Problem with nonlinear regression
I am trying to do a nonlinear regression with proportional data, but it doesn't work in Minitab. I'm getting the problems:
- "* WARNING * Singular or nearly singular gradient matrix detected at the final iteration; no statistic based on the gradient matrix will be calculated. "
-"* WARNING * Convergence criterion not met: achieved relative-offset = 2,58199."
but I don't really know why. I have 7 different variables and it works with 5 of them but with the last 2 it doesn't. Any idea what to do? The last 2 variables have a lot of 0 in them since they are not used as often but it should not matter.
It depends on the nonlinear equation that you are using. Some equations cannot handle non-positive (i.e., 0) data.
Ok. Technically, polynomials are still linear regression, so my comment does not apply. I would need to see your analysis.
Can you attach your Minitab project file? I can open version 18, so if you are on 19 or 20, you will need to save it as version 18.
Try "Save Project As" then look at the drop down list under "Save As type:". It should give you the option to save it as a version 18 MPJ file.
If you are on version 19, try updating to the most recent version 19. When Minitab first released 19, they omitted the ability to save as an older version. There was a huge outcry from their customers, so they put it back in.
I only got MPX as an alternative, but I think it works now. I changed the part after "Minitab." to MPJ and it seems like it made a difference.
If it works, this is a small example of the data we got but same problem occur. Our problem is with variable 4 and 5. Hopefully it works
No. Even with the MPJ extension, I got an unsupported file format error.
You can attach the raw data in Excel, and copy paste your model into Word.
Sorry for the delay in responding. You are apparently using a new feature in Minitab that is not available in Minitab 18. What made you decide to use a nonlinear approach? The data are extremely noisy to the point that it is impossible to see any real relationship.
D 10.2.3 Problem Solving - What to look for at a non production remote site? IATF 16949 - Automotive Quality Systems Standard 4
D Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 3
G Supplier problem solving IATF 16949 - Automotive Quality Systems Standard 8
M PROBLEM IN SCOPE OF ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
B Leadership non-conformity, Top Management's involvement in Problem Solving IATF 16949 - Automotive Quality Systems Standard 10
P Looking for help with an Ansys Workbench problem Manufacturing and Related Processes 0
M How to apply IEC 62304 Problem Resolution Process for bugs discovered prior to release i.e. during initial development? IEC 62304 - Medical Device Software Life Cycle Processes 2
J PROBLEM SOLVING - IATF and GM CSR IATF 16949 - Automotive Quality Systems Standard 0
W 6.1.3 Compliance obligations b) - problem with understanding ISO 14001:2015 Specific Discussions 0
Beth Savage Problem switching DNS Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Help on formulating a LP minimization problem Manufacturing and Related Processes 2
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
J Mandatory Problem Reporting and Recalls Canada Medical Device Regulations 0
J How to keep MDD certificate valid when legal manufacturer has liquidity problem EU Medical Device Regulations 0
M Problem Solving in Fiat Automobiles Problem Solving, Root Cause Fault and Failure Analysis 0
R Problem solving activity - Three hours to fix the issue Manufacturing and Related Processes 15
T Formal Q Self Assessment - Problem with assigning Product and Process Customer and Company Specific Requirements 1
NDesouza Go See, Think, Do (GSTD) Problem Solving Activity Food Safety - ISO 22000, HACCP (21 CFR 120) 8
Marc Medical device vulnerability highlights problem of third-party code in IoT devices Other Medical Device and Orthopedic Related Topics 1
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
qualprod Add new action plans in CA, while waiting effectiveness - Same problem reappears ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Marc Problem Opening Attachments Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 4
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
D Training for AS13000 - Problem Solving Requirements for Suppliers Training - Internal, External, Online and Distance Learning 17
eule del ayre Manual Inventory System - Problem is discipline of the employees Lean in Manufacturing and Service Industries 7
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 1
G When preventative action is prohibited by cost in 8D problem solving Problem Solving, Root Cause Fault and Failure Analysis 8
Marc vBulletin to Xenforo Import Problem Reports 28180928 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 25
M Training in 8D Problem Solving as a Preventive Action? Problem Solving, Root Cause Fault and Failure Analysis 9
A 5Why vs. 8D - Problem Solving Problem Solving, Root Cause Fault and Failure Analysis 19
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
V Query on PA66+GF15% - Color variation (Natural to Yellowish) problem Manufacturing and Related Processes 20
J Can someone help me get the UCL AND LCL for this problem? Statistical Analysis Tools, Techniques and SPC 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
K Problem with Cable Composed of Coextruded Litz Wire and Tube Manufacturing and Related Processes 1
W Documented Problem-Solving for Automotive IATF 16949 - Automotive Quality Systems Standard 4
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M Taguchi Loss Function Problem Misc. Quality Assurance and Business Systems Related Topics 2
R RoHS Compliance Problem with One Component RoHS, REACH, ELV, IMDS and Restricted Substances 5
Q Problem Solving Techniques - 5 why or Fishbone diagram ? Problem Solving, Root Cause Fault and Failure Analysis 8
S Problem Solving Database for Each Machine Manufacturing and Related Processes 5
L Suppliers Problem - One of our material suppliers is not ISO certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
J Should failure mode caused by Fixture problem be into PFMEA? FMEA and Control Plans 2
