Problem Solving
deepikanegi
If there is an issue with assembling two components but when gauged separately look good, how would you approach the problem?
Enghabashy
* some of manufacturing of components & assembly processes could need also Jigs or fixtures at designated stages
** If there's more information about this case , we can provide more study ; as below " for example only :
***When I specify hole diameter & the bar /shaft diameter ; the fitting should be classified also " clearance ; transient or interference fit"
****The grade of gauges could differ accordingly " Grade H of Hole & h or g for the bar/shaft ; anyhow the allowance between both maybe need more study.
welcome :bigwave: Can you elaborate on the actual “issue”? Getting the Problem statement right is the first best step.
Without more information my first instinct is to look for two other parts that will “assemble correctly”. Actually you should have 3 ‘pairs of correctly assembled and 3 pair of assemblies with ‘issues’. Then swap one of the parts between the 3 pairs of good and bad assemblies. Let’s call that part A (Agood and Abad) If the Problem follows the swapped part (A) you need to look at what is different between the 3 Agood and Abad Parts. If the Assemblies stay in their original condition then you need to look for differences between the 3 part Bgood and part Bbad…
The real key here is to not think about in spec or out of spec - look for differences. Remember that the specifications can be wrong.
It could be a potential tolerance stack up problem. Try running a Monte Carlo simulation to see if that is an issue. It only takes a few minutes and could save a lot of time.
Jackwilders
The first step would be to determine what the exact issue is when these two components are being assembled. This can be done by using specialized gauging or measuring equipment. Once the issue has been identified, troubleshooting should be done to try and determine the root cause of the problem. This could include checking for potential clearance issues, checking forbuild tolerances, or even inspecting for any wear or damage in the components or tools used for assembly. Once the root cause has been discovered, corrective action should be taken to resolve the issue. This could involve changing out parts, adjusting settings, or using different tools and techniques.
Steve Prevette
Deming Disciple
Happens all the time. If the nut is at the low end of the spec, and the bolt is at the high end, then they might not work. Simplest answer is to review and revise the specs such that the nut at the low end of the spec (plus some wiggle room) will engage a bolt at the high end (plus some wiggle room). Proper "wiggle room" could be determined through a good Gage R&R.
Honda automobile got rid of a lot of those problems by using standard bolts and nuts and minimizing the various differing sizes.
mattador78
I agree it happens loads the amount of time we have had to advise people that they have left no plating/painting tolerances on machined parts is ridiculous. This isnt just one man band outfits either even had this issue with F1 car companies
John Predmore
"In spec" does not equal "parts work." At best "in spec" means "we THINK they will work."
I had one coworker who referred to engineering drawings as “cartoons”. He also said engineering tolerances were one man’s opinion of what dimensions ought to work. Parts in an individual assembly either work or they don’t, which is determined by their shape and the way they are made and the circumstances they are in, and not the drawing. Dorian Shainin famously said about problem-solving, “talk to the parts” instead of the engineers. The parts do not lie.
MOester
Yep. I've yet to see a DV where we make a handful of parts at MMC to every tolerance and a handful at LMC and test the extremes. They're just copy pasted from print to print. We have a good handle on critical dimension because we have a lot of data on prior models.
And Lord help you if you find out you can increase a tolerance for manufacturability AFTER launch. It's super easy to tighten them. But loosening them - I haven't found that magic spell yet. :) It's often less work to just live with it. You consumers are going to pay anyway, eventually.
