I want to perform a study to calculate the 'probability of correctly detecting a defect size'. The defect is 'wrinkle size' and it varies from 0 to 0.2. The defects are classified into three different categories, Low wrinkle (less than 0.10), Medium wrinkle (between 0.1 - 0.15) and High wrinkle (0.15 - 2.0). The defects are classified visually by operator by looking at a the 'scan result picture'. The object of the study is to estimate 'The probabiliy of detecting a Low wrinkle is xx with a confidence interval of yy and the probability of detecting a medium wrinkle is yy with a confidance interval of zz and so forth. (see attached picture)
For this purpose i plan to take 10 samples of each defect category Low, medium and High. They will be classified by a better measurement system and then a operator will be asked to classify each sample into different defect size. I want to know how to calculate the probability from this data, Is this the right appraoch or should i perform a GR&R instead?
