a good system in my opinion.
Any ideas or suggestions from anyone would be appreciated.
Lisa,
Don't worry about it. You have a process that works. It has been verified. The audit evidence is there. Don't let the auditor and his/her opinion be a cause of concern on your part. :nope:
Keep up the great work! :applause:
Stijloor.
Big Jim
#12
no it was not an NC - It was an "observation not affecting the outcome of the audit" in our registrar's terminology. Something that will be an NC next time if they find it again in the same area.
Something isn't quite right here. It is either a nonconformance or it isn't. There is no such thing as an observation that if uncorrected becomes a nonconformance.
There is a name for this. It is called "soft grading" and is frowned upon by certification bodies and their accreditation bodies.
JoCam
#14
Hi LisaB,
That is the exact same system I have always used, and all auditors have been happy and failed to find any issues.
ScottK
Not out of the crisis
#15
You're judging without all the facts and taking the worst case scenario, I think... as if it was a critical process and nonconforming product was being made.
It was one document in one location in a non critical process.
The auditor found this one instance. He looked for more around the facility and found no others. Thus is wasn't worth an NC, especially since we fixed it within 5 minutes - removed the offending piece of paper and counseled the operator.
I would have made the same call.
ScottK
#16
I think that's perfectly fine.
Heck - we don't even embed time/date stamps in our hard copies and not a single auditor - customer, regulatory, or certification - has taken issue.
I'm also in a fairly small manufacturing company and the machine operators do not have direct access to a computer. However they are all trained to go to the supervisor's office and open document control directory on a couple of shared computers if they need to look at a work instruction or procedure.
In fact, when I give training I encourage them to just scan through the document control directory and look at anything they want. Read the quality manual, the employee handbook, org chart, whatever.
Big Jim
#17
That certainly isn't auditing with "rigor" and has been a big issue with certification bodies. Next time you find a nonconformance you don't want to write up, call your CB and ask them if they want you to "soft grade".
When you do this, you diminish the reputation off all auditors as well as for the entire ISO QMS scheem.
ScottK
#18
That's only slightly insulting.
I don't feel that my reputation as quality professional and auditor has been diminished by my registrar issuing an "observation" rather than a "nonconformance" for something like this.
If that error was indicative of the rest of the facility and repeated in other areas, or a repeated finding from prior audits, I would accept it as a nonconformance, maybe even a major if it was rampant - but he looked and was unable to find other instances.
I forgot to mention that we answer "observations" with CAPA's as if they were NC's.
Come on. Based on your rationale every company would fail every audit if an auditor wanted it to because you'd write up the most minor infraction as an NC.
So instead of "soft grading" they would be ignoring, or there would be a lot more companies losing certification.
I'd rather be soft graded and have a very minor deficiency pointed out than have it ignored and then blow up into something big later.
But I'll pass on your sentiments to my Registrar/Notified Body and see what they have to say.
Big Jim
#19
I'm only passing on what the registrar I mostly deal with brings up with every training session. They do it because ANAB pushes it.
ScottK
#20
Curious - are you aerospace? Sidney Vianna posted a thread a couple of years ago about AS9100 registrars being told to stop soft grading.
Ok - I can understand that since lives are at stake in much of that industry.
But for General industry ISO9001? It's harsh.
Anyway, this is off topic - I'd be happy to start a new thread on soft grading if you'd like to bring others into the debate.
