Re: Prior Notice of Sub-Supplier or Material Source Change - PPAP Requirements Questi
You indicated in the OP that the commodity in question is steel; if that's the case, and it's a standard type/grade, so long as they can demonstrate equivalency (i.e., that the material meets specifications), there shouldn't be a need for a big production.
If you want your suppliers to go beyond what's specified in the PPAP manual (and other applicable standards) you need to put your expectations/requirements in writing.
Don't get me wrong, I do appreciate the fact that I was at least made aware of the change. However I think I should have been notified of the change before hand so I could has assessed the risk, significant etc.
Then if I so desired I could have had my purchasing group formally issue sample orders against affected parts
