Probability Density Function of a Function of a Random Variable
sameer_1987
Hello everyone!
I am stuck in my research with a probability density function problem..
I have 'Alpha' which is a random variable from 0-180. Alpha has a uniform pdf equal to 1/180.
Now, 'Phi' is a function of 'Alpha' and the relation is given by,
Phi = (-0.000001274370471*Alpha^4) + (0.000393888213304*Alpha^3) - (0.037767210716686*Alpha^2) + (1.66089231837634*Alpha) - 5.83257204679921
I am trying to find the PDF or CDF of 'Phi' but having a hard time in doing that..
Any help will be greatly appreciated!
Thanks.
H
Hodgepodge
Hello everyone!
Thanks.
Hopefully this will get you started in the right direction.
Check here and choose the 7th item for a brief tutorial. It's the one from Fullerton.edu.
sameer_1987
Hi Hodgepodge,
I saw the power point file. The part of the problem is that 'Phi' is not normally distributed. I realized that by calculating the histogram of Phi. Therefore, maybe I first need to calculate the CDF of Phi and then PDF can be found by differentiating the CDF. But I am not sure how to go about that.
Tim Folkerts
I used a spreadsheet to calculate the value of phi as a function of alpha. (A few of the first points are negative, so I arbitrarily set them to zero, since a probability cannot be negative).
For this to represent a probability, the total of these values for Phi (as alpha goes from 0-180) should equal 1. In reality, the sum is 7674. So if all the values for Phi are divided by 7674, then it is a proper probability density function. The cumulative distribution would then be the integral of Phi, which can be approximated very well in a spreadsheet by simply adding up the values of Phi from zero to any given angle.
At least that is my take after a few minutes' thought.
H
Hodgepodge
Hi Hodgepodge,
Non-normal distribution...is beyond me. Hopefully some of the big brains here can help.
Best regards,
H
Tim Folkerts
PS You could also integrate the polynomial for phi from 0 to 180 and see what you get (I get ~ 7660) (and again, you have to watch out for the first few values that are negative). This confirms the the spreadsheet is on the right track.
Steve Prevette
Deming Disciple
Best thing at this point is to brute force Monte Carlo simulate it.
Determine the reverse cdf for the origninal function
Generate LOTS (thousands) of random numbers between 0 and 1 (easily done on an Excel spreadsheet).
Apply the reverse CDF to the 0 to 1 random numbers
Apply the transformation function
Make a histogram of the results.
sameer_1987
Thanks Steve,
but the problem is to find the inverse. i.e to find alpha in terms of phi..since its a 4th order polynomial...
Steve Prevette
Deming Disciple
Thanks Steve,
Actually the inverse is VERY easy. The statement is that it is a uniform random number from 1 to 180. Generate in Excel thousands of lines of =Rand() * 180. Then execute the formula to each line. Then accumulate as a histogram.
Tim Folkerts
It looks like I was answering a slightly different question before. And now I like the approach Steve posted. Either select a large number of random numbers between 0-180 or select a large number of uniformly spaced numbers between 0-180. Then make the histogram and fit some function to the results. (I actually redid the spreadsheet to do this and the plot is rather nice, with peaks near 23.5 and 79. Finding an actual function to approximate this could be a trick)
PS. Wolfram alpha is a handy site for all sorts of math. It actually finds the inverse of the function, but the answer is a HUGE mess!
http://www.wolframalpha.com/input/?...^2)+++(1.66089231837634*x)+-+5.83257204679921
Marc Definition Probability Density Function - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
H Risk Analysis and Probability of Occurrence ISO 14971 - Medical Device Risk Management 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
MrTetris How to qualitatively assess initial probability ISO 14971 - Medical Device Risk Management 4
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
K Small Sample - Lower Limit Probability Statistical Analysis Tools, Techniques and SPC 0
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
L Balls drawn without replacement probability question Brain Teasers and Puzzles 8
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
Marc Definition PFH - Probability of dangerous failure per hour Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition PFD - Probability of failure on demand Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Risk Acceptability Criteria - Probability and Acceptability Level ISO 14971 - Medical Device Risk Management 1
M Risk Probability - Is there a Better System? ISO 14971 - Medical Device Risk Management 18
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Z What is the Probability of Picking Up "Good" alphabets? Six Sigma 6
N Hazard Probability of Occurrence Definition ISO 14971 - Medical Device Risk Management 11
E Risk Management selection Probability of Occurrence and Severity ISO 14971 - Medical Device Risk Management 24
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
Bev D Probability question - Components of Variation study on a single use diagnostic test Statistical Analysis Tools, Techniques and SPC 1
P One sided confidence interval for probability plot in Minitab Using Minitab Software 1
K Probability of Occurrence Ranking for Low Volume Manufacturing vs High Volume FMEA and Control Plans 11
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
U PROBLEM: Probability of Resource Access Collision Statistical Analysis Tools, Techniques and SPC 5
S Software Risk Estimation: Probability of Medical Device Software Anomaly Occuring ISO 14971 - Medical Device Risk Management 9
N Bayes Law of Conditional Probability ("The Drunkard's Walk" by Mlodinow) Statistical Analysis Tools, Techniques and SPC 1
V Preparing for SSGB - Six Sigma Probability Question Six Sigma 13
R Risk Management - Probability vs. Frequency IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V ASQ CSSGB - More In Depth Probability and Sampling Methods prep materials Book, Video, Blog and Web Site Reviews and Recommendations 4
A Probability of a good lot given that the sample was good Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Rameshwar25 How Probability of Acceptance of a Part is Calculated Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Plotting Probability Exceedance using the Probability Plot Graph in Minitab Using Minitab Software 4
I Mathematical Probability Puzzle Brain Teasers and Puzzles 25
1 What are TOP, DPU, DPO, DPMO? Mult-CTQ (discrete) ZST - Is this a probability? Six Sigma 1
B Probability of finding a Defective Part - Probability question Statistical Analysis Tools, Techniques and SPC 8
D ISO 2859 - Probability that sample size is sufficient Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Multiple Censored Tests to find out the Survival Probability Reliability Analysis - Predictions, Testing and Standards 3
M Probability Distribution Problem Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Confidence Interval on Normal Probability Plot Using Minitab Software 2
bobdoering How's this for a probability function? Player Hits Own Mom With Foul Ball Funny Stuff - Jokes and Humour 7
D Probability of Failure - Seven expansion joints Reliability Analysis - Predictions, Testing and Standards 5
bobdoering Goodness of Fit: Is it normal? Probably...or probably not - it's all probability Imported Legacy Blogs 0
J Xbar - R Control Chart taking into account the Probability Limit Using Minitab Software 8
0 Calculating axis values of normal probability plot Statistical Analysis Tools, Techniques and SPC 4
R Sampling - Total probability of accepting bad lot - Producer's risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Interpreting a Normal Probability Plot Statistical Analysis Tools, Techniques and SPC 4
A Actual probability of TYPE I error for 3 sigma P-chart Statistical Analysis Tools, Techniques and SPC 10
G Running simulations using Bernoulli Distributions with a certain probability. Using Minitab Software 5