D 10.2.3 Problem Solving - What to look for at a non production remote site? IATF 16949 - Automotive Quality Systems Standard 5
G Supplier problem solving IATF 16949 - Automotive Quality Systems Standard 8
Booker Leadership non-conformity, Top Management's involvement in Problem Solving IATF 16949 - Automotive Quality Systems Standard 10
J PROBLEM SOLVING - IATF and GM CSR IATF 16949 - Automotive Quality Systems Standard 0
M Problem Solving in Fiat Automobiles Problem Solving, Root Cause Fault and Failure Analysis 0
R Problem solving activity - Three hours to fix the issue Manufacturing and Related Processes 15
NDesouza Go See, Think, Do (GSTD) Problem Solving Activity Food Safety - ISO 22000, HACCP (21 CFR 120) 8
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
D Training for AS13000 - Problem Solving Requirements for Suppliers Training - Internal, External, Online and Distance Learning 17
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 1
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 8
M Training in 8D Problem Solving as a Preventive Action? Problem Solving, Root Cause Fault and Failure Analysis 9
A 5Why vs. 8D - Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 19
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
W Documented Problem-Solving for Automotive IATF 16949 - Automotive Quality Systems Standard 4
Q Problem Solving Techniques - 5 why or Fishbone diagram ? Problem Solving, Root Cause Fault and Failure Analysis 8
S Problem Solving Database for Each Machine Manufacturing and Related Processes 5
automoto International Problem Solving Guide Problem Solving, Root Cause Fault and Failure Analysis 2
M Problem Solving: JDI (just do it) vs. A3 vs PDCA Projects Lean in Manufacturing and Service Industries 1
P Global 8D Problem Solving Training Material Problem Solving, Root Cause Fault and Failure Analysis 1
P Global 8D Problem Solving Example Problem Solving, Root Cause Fault and Failure Analysis 5
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
B Problem to be used for Problem Solving class for different Manufacturing Backgrounds Problem Solving, Root Cause Fault and Failure Analysis 1
T What Problem Solving Tools do you use the most? Problem Solving, Root Cause Fault and Failure Analysis 4
E Problem Solving using PDCA/A3 - Tips & Exercise Lean in Manufacturing and Service Industries 3
C A3 Problem Solving Template Document Control Systems, Procedures, Forms and Templates 0
C 5 Why's Problem Solving Template Document Control Systems, Procedures, Forms and Templates 0
O Practical 8-D or similar Problem Solving worksheet or form Excel .xls Spreadsheet Templates and Tools 5
Q Green Wall or Green Room Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 2
K 7 or 8D (Problem Solving) CAPA template Nonconformance and Corrective Action 4
C What is problem solving? Imported Legacy Blogs 5
T Practical Problem Solving - Does anyone have a practical problem solving template? Document Control Systems, Procedures, Forms and Templates 6
W Does anyone have a Training Exercise for 5 Whys Problem Solving? Problem Solving, Root Cause Fault and Failure Analysis 11
B Problem Solving Methodology Help - Shainin/Red X Problem Solving, Root Cause Fault and Failure Analysis 19
Q List of Problem Solving Methods (not tools) Problem Solving, Root Cause Fault and Failure Analysis 23
R 5S Problem Solving Presentation needed Lean in Manufacturing and Service Industries 4
F Toyota A3 Practical Problem Solving (PPS) Document Needed Nonconformance and Corrective Action 1
Casana 8D (Eight Disciplines) Problem Solving - When Actions are not Effective Nonconformance and Corrective Action 5
P I need a good QC story format for my use in problem solving technique Document Control Systems, Procedures, Forms and Templates 1
U Problem Solving Flowchart Problem Solving, Root Cause Fault and Failure Analysis 9
M Lesson Learned Cards for Problem Solving and Prevention after 8D Problem Solving, Root Cause Fault and Failure Analysis 1
F Problem Solving Workshops - DMAIC Example? Six Sigma 11
L When to use 8D Problem Solving Misc. Quality Assurance and Business Systems Related Topics 3
A How many steps in an 8D? What is an 8-D? Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 4
J IS - IS NOT Problem Solving Analysis Method Nonconformance and Corrective Action 10
Chennaiite What is meant by 'Lesson Learned' in the context of Problem Solving Quality Tools, Improvement and Analysis 6
C Planning & Implementing Solution (book chapter 5 on problem solving) The Reading Room 8
C Identifying Causes (book chapter 4 on problem solving) The Reading Room 26
D Problem Solving Techniques Training Materials Training - Internal, External, Online and Distance Learning 4
M So long Problem Solving Program? Quality Tools, Improvement and Analysis 1
