Probability of Failure - Seven expansion joints
daledun
My company made seven expansion joints that were placed into a closed loop pipe system. Two joints failed prematurely and were replaced. Shortly after replacement, the new joints, which were placed into exactly the same locations as the originals, failed. So a first set of joints, then a second, located in the same place in the system failed. The other five located in different locations in the system have functioned as expected.
There is no evidence that manufacturing deficiencies were to blame for the failures. What statistical/probability data can I present to the customer to reinforce my belief that it is a problem with their system, not my product? I do not have MTBF info.
Thanks in advance for your thoughts.
Tim Folkerts
Re: Probability of Failure
Here are two different ways to look at it:
(This argues your side). Suppose the parts follow an exponential sort of failure mode - so that previous history is not an indication of future performance (which is common for electronics). If you run the system long enough, you would expect eventually that two joints in each would fail. Suppose position x and y fail first. When you replace them, the system is like new (due to the nature of the exponential failure mode). The second time around, there is a 2/7 chance that x or y position will fail first and a 1/6 chance that the remaining x or y will fail next = 2/42 = 1/21 = 4.8%.
(this argues their side). Suppose that, unknown to you, the joints are bad 1/3 of the time. In the system, you would expect about 2 bad joints. If you replace these with two other random joints, there is a 1/3 * 1/3 = 1/9 =11% chance that you would randomly select 2 more bad joints as the replacements and that they would again fail prematurely. Not very likely, but certainly possible, so it is hard to rule out bad parts as the cause
My guess would be that vibrations/stress/heat/etc at those two spots is generating the problems. More info on the MTTF and the failure distribution would obviously help nail down the answer.
Tim
Steve Prevette
Deming Disciple
I'd suggest doing this more as a binomial.
Let us assume that each of the 7 joints at any point in time are equally likely to be the "next to fail". Even if some joints were replaced more recently than others, if we do assume exponential (memoryless) failure, then the assumption is valid that each equally likely to be the next to fail.
Now - what is the probability that the first four failures will ONLY involve two of the joints? If we pick two specific joints, then the probability of the first failure includes one of the two specific joints is 2/7. Same for the second, the third, and the fourth. Thus we end upon with (2/7)^4 = 0.006664
However, we don't know the specific two joints. We must multiply by the numbers of ways we can take two joints out of seven. That is 7! / (2! x 5!) or 7*6/2 = 21.
So the probability that the first four failures involve only two of the joints is 21 * 0.006664 = 0.14
bobdoering
Stop X-bar/R Madness!!
The problem may be you do not have all of the system variables to determine the root cause. If you have any data that compares the print requirements of the parts that are passing to the parts that are failing to show they are in print (thickness, tensile and/or compression testing, etc.) that is a good starting point. You do not likely have key system data, such as: 1) system pressure in passing areas vs failing areas 2) flange condition (flatness, surface finish) 3) flange bolt torque 4) flange spacing after installation 5) perpendicularity of flanges (is there a cantilevered load cocking the flanges in the failing installation?). There may be sufficient difference in any of these factors that could cause a failure in one area, but not another - however, acquiring that data may be difficult..
If the root cause is in the system and not product variation, they are independent occurrences, and that would influence the probability of failure - they may never fail in the other installations, and they may always fail in the suspect installations. They are trying to determine product MTTB (blame) - and the raw failure data may not accurately represent that. It may represent installation MTTB (shared blame).
Tim Folkerts
(For the sake of argument, let's assume that joint 1 & joint 2 are the ones that failed)
My concern with your analysis, Steve, is that you are allowing for some possibilities that could not easily have occurred in the actual setting. For example, you include the possibility that joint 1 failed all four times. In other words, you are replacing the failed joint as soon as it fails. But in the actual setting, they had a pair of failures replaced together, so there are fewer possibilities. I think my estimate of 4.8% is more appropriate than 14%.
Perhaps more importantly for the original post, all of this assumes the process is "memoryless", which I would not expect for mechanical parts. Steve & I were both being mathematicians and not engineers.
If you drive your car until 1 tire goes flat (and replaced it with a new tire), you would be highly surprised if that new tire was the next to go flat. And it it did go flat again then I would look for a problem with the car -- basically what Bob was discussing. If you take into account this real life wear & tear & stress & strain, then the odds that either steve or I calculated would be WAY too high.
