Problem solving activity - Three hours to fix the issue
Rush2608
Rushtam
If your manager tells you that you have only three hours to fix the issue on the manufacturing floor. How would you proceed? What tools you use or which route would you go to fix the issue?
I’ll use my approach on you:
Step 1: what is The Problem? In other words in simple words what is not right with what?
The basic approach is to state the Problem then work backwards to the causal mechanism. Along the way it may be possible to implement a containment that prevents the Problem from getting to the Customer in some way. But beyond that the exact tools and methods are based on the nature of the problem. Behavior based problems and physics based problems have very different tools.
Marc
Fully vaccinated are you?
Also - Have you actually visited the place where the problem is reported to be and observed the problem?
qualprod
It depends of what ... fix could have several meanings, to remove the problem or just "stop the bleeding".
There are things easy to solve , while others take too long..
Ed Panek
QA RA Small Med Dev Company
Triple constraints can be applied to almost any solution. Pick two of the following three
Cheap
Fast
Good
You cant have all 3.
Cheap
Fast
Good
I've always thought that this idea is superficial and a little silly. The best answers are the most direct ones, and they can indeed be relatively cheap, fast and good. A lot depends on the problem-solving skills of the individual. Some people who are assigned the task of solving a problem are likely to make things more complicated than they need to be, and perhaps make things worse.
Ed Panek
It is silly but its important to ask "What is the most critical part of the project?"
Perfection is the enemy of good is another or paralysis by analysis
