Problem solving activity - Three hours to fix the issue
#11
Triple constraints can be applied to almost any solution. Pick two of the following three
Cheap
Fast
Good
You cant have all 3.
In my experience this just an old trope. If you have good problem solving skills you can have all three. the same applies to R&D development - with good development tools and skills you can have all 3. I've done it now for 35 years.
Proud Liberal
#13
If your manager tells you that you have only three hours to fix the issue on the manufacturing floor. How would you proceed? What tools you use or which route would you go to fix the issue?
Three hours seems like an unreasonable window based on the types of problems I've seen in my career (ie: an 8D type issue). To that, I would say updating your resume would be in order. But I guess it would depend on the type of problem you're attacking.
Ninja
Looking for Reality
#14
Since we're already drifting off topic...
I would ask "What's it worth to you if I succeed? How much money is this costing the company per hour? Who else ya got to handle this?"
silentmonkey
#15
As many others have already said, it depends on the nature of the issue. I'll try to provide a serious response to the question.
My first priority, especially in such a short period of time, would be to apply containment. What can you do to protect the customer i.e. prevent the issue from being delivered into the field? This can be utilising the next batch of materials (if you have evidence it's batch-specific), performing added inspection, rework or some other workaround while the root of the problem is being investigated and a proper corrective action can be applied.
Root cause analysis and corrective action can take much longer than 3 hours depending on the nature of the issue so containment can buy you time.
Then there are various root cause analysis tools available such as 5 Whys, Ishikawa, or KT. I would say finding a root cause is usually the hardest part in problem solving. In saying that, don't forget about the other important aspects such as:
Problem Statement, Impact/Risk Assessment, Containment, Disposition, Corrective/Preventive Action and Effectiveness Check.
Good luck my friend, I hope you didn't get fired already.
#16
The first important step will b define the problem by going to the actual place of occurence and getting the information baed on What, When,Where,Who,Why, How and How much. Having gathering premilary Investigation Use 5 Why technique to find the Root cause on root cause 1.to occur 2. Reason for not getting detected and outflow to customer. Answer for this help you in implementating system based correction so that problem never occur again.
NDesouza Go See, Think, Do (GSTD) Problem Solving Activity Food Safety - ISO 22000, HACCP (21 CFR 120) 8
M Problem Solving in Fiat Automobiles Problem Solving, Root Cause Fault and Failure Analysis 0
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
D Training for AS13000 - Problem Solving Requirements for Suppliers Training - Internal, External, Online and Distance Learning 14
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 1
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 8
M Training in 8D Problem Solving as a Preventive Action? Problem Solving, Root Cause Fault and Failure Analysis 9
A 5Why vs. 8D - Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 19
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
W Documented Problem-Solving for Automotive IATF 16949 - Automotive Quality Systems Standard 4
Q Problem Solving Techniques - 5 why or Fishbone diagram ? Problem Solving, Root Cause Fault and Failure Analysis 8
S Problem Solving Database for Each Machine Manufacturing and Related Processes 5
automoto International Problem Solving Guide Problem Solving, Root Cause Fault and Failure Analysis 2
M Problem Solving: JDI (just do it) vs. A3 vs PDCA Projects Lean in Manufacturing and Service Industries 1
P Global 8D Problem Solving Training Material Problem Solving, Root Cause Fault and Failure Analysis 1
P Global 8D Problem Solving Example Problem Solving, Root Cause Fault and Failure Analysis 5
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
B Problem to be used for Problem Solving class for different Manufacturing Backgrounds Problem Solving, Root Cause Fault and Failure Analysis 1
T What Problem Solving Tools do you use the most? Problem Solving, Root Cause Fault and Failure Analysis 4
E Problem Solving using PDCA/A3 - Tips & Exercise Lean in Manufacturing and Service Industries 3
C A3 Problem Solving Template Document Control Systems, Procedures, Forms and Templates 0
C 5 Why's Problem Solving Template Document Control Systems, Procedures, Forms and Templates 0
O Practical 8-D or similar Problem Solving worksheet or form Excel .xls Spreadsheet Templates and Tools 5
Q Green Wall or Green Room Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 2
K 7 or 8D (Problem Solving) CAPA template Nonconformance and Corrective Action 4
C What is problem solving? Imported Legacy Blogs 5
T Practical Problem Solving - Does anyone have a practical problem solving template? Document Control Systems, Procedures, Forms and Templates 6
W Does anyone have a Training Exercise for 5 Whys Problem Solving? Problem Solving, Root Cause Fault and Failure Analysis 11
B Problem Solving Methodology Help - Shainin/Red X Problem Solving, Root Cause Fault and Failure Analysis 19
Q List of Problem Solving Methods (not tools) Problem Solving, Root Cause Fault and Failure Analysis 23
R 5S Problem Solving Presentation needed Lean in Manufacturing and Service Industries 4
F Toyota A3 Practical Problem Solving (PPS) Document Needed Nonconformance and Corrective Action 1
Casana 8D (Eight Disciplines) Problem Solving - When Actions are not Effective Nonconformance and Corrective Action 5
P I need a good QC story format for my use in problem solving technique Document Control Systems, Procedures, Forms and Templates 1
U Problem Solving Flowchart Problem Solving, Root Cause Fault and Failure Analysis 9
M Lesson Learned Cards for Problem Solving and Prevention after 8D Problem Solving, Root Cause Fault and Failure Analysis 1
F Problem Solving Workshops - DMAIC Example? Six Sigma 11
L When to use 8D Problem Solving Misc. Quality Assurance and Business Systems Related Topics 3
A How many steps in an 8D? What is an 8-D? Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 4
J IS - IS NOT Problem Solving Analysis Method Nonconformance and Corrective Action 10
Chennaiite What is meant by 'Lesson Learned' in the context of Problem Solving Quality Tools, Improvement and Analysis 6
C Planning & Implementing Solution (book chapter 5 on problem solving) The Reading Room 8
C Identifying Causes (book chapter 4 on problem solving) The Reading Room 26
D Problem Solving Techniques Training Materials Training - Internal, External, Online and Distance Learning 4
M So long Problem Solving Program? Quality Tools, Improvement and Analysis 1
C Understanding the Process (book chapter 3 on problem solving) The Reading Room 26
A Non-conformance tools and problem solving - Customer complaints Customer Complaints 4
I TRIZ (Theory of Inventive Problem Solving) Methodology - Is there training available? Misc. Quality Assurance and Business Systems Related Topics 6
R Practical Problem Solving for Management Development Quality Tools, Improvement and Analysis 3
B Informational Problem Solving for Effective Corrective Actions Nonconformance and Corrective Action 15
