Private Label Requirements, Manufacturer's Registration & Initial Importers
A single-member LLC with a non-US alien owner wants to sell Class I, 510(k)-exempt medical device via Amazon FBA (Amazon.com). The manufacturer of the device is a foreign business entity and has a valid FDA registration. The LLC wants to sell the medical device as private label. The product packaging will reference the LLC as „Manufactured for”. The manufacturer itself will not be referenced on the package.
I would like to understand all the requirements to be fully compliant with FDA and US Customs regulations:
1. Since the device will be shipped directly to Amazon FBA warehouses, who should be referenced as the Importer under the manufacturer’s FDA registration (Device Listing section): LLC, Amazon or neither of the two?
2. If a 3rd party freight forwarder acts as the consignee, do they need their own FDA registration? If so, do they need to have that particular medical device in their Device Listing section of the registration? Do they need to be referenced on the manufacturer’s FDA registration? What FDA roles (as in "Who Must Register, List and Pay the Fee" on their website) do they need to be registered for?
3. If the LLC is both the IOR as well as consignee, is it subject to any additional FDA registration requirements?
4. If the LLC wants the device to be packed in boxes with custom artwork and the manufacturer is responsible to print it using their regular supply channel, does it still constitute private label or would it require the LLC to register as Relabeler? To clarify, there is no physical relabeling/repacking activity conducted by the LLC. The LLC merely provides the artwork for the box on the dieline supplied by the manufacturer.
5. What are the factors that would require an Initial Importer to be included in the supply chain? Currently, it seems to me that simply importing a device from a foreign FDA-registered manufacturer as private label makes the LLC a Domestic Distributor and merely requires it to be referenced in the manufacturer’s FDA registration.
6. Per 801.62(m), weight and dimensions should be expanded to the largest whole unit in the following way: „196 in (5 yd 1 ft 4 in)”, which I believe is much less helpful to the end consumer in comparison to „16.4 ft”. Does the latter also satisfy the requirements of FDA labeling regulation? If not, how could „196 in (5 yd 1 ft 4 in)” be simplified?
Kind regards
Simon
Ronen E
Problem Solver
Moderator
Then you should - in my opinion - engage with someone who (in your opinion) has appropriate qualifications, and the will, to provide the answers / explanations.
Not sure if you are looking to understand all the requirements or just the ones you listed.
That is a valid point Ronen, thank you. For the sake of this thread, let's focus on the ones I've listed.
Kind regards
Simon
Parul Chansoria
Founder, Elexes Medical Consulting
Since the device is Class 1 510(k) exempt, the device regulations are less stringent and should comply with General Controls.
  1. The importer here shall be Amazon as they shall be responsible for marketing the device from a foreign manufacturer and make final delivery of the device to the ultimate consumer or user.
  2. Yes, the consignee should have an establishment registration and should be registered as an initial importer, however, they need not have the device listed in the database. Since, as per 807.20 (a)(5) "Initial importers may fulfill their listing obligation for any device for which they did not initiate or develop the specifications for the device or repackage or relabel the device by submitting the name and address of the manufacturer." They should also be referenced on the manufacturer’s (foreign business entity) FDA registration as an initial importer.
  3. No, even though an organization is classified as IOR or consignee both needs to be registered as Initial importer and shall have to address the requirements according to an importer and need not go through any additional requirements.
  4. Custom artwork does not qualify as a private label. Further, a custom artwork cannot be considered as change in labeling and hence, LLC cannot be a Relabeler. As per “Who Must Register, List and Pay the Fee” Relabeler is defined as those who “changes the content of the labeling from that supplied from the original manufacturer for distribution under the establishment's own name”.
  5. Yes, just an FDA registration would be required, however, each of the supplier should be evaluated as per the Supplier Management SOP/procedure as defined in the organization's Quality Management System as per 21 CFR Part 820.50 (a)(1) “Evaluate and select potential suppliers, contractors, and consultants on the basis of their ability to meet specified requirements, including quality requirements. The evaluation shall be documented.”
  6. The regulation mandates the use of the largest whole unit, in this case of 196 inches which is 5.44 yards, shall be stated as “196 in (5 yd 3.84 ft) as decimal for yards and feet is allowed.
