Hello everyone,
I would really appreciate your guidance on the following issue:
Some of the devices used in our production and QC processes are equipped with built-in thermal printers that generate printed results. These results are also stored as PDF files on a server.
My question is: If we stop using the thermal printer output and instead print the stored PDF data using a standard external printer, would that be considered non-compliant with CSV (Computer System Validation) requirements or Data integrity or 21 CFR Part 11? If so, could you please point me to the specific clause or requirement that applies?
Additionally, in cases where the built-in thermal printer is malfunctioning and cannot be repaired, and assuming the device is still storing the data correctly in PDF format to a defined, secure path—would printing from an alternative external printer still be acceptable from a compliance standpoint?
Any references to the relevant regulatory requirements or industry best practices would be greatly appreciated.