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
K Printed documents can't be controlled Document Control Systems, Procedures, Forms and Templates 16
Q Documents uncontrolled when printed, if is not printed is controlled? Document Control Systems, Procedures, Forms and Templates 4
Q Red Stamped Printed Paper vs. Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Suggestions for addressing Printed Paper Documents Document Control Systems, Procedures, Forms and Templates 3
B Printed Copies of Controlled Documents Document Control Systems, Procedures, Forms and Templates 9
P Should Forms printed for daily use in the shop floor be controlled documents? Document Control Systems, Procedures, Forms and Templates 16
M Controlled documents vs. Hardcopy documents printed "For Reference Only" Document Control Systems, Procedures, Forms and Templates 17
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Informational TGA Consultation: Proposed regulatory scheme for personalised medical devices, including 3D-printed devices Medical Device and FDA Regulations and Standards News 0
M Medical Device News Health Canada update 28-08-18 - Licensing Requirements for 3D-Printed Devices Canada Medical Device Regulations 0
Q Modifying an old printed record? ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Printed Circuit Board Assembly and Components FAI Question Document Control Systems, Procedures, Forms and Templates 8
D Nadcap Certification for Printed Boards Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W Medical Agency Label - A handshake, USA, printed over a US flag ISO 13485:2016 - Medical Device Quality Management Systems 1
D Printed Circuit Board Assembly - General Discussion Manufacturing and Related Processes 1
T Controlling Manual - Control of 10 Printed Manuals throughout our 9 Branches Document Control Systems, Procedures, Forms and Templates 8
W Made in China - Requirement for it to be Printed on the Label? Other US Medical Device Regulations 2
R DFMEA (Design FMEA) on Printed Circuit Boards (PCB's) FMEA and Control Plans 2
shimonv Requirement for a Printed Copy of the User Manual with a Medical Device US Food and Drug Administration (FDA) 3
C Any CQI-Special Process related to Printed Circuit Boards (PCB)? IATF 16949 - Automotive Quality Systems Standard 1
T Customizing the order in which the graphs are printed in Minitab question Software Quality Assurance 1
C 510(K) Number and Establishment Registration Number Printed in Carton Box and Pouches 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Option for adding date-time to the copies printed from Adobe Acrobat (pdf) Quality Assurance and Compliance Software Tools and Solutions 1
W Sterile Product or Not Sterile - The device has "Gamma Irradiated" printed on it 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
michellemmm Hardware Design Standards - Printed Circuit Board Assembly EASA and JAA Aviation Standards and Requirements 2
B Manual Inspection Tools for PCB (Populated Printed Circuit Boards) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
B Revision Control of PCBs (Printed Circuit Board) and Printed Circuit Board Assemblies Manufacturing and Related Processes 6
D Printed Packaging Material Suppliers to Pharmaceutical Companies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 13
ScottK Are printed paper products subject to REACH and RoHS? RoHS, REACH, ELV, IMDS and Restricted Substances 2
Q Workmanship on PCB (Printed Circuit Board) Assembly Manufacturing and Related Processes 14
A Labels - How do you control the number of product labels printed, scrapped and used? Document Control Systems, Procedures, Forms and Templates 5
A How to Reduce Printed Paper Waste Sustainability, Green Initiatives and Ecology 47
P PCB (Printed Circuit Board)/Electronics Inspection Training? IPC-A-610? Career and Occupation Discussions 10
Jim Wynne Telephone Directories - Another Printed Medium Bites the Dust Coffee Break and Water Cooler Discussions 21
J Frustrated with Printed Circuit Board Assembly Suppliers Supplier Quality Assurance and other Supplier Issues 11
A PCB (Printed Circuit Board) Assembly Inspection Checklist Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Control of Printed Work Instructions in Production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
N PCBA (Printed Circuit Board Assembly) Conformal Coating Material and Thickness? Reliability Analysis - Predictions, Testing and Standards 15
J Auditing PCB (Printed Circuit Board) Assembly Lines - Fire And Safety Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R Specified Retention Time of PWB (printed wiring board) Test Coupons Various Other Specifications, Standards, and related Requirements 3
S Packaging Specification template and Reasonable dppm target for printed material? Document Control Systems, Procedures, Forms and Templates 1
Ajit Basrur Pad Printing Ink Requirements for pad printed medical device ISO 13485:2016 - Medical Device Quality Management Systems 4
D Controlled Engineering Drawings - Inspections to printed 'Uncontrolled' Prints Document Control Systems, Procedures, Forms and Templates 14
Q Electronic Work Instructions can be viewed on computer but not printed Document Control Systems, Procedures, Forms and Templates 10
S Receiving Inspection Instructions for PCB's (Printed Circuit Boards) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product Miscellaneous Environmental Standards and EMS Related Discussions 10
M PCB (Printed Circuit Board) Root Cause Fault Analysis Problem Solving, Root Cause Fault and Failure Analysis 1
R ISO Communication Board - Pre-printed ISO9001 posters, quality slogans Misc. Quality Assurance and Business Systems Related Topics 1