Q Private Label Listing Requirements for Medical Devices Other US Medical Device Regulations 1
V MDL/MDEL private label process Canada Medical Device Regulations 8
K 510(k) Manufacturer question (private label and manufacture under another persons 510(k)) US Food and Drug Administration (FDA) 1
D Private Label Distribution - US Other US Medical Device Regulations 2
supadrai Just found out the hard way that only one registration per manufacturer is allowed in Yemen, regardless of OEM or private label arrangement. Other Medical Device Regulations World-Wide 0
N Regulatory Responsibilities of an OEM and Private Label manufacturer Canada Medical Device Regulations 3
K Selling Medical Devices in Canada - Distributor? Private Label? Canada Medical Device Regulations 10
supadrai Indonesian MOH Regulation Restricting OEM/Private Label Medical Devices Other Medical Device Regulations World-Wide 2
O Private label issues For EU - Customer does not have CE Mark CE Marking (Conformité Européene) / CB Scheme 7
S Registration/Listing; Initial Importer - Private Label w/ Foreign Establishment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Health Canada Private Label Guidance Confusion - Quality System Required? Canada Medical Device Regulations 5
M Private Label CLIA Waived Status 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Medical Device Registration in Brazil for Private Label Manufacture Other Medical Device Regulations World-Wide 6
K Private Label Devices - Who is responsbile for reporting? US Food and Drug Administration (FDA) 2
C Private Label (Manufacturer in China) Question China Medical Device Regulations 5
R C of Cs (Certificate of Comformance) for Private Label Products Misc. Quality Assurance and Business Systems Related Topics 8
L Rx Only vs. Professional Use Only - Class II Private Label Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 17
R Private Label CE Marked Products for One Person Company ISO 13485:2016 - Medical Device Quality Management Systems 7
H OTC DRUG Private Labelling Distributor: GMP REQUIREMENT ISO 13485:2016 - Medical Device Quality Management Systems 0
R Private Ltd Service Industry Specific Topics 5
K Private Labeler is Relabeler 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Ed Panek MDD Cleared Private Labelled Devices into EU EU Medical Device Regulations 0
Q Private Labeler FURLS Responsibility-USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Z Labeler Code - Private labelling for OTC (Over the Counter) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Z NHP Health Canada Private Labelling Other ISO and International Standards and European Regulations 4
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Marc "Private" Conversations - Limitations for New Registered Members Elsmar Xenforo Forum Software Instructions and Help 14
Marc Conversations (Private Messages) - How to see ALL of Yours Elsmar Xenforo Forum Software Instructions and Help 3
J Manufacturer Name on Private Brand Labeling Other US Medical Device Regulations 12
Q Medical Device Establishment Registration/Listing for Foreign Private Labeler Other US Medical Device Regulations 8
P Medical Device OEM, OBL and Private Labeling Questions EU Medical Device Regulations 5
Q Mexico Medical Device Registration - Private Hospital Exemption Other Medical Device Regulations World-Wide 1
M Medical Device Private Labeler Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
AnaMariaVR2 Agila Specialties Private Limited Warning Letter US Food and Drug Administration (FDA) 0
T Requirements for Private Labeling a Class III (PMA) Medical Device in the US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C UAE Device Regulation and Registration for Public and Private market Other Medical Device Regulations World-Wide 10
S Private Labeling Regulations - Medical Device from Canada into India Other Medical Device Regulations World-Wide 3
P Transfering UK private pension to USA (Cash Out) Immigration and Expatriate Topics 2
Marc Private Sector Preparedness Business Continuity & Resiliency Planning (BCRP) 1
N Process Mapping a Private Company that deals with Insurance Process Maps, Process Mapping and Turtle Diagrams 8
pbojsen OEM / OBL "Private labeler" agreement template? EU Medical Device Regulations 9
Sidney Vianna ISO brochure clarifies distinctions between International Standards and private ones Other ISO and International Standards and European Regulations 2
R Reimbursement to private citizens for a company product Customer and Company Specific Requirements 6
F Realisation of Product in regards to ISO 9001 for Private School (Education) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M What is the advantage of ISO? Private school that teaches from KG to grade 12 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Interesting Discussion FDA 510(k) required? US company Private Labeling an FDA Class II Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 34
D Certification - Changing from 'Partnership' to 'Private Limited Company' Misc. Quality Assurance and Business Systems Related Topics 6
B Labeling question about different manufacturers on a single label Manufacturing and Related Processes 4
S Calibration Label issues General Measurement Device and Calibration Topics 14
M Medical Device Label - Language EU Medical Device Regulations 2