Tim
While this is a good discussion, can you not perform a failure analysis of the failed joints? You did not say whether these were metal joints, so this may be out in left field. A good metallurgical analysis can tell many things about the type of stress that caused a failure. You can tell the difference between an overstress, a fatigue failure, material or heat treat issues.
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
Marc Definition PFH - Probability of dangerous failure per hour Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition PFD - Probability of failure on demand Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
M Simple Probability Statistics - Assembly Failure - Binomial Equations Statistical Analysis Tools, Techniques and SPC 12
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
MrTetris How to qualitatively assess initial probability ISO 14971 - Medical Device Risk Management 4
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
K Small Sample - Lower Limit Probability Statistical Analysis Tools, Techniques and SPC 0
L Balls drawn without replacement probability question Brain Teasers and Puzzles 8
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
A Risk Acceptability Criteria - Probability and Acceptability Level ISO 14971 - Medical Device Risk Management 1
M Risk Probability - Is there a Better System? ISO 14971 - Medical Device Risk Management 18
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Z What is the Probability of Picking Up "Good" alphabets? Six Sigma 6
N Hazard Probability of Occurrence Definition ISO 14971 - Medical Device Risk Management 11
E Risk Management selection Probability of Occurrence and Severity ISO 14971 - Medical Device Risk Management 17
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
Bev D Probability question - Components of Variation study on a single use diagnostic test Statistical Analysis Tools, Techniques and SPC 1
P One sided confidence interval for probability plot in Minitab Using Minitab Software 1
K Probability of Occurrence Ranking for Low Volume Manufacturing vs High Volume FMEA and Control Plans 11
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
U PROBLEM: Probability of Resource Access Collision Statistical Analysis Tools, Techniques and SPC 5
S Software Risk Estimation: Probability of Medical Device Software Anomaly Occuring ISO 14971 - Medical Device Risk Management 9
ncwalker Bayes Law of Conditional Probability ("The Drunkard's Walk" by Mlodinow) Statistical Analysis Tools, Techniques and SPC 1
S Probability Density Function of a Function of a Random Variable Statistical Analysis Tools, Techniques and SPC 13
V Preparing for SSGB - Six Sigma Probability Question Six Sigma 13
R Risk Management - Probability vs. Frequency IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V ASQ CSSGB - More In Depth Probability and Sampling Methods prep materials Book, Video, Blog and Web Site Reviews and Recommendations 4
A Probability of a good lot given that the sample was good Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Rameshwar25 How Probability of Acceptance of a Part is Calculated Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Plotting Probability Exceedance using the Probability Plot Graph in Minitab Using Minitab Software 4
I Mathematical Probability Puzzle Brain Teasers and Puzzles 25
1 What are TOP, DPU, DPO, DPMO? Mult-CTQ (discrete) ZST - Is this a probability? Six Sigma 1
B Probability of finding a Defective Part - Probability question Statistical Analysis Tools, Techniques and SPC 8
D ISO 2859 - Probability that sample size is sufficient Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Multiple Censored Tests to find out the Survival Probability Reliability Analysis - Predictions, Testing and Standards 3
M Probability Distribution Problem Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Confidence Interval on Normal Probability Plot Using Minitab Software 2
bobdoering How's this for a probability function? Player Hits Own Mom With Foul Ball Funny Stuff - Jokes and Humour 7
bobdoering Goodness of Fit: Is it normal? Probably...or probably not - it's all probability Imported Legacy Blogs 0
J Xbar - R Control Chart taking into account the Probability Limit Using Minitab Software 8
0 Calculating axis values of normal probability plot Statistical Analysis Tools, Techniques and SPC 4
R Sampling - Total probability of accepting bad lot - Producer's risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Interpreting a Normal Probability Plot Statistical Analysis Tools, Techniques and SPC 4
A Actual probability of TYPE I error for 3 sigma P-chart Statistical Analysis Tools, Techniques and SPC 10
G Running simulations using Bernoulli Distributions with a certain probability. Using Minitab Software 5
A Probability of points outside of... Statistical Analysis Tools, Techniques and SPC 2
J Failures-in-time (FITs), DPPM and Probability Calculation Questions Reliability Analysis - Predictions, Testing and Standards 9
